JBL Flip 4 Bluetooth Speaker Unresponsive: No Power, Charging & Connectivity Solutions
MZgame 8052 4
  • #1 17000204
    MZgame
    Speaker Hello, I bought the JBL Flip 4 Bluetooth speaker about a month ago. Yesterday, when I was listening to music as usual, he turned off. Since then, it does not respond to anything, it can not be turned on. The only way to do this is to connect it to charge. It will turn on, LEDs indicating the battery status will light up, but it will not be able to connect or do anything. It is also vain to connect it by cable, it will not work either. The speaker was used calmly to listen to music while on the road from school and at home. He did not experience water disorder, splashing or even falling.
    PLEASE HELP!
    thank you in advance! [/ b]
  • #2 17000364
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    What battery status was shown on the LEDs? Turning off the speaker indicates that the battery has been excessively discharged, you must connect the charger for a few hours to bring the battery back to life. When the attempt to charge fails it will remain to return to the store.
  • #3 17000531
    MZgame
    4/5 diodes As I said, he turned himself out of nothing
  • #4 17000764
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    Due to the fact that the loudspeaker is under warranty, I advise you to return it to the seller or service. The speaker was bought in the store and has a warranty?
  • #5 17004398
    MZgame
    Yes it is, I sent it to the site yesterday.
