[Solved] ETS2 Program Stopped Working on Windows 7 Pro SP1-64 Bit | 4x3.2 GHz CPU, 4GB RAM: Fixes Tried
zezuz 10722 7
  • #1 17005394
    zezuz
    Hello!
    I have a problem running Euro Truck Simulator 2 (on Steam).
    I have a new computer and I don't know what may be wrong with it.
    Equipment:
    Windows 7 Professional SP1-64 Bit
    4 x 3.2 GHz processor
    Ram - 4GB
    What have I already done?
    1. I've set boot to 64 Bit.
    2. I installed Adobe Flash Player and Directx 11
    3. I tried to change the screen resolution
    4. I reduced RAM consumption
    5. I turned off the firewall.
    6. I installed the missing Directx bookcases (Unless they busted me with the program)
    PS. In the attachment I add a log from the game, maybe you'll find something there.
    • game.log.txt (12.13 KB) You must be logged in to download this attachment.
  • #2 17005404
    Kasek21
    Help: 4981
    Rate: 3548
    What monitor? What resolution is set in the system / game?
    Added after 54 [seconds]:
    What monitor? What graphics card? What resolution is set in the system / game?
  • #3 17005458
    zezuz
    1280 x 1024
    Standard VGA graphics card
    Monitor: SyncMaster 743N / 743NX, SyncMaster Magic CX743N
  • #4 17005496
    Kasek21
    Help: 4981
    Rate: 3548
    Show screen from Device Manager.
    What is the comp. k.graficzna?
  • #5 17005520
    zezuz
    Please, you can see everything. Maybe you can check the graphics card differently? Eg via CMD?
    PS Could this mean that there is no graphics card? I would be a bit surprised, but I can't find a card anywhere and shoot after all the drivers is a bit of a joke.
    • ETS2 Program Stopped Working on Windows 7 Pro SP1-64 Bit | 4x3.2 GHz CPU, 4GB RAM: Fixes Tried mz.png (47.44 KB) You must be logged in to download this attachment.
  • #7 17005565
    zezuz
    Is this something like that?
    PCI \ VEN_1002 & DEV_9904 & SUBSYS_78001462 & REV_00
    PCI \ VEN_1002 & DEV_9904 & CC_030000
    I checked it and found it AMD Radeon HD 7560D. Now I'm downloading the driver and checking if there are any problems. To tell you the truth I didn't know that you can check the hardware and maybe the problem is a bad / missing driver.
    PS I have already installed the drivers but ETS2 still won't start. There is still a "program stopped working"
    The patch after restarting everything is flashing as it should.
The user is experiencing issues with Euro Truck Simulator 2 (ETS2) on a new computer running Windows 7 Professional SP1-64 Bit, equipped with a 4 x 3.2 GHz CPU and 4GB RAM. Despite various troubleshooting steps, including setting the boot to 64 Bit, installing Adobe Flash Player and DirectX 11, adjusting screen resolution, reducing RAM consumption, disabling the firewall, and installing missing DirectX components, the game continues to crash with a "program stopped working" error. The user has a Standard VGA graphics card and a SyncMaster 743N monitor set to a resolution of 1280 x 1024. Further investigation revealed the graphics card to be an AMD Radeon HD 7560D, and the user is in the process of downloading the appropriate drivers to resolve the issue.
