Connecting headphones to the TV (optical output)
K19oChA94S 34404 17
Can I connect standard headphones to a Samsung TV that only has an optical audio output?
Yes, but not with a simple optical-to-3.5 mm adapter alone: the TV’s optical output is digital, so you need a digital-to-analog converter plus a headphone amplifier to drive regular headphones [#16171424] [#17760110] A plain Toslink transition/adapter is not enough for headphones [#17760110] If you want a direct optical solution, there are wireless headphones designed to connect to optical output, but they are expensive, such as the Sony MDR-DS6500 mentioned in the thread [#16238459]
  • #1 16171352
    K19oChA94S
    Rate: 20
    I have TV Samsung ue43ku6072 and I would like to connect the headphones to the TV but it has only an optical output. And my question is, are there any headphones with such an input and maybe there is an adapter?
  • #2 16171369
    asdqwerty
    Help: 11
    Rate: 67
    If the headphones are standard (3.5mm jack plug) then there are such adapters. Their price varies from several to several dozen zlotys.
  • #3 16171375
    K19oChA94S
    Rate: 20
    Only in this picture, what did you specify where the input is, optical output?
  • #5 16171381
    asdqwerty
    Help: 11
    Rate: 67
    You are interested in this one in the bottom left corner. The optical output is a square-like shape.
  • #6 16171384
    K19oChA94S
    Rate: 20
    But will it certainly convert digital to analog signal?
    Added after 4 [minutes]:
    Any auction on allegro?
  • #7 16171424
    HD-VIDEO
    Help: 1265
    Rate: 1883
    These are optical converters and you can not connect any headphones.
    link
    But you can not connect headphones either, you need the simplest amplifier / headphone amplifier
  • #8 16171447
    K19oChA94S
    Rate: 20
    But I will not connect 3.5 jack to it
  • #9 16171524
    HD-VIDEO
    Help: 1265
    Rate: 1883
    The same with socket 3.5:
    link
  • #10 16172425
    K19oChA94S
    Rate: 20
    So there is no other way to connect headphones to this type of TV?
  • #11 16172438
    Zbigniew 400
    Help: 283
    Rate: 794
    The euro nest is?
  • #12 16173980
    K19oChA94S
    Rate: 20
    Does not have
  • #13 16238459
    Dekalog
    Rate: 8
    I also have this problem. I found such Sony MDR-DS6500 headphones connected to the optical output but the barrier price :(
  • #14 17759105
    alavus11
    I'll step on the subject. I have a TV samsung NU8042 in the optical input, I want to attach a 3.5 mm mini jack to it.
    whether link is it enough to convert the signal or do I need some converter / amplifier?
    or maybe just some sound card on usb with mini jack can be connected to tv?
  • #15 17760110
    HD-VIDEO
    Help: 1265
    Rate: 1883
    You need a converter + amplifier (headphone amplifier); in the link it is just an optical transition Toslink
    The USB card can not be connected to TV
  • #16 17773433
    alavus11
    I found 2 converters here, my question is how different they are and whether they will fit samsung nu8042
    first: link
    second: link much cheaper with the note "PCM onverter does not work with the latest nc + decoders, and some of the latest TVs that have an AC3 / DTS output"
    I understand I have to check what optical output is on tv and what type of sound does it support? But since in this 2 model it is written that it does not handle ac3 (dolby digital or so?) Or dts, what kind of sound will it handle then and what can it be used for? With something older than ac3, dts?
    link
    on the reviewing post I found something like:
    "5.1 Passthrough ARC Dolby Digital
    : Yes
    5.1 Passthrough ARC DTS
    : No.
    5.1. Passthrough Optical Dolby Digital
    : Yes
    5.1 Passthrough Optical DTS
    : No "
  • #17 18349166
    funman
    Rate: 24
    I will follow the topic (and conquer because I do not see that the problem is solved)
    I have a Samsung UE43KU6072U unfortunately, without a mini jack I need to connect the headphones and the TV has an optical and hdmi output.
    Has anyone managed to connect the headphones to the optical output via an adapter?
    Are there headphones for hdmi? (searched but not found)
    Or maybe some of the Dear Forumers have another idea on how to solve this problem ...
    Thank you in advance for your answer :)
  • #18 18349198
    albert505
    Help: 15
    Rate: 30
    Mount the TV input to the mini jack and after trouble.
✨ To connect headphones to a Samsung UE43KU6072 TV, which only has an optical output, users discussed the need for an optical-to-analog converter and a headphone amplifier. Standard headphones with a 3.5mm jack cannot be directly connected to the optical output. Adapters are available, but they require additional amplification to convert the digital signal to analog. Some users mentioned specific headphone models like the Sony MDR-DS6500 that can connect via optical output, but they noted the high cost. The discussion also touched on the possibility of using HDMI outputs and the limitations of certain converters regarding audio formats like AC3 and DTS.
