Connecting Samsung TV's Optical Toslink Output to Amplifier with Chinch Inputs: Adapter Solution
Koninaa 3891 8
  • #1 16522308
    Koninaa
    In my new Samsung TV, I only have the toslink optical output. I have Chinch inputs in the amplifier.
    I do not know how to connect it to work properly. I found such an optical to analog adapter in one of the stores. http://sklepwideo.pl/details.php?id=ac4wauda
    Will it be able to play properly in the amplifier thanks to this? Will the sound quality be worse? Will it even work?
    Or maybe someone knows other methods? I would like to add that there are NO OTHER AUDIO OUTPUTS on the TV.
  • #2 16522341
    kokapetyl
    Help: 1787
    Rate: 2101
    Koninaa wrote:
    Will it even work?
    Theoretically it should.
    It is not an adapter, but a D / A converter.
    Worse than what (no comparison)? The sound will not be digital, but analog, because the amplifier only supports it.
  • #3 16522349
    Koninaa
    I meant whether after using this converter the sound quality will deteriorate significantly and it will sound poor simply or it will not make a difference and it will sound as if it were connected with ordinary chinchas.
    And above all, will it really work? It costs a bit, and it would be a pity if I had to throw it in the corner right now, because it will not work. ; d
  • #4 16522355
    lesławek
    Level 32  
    Help: 190
    Rate: 295
    There is no headphone output there?
  • #6 16522378
    kokapetyl
    Help: 1787
    Rate: 2101
    As the seller specifies it, it is a signal converter (it has its own power supply) and as for me it should work, it is not an adapter (because you can also meet such in "offers")
    As for the quality, I cannot comment, I did not use them.
  • #7 16522384
    Koninaa
    Well, unfortunately, there is nothing else for me to do but order and test it myself. I leave the topic open if someone has already used such a device and wants to comment. ; p
  • #8 17290976
    berolwtyn
    Hello. And how did you deal with this problem? Is this converter working properly? He also wants to connect chinch to tv, and the only audio output is optical ...
  • PLN 120 optical-to-RCA converter works fine
    #9 17290987
    Koninaa
    Hi, everything works fine. I have no idea which converter I bought now, but it cost about PLN 120. I have a little impression that the quality of the bitch is a bit weaker, but these are such tiny details.
    I am actually curious now how these Chinese converters for PLN 20 have worked.
The discussion revolves around connecting a Samsung TV, which only has an optical Toslink output, to an amplifier that accepts Chinch inputs. The user inquires about the functionality and sound quality of an optical to analog converter they found in a store. Responses indicate that the device is a signal converter, not merely an adapter, and should work as intended. However, there are concerns about potential sound quality degradation when converting from digital to analog. The user ultimately decides to test the converter themselves, with one follow-up confirming successful operation but noting a slight decrease in sound quality.
