What motherboard for the AMD X8 FX-8350 4.0GHz AM3 + processor?
OnWave 3567 9
What motherboard should I buy for an AMD FX-8350 system with a GTX 1050 Ti and 8 GB of DDR3 RAM, and what else would I need to make it work well?
The thread’s main advice is not to buy an AM3+ motherboard for the FX-8350, but to move to a newer platform such as Intel 1151 or Ryzen, because it gives better value and performance [#16706051] [#16706106] [#16705968] For around PLN 1000, suggested Intel options were a Core i5-7400 with an MSI B250M PRO-VDH or Gigabyte B250M-DS3H, or a cheaper Pentium G4560/G4600 if you will not go beyond the GTX 1050 Ti [#16706051] [#16706106] If you go to one of these newer boards, you must use DDR4 RAM; DDR3 will not fit on a DDR4 motherboard [#16706018] [#16706106] The replies also note that the power supply model matters more than just its 550 W rating, and a no-name unit may need replacing [#16705921] [#16706051] One reply also warns that the FX-8350 would likely require extra cooling for its 125 W heat output, adding more cost [#16706106]
  • #1 16705899
    OnWave
    Unfortunately, my desktop computer is already old and I would like to mention a few things (actually all) in it.
    I noticed:
    - AMD X8 FX-8350 4.0GHz AM3 + processor,
    - Gigabyte GeForce GTX 1050 Ti OC 4GB GDDR5 128Bit graphics card
    - I have 8GB RAM DDR3
    The question is, what motherboard would best fit these components?
    Preferably up to PLN 500.
    For now, the only things that caught my eye are: ASUS 970 PRO GAMING AURA, Socket AM3 +
    And possibly what else would be needed to make everything work well?
    I have a 550WAT power supply so I will not change it.
    best regards
  • #2 16705921
    badboy84
    Help: 1197
    Rate: 1486
    What kind of power supply is it? The fact that it has 550W is less important than its company and model ... If the hardware is to be used for gaming, think about Intel.
  • #3 16705959
    OnWave
    I do not remember the power supply company.
    It's just that Intel similar to AMD is much more expensive
  • #4 16705968
    kred
    Help: 30
    Rate: 18
    Do not go into old bulldozers. With AMD, I recommend Ryzen 5 1600 + MSI B350 PC MATE + some 8GB DDR4 2667 / CL15.
  • #5 16705977
    OnWave
    Unfortunately, the price is once again a problem: / In addition, Intel with similar parameters is much more expensive
    So I understand that a graphics card is a good choice :D
    Just suggest what motherboard would be worth attention to this set.
    And the question is, if the motherboard supports DDR4 ram bones, will it also be possible to plug in DDR3 bones?
  • #6 16706018
    Kasek21
    Help: 4981
    Rate: 3547
    No!
  • #7 16706028
    OnWave
    Ok, what do you recommend the motherboard + processor package up to PLN 1000?
  • #8 16706051
    badboy84
    Help: 1197
    Rate: 1486
    In this amount you can look for Core i5 on socket 1151, i.e. Sky / KabyLake with a board and DDR4 memory. Do not pack in old stuff, if you add about PLN 250, you have a new set, for example http://allegro.pl/asus-b250m-a-intel-i5-7400-3ghz-crucial-ddr4-8gb-i6943243147.html How to put it together yourself maybe you'll break something. The power supply is still unknown, and this is quite an important element. If it's some no name, you still have a power supply to replace and you need about PLN 160.
    On the other hand, if you do not measure above this GTX 1050Ti, the Pentium G4560 / 4600 should be enough and then you can fit the processor, motherboard and memory in PLN 800-900.
  • #9 16706083
    OnWave
    Thanks for the specific answer, I will check how it looks. these processors are a bit scary with the price
  • #10 16706106
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Intel does not come out more expensive, taking into account that up to the five-year FX you can start with a Pentium G4600 costing PLN 300 in most applications. Let's not forget that for the FX8xxx you will also have to buy cooling, and to dissipate 125W of heat it will cost a minimum of PLN 100. In addition, when you buy FX, you will have equipment that will be able to handle all the threads computationally, but in ordinary applications (games, multimedia) - unfortunately it will get whips from the i3 or sometimes also the Pentiums from current generations.
    For PLN 1000 you can buy the MSI B250M PRO-VDH or Gigabyte B250M-DS3H board and the I5-7400.
    You will have to replace DDR3 RAM with DDR4, but 8GB DDR3 can still be sold.
The discussion revolves around selecting a suitable motherboard for the AMD X8 FX-8350 4.0GHz AM3+ processor, alongside a Gigabyte GeForce GTX 1050 Ti OC 4GB GDDR5 graphics card and 8GB DDR3 RAM. The user is considering the ASUS 970 PRO GAMING AURA motherboard but is open to other recommendations within a budget of PLN 500. Responses suggest that while the FX-8350 is an older model, alternatives like Intel's Core i5 with a B250 motherboard are recommended for better performance, especially for gaming. It is clarified that DDR4 motherboards do not support DDR3 RAM. The conversation also highlights the importance of a reliable power supply and suggests that upgrading to a newer platform may be more cost-effective in the long run.
