[Solved] What is Allow 9009 on Firewall? Virus or Port Issue? Win10 Pro, TCP Port 9009, Pichat Service
moher40 32847 5
  • #1 17005187
    moher40
    Rate: 27
    I have exactly the same problem:
    https://www.bleepingcomputer.com/forums/t/642063/keep-seeing-something-hosted-on-port-9009/
    and followed the instructions therein. It didn't do anything.
    Commonly in the firewall I have an attempt to output something called ALLOW and it connects only to TCP port 9009. I have no clue what it is. Win10 Pro (ori) system and zero installed goodies.
    I got in here:
    http://www.ipfingerprints.com/portscan.php
    and I have this result:
    Note: Host seems down. If it is really up, but blocking our ping probes, try "Don't Ping" in advance mode.
    Host is up!
    PORT STATE SERVICE
    9009/tcp filtered pichat
    9009/udp open|filtered pichat
    TCPview only shows this:
  • #2 17005235
    dt1
    Admin of Computers group
    Help: 7300
    Rate: 8260
    Hello. Run the command line as administrator and enter the command:
    netstat -n -a -b
    It should display all listening processes and connections established at the moment. See if you can identify a process that is listening on port 9009.
    Do a FRST scan: https://www.bleepingcomputer.com/download/farbar-recovery-scan-tool/ - don't change any parameters. Upload both generated logs (FRST and Addition text files) as attachments.
  • #3 17005386
    moher40
    Rate: 27
    In cmd it doesn't show anything. Everything is ok there. There is no 9009 Allow listener and the rest is from Firefox and from the system.
    • FRST.txt (151.75 KB) You must be logged in to download this attachment.
    • Addition.txt (31.65 KB) You must be logged in to download this attachment.
  • #4 17006440
    dt1
    Help: 7300
    Rate: 8260
    I guess a bunch of (from my perspective) redundant LED control software might be using port 9009 for communication. RGB Fusion has a smartphone app that communicates over this port, so I wouldn't be surprised if the software took care to keep it open.
  • #5 17006976
    moher40
    Rate: 27
    I put a clean system straight from M$. Te Allow is from Microsoft. I put a clean W10, depriving it only of telemetry, defender, antimalware and a few other reptiles. I put in a firewall and it still pops up connecting to port 9009.
    So I blocked this port in the firewall in UDP and TCP and we'll see what it does.
  • #6 17012699
    moher40
    Rate: 27
    It turned out to be a service related to the so-called. GCloud is some garbage from Gigabyte packed in APP-Center. I got rid of it and nothing similar to Allow 9009 speaks anymore. It's ok.
