Samsung UE46F6400 TV Connection: Hi-Fi Tower/Set-up Compatibility & Inputs/Outputs Needed
filip1127 7284 4
  • #1 16999324
    filip1127
    I have a SAMSUNG UE46F6400 TV
    About the following connectors:
    Audio output (Mini Jack)
    No
    Component In (Y / Pb / Pr)
    1
    Composite In (AV)
    1 (Common Use as Component Y)
    Digital Audio Out (Optical)
    1
    Ethernet (LAN)
    1
    HDMI
    4
    RF Input (Terrestrial / Cable)
    1
    RF (satellite) input
    No
    RS-232C (AV CONTROL)
    No
    USB
    3
    Headphones
    1
    CI slot
    1
    IR Out
    Yes
    I want to buy some Hi-Fi towers / set up to PLN 1800. Please tell me what input / output should have so that I can connect my TV to it?
  • #2 16999533
    pitron
    Help: 51
    Rate: 100
    You have a digital optical output on the TV, choose a tower with this connector.
    You will send audio digitally between devices over the fiber optic cable.
    The best option when it comes to sound quality.
  • #3 16999569
    AndrzejB1e1
    There is definitely an HDMI output in the new towers and this will take care of watching movies from the tower. On the other hand, the audio signal is probably only from the TV headphone output to the AUX input in the tower (this is not an optimal solution). You will definitely find a cable for such a connection.
  • #5 17000742
    Koolo
    Help: 9
    Rate: 75
    It will fit but Pioneer can "decode" only PCM ... check if Samsung can set "pcm" on optical output "permanently".
