PlayStation 4 Connection Issue: Samsung LCD LE32A330J1N, HDMI Cables, and Console Compatibility
aanneekk 5829 9
Why won't a PlayStation 4 show an image on a Samsung LCD LE32A330J1N over HDMI, even after trying another cable and checking that other HDMI devices work?
The most likely cause is that this old Samsung TV is incompatible with the console’s HDMI/HDCP handshake, so it does not recognize the newer console [#16298610][#16506616] A lower output resolution was suggested, and the console was set to 480 on a FullHD TV, but the PS4 still did not display on the LE32A330J1N [#16285228][#16285357][#16288989] Since other HDMI devices such as a Polsat decoder work on the TV, the HDMI input itself is fine and the problem appears specific to the console-TV compatibility [#16290013][#16291313]
  • #1 16285081
    aanneekk
    Rate: 63
    Problem with connecting the console to the TV (Samsung LCD LE32A330J1N).
    I connected with HDMI cable, but it doesn't work. Is it a TV thing that is already old?
    I changed the cable to a different one. I connected the set-top box and the TV works, but with the console connected, it doesn't.
    Please help
  • #2 16285228
    sosarek
    Help: 9321
    Rate: 15545
    Change the resolution on the console output and you will have the image on the TV.
    Z
    Pka, Poznań, 60-850
  • #3 16285325
    aanneekk
    Rate: 63
    Thanks for the reply.
    Please provide details on how to do this.
  • #4 16285357
    sosarek
    Help: 9321
    Rate: 15545
    Connect to a TV that supports FullHD resolution and change to a smaller one.
    It was possible to reset the settings on the PS3 - check the manual, maybe there is also an option here.
    Z
    Pka, Poznań, 60-850
  • #5 16288989
    aanneekk
    Rate: 63
    I connected to FullHD TV and changed the resolution to 480, then connected to the target Samsung LCD TV LE32A330J1 and unfortunately it still does not work. Can someone, something any idea?
    Thanks
  • #7 16291313
    aanneekk
    Rate: 63
    Yes. For example, Polsat decoder.
  • #8 16291331
  • #9 16298610
    KOCUREK1970
    Help: 3867
    Rate: 5500
    @aanneekk
    You may not see anything - a different version of HDCP security in the console (newer version) and another in tv (older version).
  • #10 16506616
    aanneekk
    Rate: 63
    Niesety managed to establish that the TV as a scary model does not see the new console and this is the reason.
The discussion revolves around a connection issue between a PlayStation 4 console and a Samsung LCD TV model LE32A330J1N using HDMI cables. The user reports that while other devices, such as a Polsat decoder, connect successfully, the console does not display any image. Suggestions include changing the console's output resolution, with advice to try lower settings, and troubleshooting steps like disconnecting the console from power while holding the switch. A potential compatibility issue is noted, indicating that the older TV model may not support the newer HDCP version used by the console.
