Flooded Huawei P9 lite, Is there still a chance for repair and is it worth it?
dreamcometrue 2976 2
  • #1 17196923
    dreamcometrue
    Hi! A month ago, I flooded the HUAWEI P9 LITE phone in the water for 10 seconds, it was in rice for a month. When it charges, everything reacts, when notifications come, it vibrates and the LED flashes. However, when I want to unlock the phone, it turns on only for 3 seconds, then writes there in the notifications "restart is required" and immediately the screen goes out, and the navy blue LED has started flashing all the time. What should I do and is there a chance for coal?
  • #2 17197999
    br501
    Help: 14
    Rate: 56
    The sooner you return your phone to the service, the greater the chances of it being successful. Is it worth it? They will tell you on the site.
  • #3 17201227
    blade1231
    Help: 8
    Rate: 31
    After a month of flooding, the chances of repair are no longer changing. What was supposed to corrode has long since corroded. Now the disc has to go to the washer for cleaning and no one knows whether it will work properly or not.
