[Solved] Troubleshooting JBL Flip 4 Speaker: Won't Turn On, Accidental Hourglass Button Press
Rompcaaaa 27171 16
How can I reset a JBL Flip 4 that won’t turn on after accidentally pressing the Connect button, especially if it only works when plugged in?
Hold the Power button for about 30 seconds to try a reset [#17899028] If that does not work, plug in the charger and hold Connect + and Volume + at the same time [#17899175] That combination was reported to resolve the problem after the other reset attempts failed [#17899175]
  • #1 17898852
    Rompcaaaa
    Rate: 22
    Hello, I have a problem because yesterday I was listening to music and I wanted to turn off the loudspeaker and accidentally held the hourglass button and the speaker turned off and since then it won't turn on, I tried to turn it on and connected nothing to charging and it landed normally, I also connected via jack cables and played and when I unplugged the charger, it stopped playing, I need help because the loudspeaker cannot be turned on
  • #2 17898937
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Rompcaaaa wrote:
    I was holding the hourglass button by accident
    Do you mean the Connect + button?
  • #3 17898940
    Rompcaaaa
    Rate: 22
    That's about connect
  • #4 17899028
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Press and hold the Power button for approximately 30 seconds.
  • #5 17899038
    Rompcaaaa
    Rate: 22
    It does not work for me
  • #6 17899056
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And somehow does it react to the combination of Play and Volume + buttons?
  • #7 17899059
    Rompcaaaa
    Rate: 22
    Play is this a triangle?
    It does not respond, but when I connect it to charging it is like a sound like this
  • #8 17899066
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Yes, that's exactly what this triangle is about.
  • #9 17899068
    Rompcaaaa
    Rate: 22
    Well, nothing works like I do
    But when I connect to charging and click and hold the power, the speaker turns off
  • #10 17899117
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    So under the charger it starts normally and works properly?
  • #11 17899120
    Rompcaaaa
    Rate: 22
    The charger turns on as if there is even this sound, only there is an error with bluetooth connection, you can only listen to music via the jack cable then
  • #12 17899123
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And did you try to hit the same combination you beat him? So Power and Connect +?
    Did you press these previous combinations with the charger disconnected or with the charger connected?
  • #13 17899126
    Rompcaaaa
    Rate: 22
    I do not know, but I pressed them with the charger disconnected, as it happened
    It only turns off when I press it on the charger
  • #14 17899141
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Pressing Power for approximately 30 seconds should reset it. Did you press it with or without the charger plugged in?
  • #15 17899157
    Rompcaaaa
    Rate: 22
    Yes and so I checked
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    The last combination I can think of is: Plug in the power and hold down Connect + and Volume +.
  • #17 17899178
    Rompcaaaa
    Rate: 22
    Ok, I plug it in and do it
    Thank you, you actaaaa is a champion
The discussion revolves around troubleshooting a JBL Flip 4 speaker that won't turn on after an accidental press of the hourglass button. The user reports that the speaker does not respond to the power button or other combinations, although it emits a sound when connected to a charger. Various suggestions are made, including holding the Power button for 30 seconds, trying combinations of the Play and Volume + buttons, and pressing Connect + while plugged in. The user confirms that the speaker only turns off when the power button is pressed while charging, and ultimately finds success with the suggested combination of holding Connect + and Volume + while plugged in.
TL;DR: JBL Flip 4 won’t turn on after a Connect+ (hourglass) mishap? Use a 30‑second soft reset. "Pressing Power for approximately 30 seconds should reset it." This FAQ shows how to fix no‑power, pairing errors, and AUX‑only symptoms. [Elektroda, Vytautas_YT, post #17899141]
Why it matters: Fast, proven resets can save time and avoid unnecessary battery replacements or support tickets.
  • Soft reset: Hold the Power button for approximately 30 seconds to reset the speaker. [Elektroda, Vytautas_YT, post #17899141]
  • Recovery combo: With the charger plugged in, hold Connect+ and Volume+ to revive an unresponsive Flip 4. [Elektroda, Vytautas_YT, post #17899175]
  • JBL Connect+: Link up to 100 compatible speakers for synchronized playback. ["What is JBL Connect+?"]
  • Flip 4 spec highlights: up to 12 hours playtime (3000 mAh Li‑ion), IPX7 water‑proof. ["JBL Flip 4 – Portable Bluetooth Speaker"]
  • Lithium‑ion packs use protection circuits that cut power at low voltage; devices may only run while charging until reset or recharge. ["BU‑304: Battery Protection"]
Why won’t my JBL Flip 4 turn on after I pressed the hourglass/Connect+ button?
Connect+ links speakers and does not control power. After accidental long presses, the speaker can freeze and ignore inputs. Do a soft reset by holding the Power button for about 30 seconds, then release. Try again on battery and with the charger connected. This restores normal button handling. [Elektroda, Vytautas_YT, post #17899141]
How do I soft‑reset a JBL Flip 4 that’s unresponsive?
Press and hold Power for about 30 seconds until the unit resets. Release and wait a few seconds. Turn it on normally. As one helper put it, "Pressing Power for approximately 30 seconds should reset it." If the battery is low, connect a charger first. [Elektroda, Vytautas_YT, post #17899141]
What should I try if the 30‑second hold doesn’t work?
Use the recovery combo while charging. "Plug in the power and hold down Connect+ and Volume+." How‑To:
  1. Plug the speaker into a charger.
  2. Press and hold Connect+ and Volume+ together.
  3. Release, then power on and test Bluetooth and AUX. [Elektroda, Vytautas_YT, post #17899175]
Did the Connect+ + Volume+ method actually fix the OP’s speaker?
Yes. The OP tried the combo while on the charger and reported success a minute later. That confirmed the recovery method worked in this case. [Elektroda, Rompcaaaa, post #17899178]
The speaker chimes when charging but ignores buttons. What should I do first?
The charge chime indicates external power is present, but the interface may be frozen. Force a soft reset by holding the Power button for roughly 30 seconds, then try powering on again. This clears a stuck state after accidental button holds. [Elektroda, Vytautas_YT, post #17899141]
Why does my Flip 4 play over AUX when charging, then stop when unplugged, and Bluetooth fails?
That pattern points to a failing or disconnected battery. The speaker can run from USB power long enough for AUX, then shuts off when power is removed. Bluetooth pairing can also fail under low battery conditions. Replace the battery after you attempt resets. ["JBL Flip 4 Troubleshooting"]
What exactly does the Connect+ (hourglass) button do?
Connect+ wirelessly links compatible JBL speakers for synchronized audio. It does not control power. Press Connect+ on each speaker to join a group. Connect+ supports linking up to 100 compatible speakers. ["What is JBL Connect+?"]
Do I need the charger connected to run the recovery combo?
Yes. Perform the combo only while the speaker is on external power. The instruction was, "Plug in the power and hold down Connect+ and Volume+." This helped recover the non‑starting speaker. [Elektroda, Vytautas_YT, post #17899175]
Does the Play + Volume+ button combo reset a Flip 4?
Not here. The user pressed Play (triangle) plus Volume+, and the speaker did not respond at all. That combo did not fix this case. [Elektroda, Rompcaaaa, post #17899059]
Which specs matter for power‑related troubleshooting on Flip 4?
Expect up to 12 hours of playtime from a 3000 mAh Li‑ion battery. The unit is IPX7 water‑proof. After heavy use or aging, available runtime can drop. Fully charge before testing resets, then verify Bluetooth pairing. ["JBL Flip 4 – Portable Bluetooth Speaker"]
Edge case: Can a tripped battery protection circuit block power‑on even after resets?
Yes. Lithium‑ion packs include protection that cuts output on deep discharge or faults. The device may only run while charging until the pack is safely precharged, or the battery is replaced. This can look like a hard failure. ["BU‑304: Battery Protection"]
What if none of the button resets work on my Flip 4?
If soft reset and the Connect+ + Volume+ recovery fail, suspect a weak battery or hardware fault. Back up purchase details and contact JBL/Harman support for warranty options. Out‑of‑warranty units may need a battery replacement or service. ["Harman Warranty Information"]
