[Solved] BMW E70 X5 3.0xd - Starter Not Turning: Battery Replaced, Voltage & Current Present
sly_1978 19575 7
  • #1 17000000
    sly_1978
    Help: 34
    Rate: 284
    Hello. BMW E70 X-5 3.0xd, does not spin the starter. The car was off and did not start again. Battery replaced with a new one. Current on the + wire is. Voltage also appears on the starter control cable when START is pressed.
  • #2 17000036
    sk700
    Help: 173
    Rate: 420
    Ask a question because you probably don't want to ask us what to do next if there is power and a signal on the starter? And why haven't you pulled out the starter yet?
  • #3 17000085
    sly_1978
    Help: 34
    Rate: 284
    No, of course, it's already done and under the rectifier turns.
  • #4 17000247
    los_sombreros
    Help: 7
    Rate: 25
    And no reaction, not even a pop?
  • #5 17000277
    sk700
    Help: 173
    Rate: 420
    Did you measure voltages on a connected starter? Maybe one dies under load?
    jurtur
    Help: 26
    Rate: 81
    Connect the extra ground to the engine (starter).
    andrzej20001
    Help: 1578
    Rate: 6669
    Engine weight. The ring has a right side member
  • #8 17002200
    sly_1978
    Help: 34
    Rate: 284
    Yes, exactly on the left side member, but the fact was the reason. Thank you all for your time.
The discussion revolves around a BMW E70 X5 3.0xd that fails to start despite having a new battery installed. The user reports that there is voltage and current present at the starter control cable when the START button is pressed, yet the starter does not engage. Responses suggest checking the starter connections, measuring voltages under load, and adding an extra ground to the engine. The issue was ultimately resolved by addressing a grounding problem on the left side member of the vehicle.
