The light switch does not work - the light cannot be turned off
PRZEmeG1997 13974 6
  • #1 17007592
    PRZEmeG1997
    Good morning,
    Some time ago (about 2 weeks) after turning on the light in the room with the switch the following situation happened, the bulb flashed and damaged, breaking traffic jams throughout the apartment. By damage to the light bulb, I mean that the wires inside fell off (broke?). After switching on the plugs and replacing the bulb with a completely new one, the following problem arose, the light can not be turned off - only by unscrewing the bulb, the switch does not work (regardless of its position, the light is on). I will add that in other rooms everything works completely normal and only in this one room something broke.
    At this point I would like to ask what could have happened and is it difficult to rectify such a defect? I would avoid calling an electrician unless necessary, thank you in advance for all your answers and help, best regards :)
    spinacz
    Help: 1204
    Rate: 2654
    Maybe it is enough to replace the switch, or maybe something happened in the box with connections.
  • #3 17007609
    Qbuś
    Help: 380
    Rate: 876
    It is necessary to replace the switch with a new one, the contacts are probably stuck together.
  • #4 17007616
    PRZEmeG1997
    Thank you for the tips, I will try to comprehend it and I hope it will solve the problem ;)
    Qbuś
    Help: 380
    Rate: 876
    Remember not to change anything under voltage!
    The fuse responsible for this circuit must be turned off!
  • #6 17007648
    PRZEmeG1997
    Of course! I will consult with the owner and the seller in the electrical store ;)
  • #7 17008049
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    PRZEmeG1997 wrote:
    the light bulb flashed and damaged, breaking traffic jams throughout the apartment.
    This is for electricians, not for amateurs.
    Ps. I close it and move it to a more suitable place.
The user reported a malfunctioning light switch that prevents the light from being turned off, following an incident where a bulb flashed and caused circuit breakers to trip. Responses suggest that the issue may stem from a faulty switch or stuck contacts, and recommend replacing the switch. Safety precautions were emphasized, advising to turn off the circuit fuse before attempting any repairs. Some responses indicated that the problem might require professional assistance, while others encouraged the user to seek advice from an electrical store.
