Title: Best Vacuum Cleaner for Gypsum Dust: Giraffe Grinder, Starmix 1425, 1435, Shaker & Bags
bartek158 30960 8
  • #1 17017673
    bartek158
    Rate: 26
    I need to buy a vacuum cleaner for a gispu grinder giraffes. I was thinking about STARMIX 1425 with shaker. In this model, to use the shaker, the vacuum cleaner must be switched off and work stopped. I met in various opinions, on the starmix hotline, they say that the filter usually clogs after 1-2 minutes and a more expensive model (1435) is intended for plaster grinding. I also got acquainted with the opinion that when sanding gypsum filters rarely in this model are clogging so it is not a problem as once every 15-20 minutes will break for a moment of work. In the rental of equipment they recommend the use of bags and turn off this shaking because it breaks the bags. Can someone say who works on this type of device? How often do you have to stop working in vacuum cleaners with semi-automatic shaking? What would you recommend? The price is max 2300 but I would rather spend less.
  • #2 17019253
    Piasek80
    Help: 129
    Rate: 666
    https://www.narzedzia.pl/odkurzacz-dewalt-dwv902l,42994.html
    Unfortunately, in the bagless mode of work and the trash like gypsum dust, there will be similar difficulties with each one.
    The dust should, however, be the bag, for example, just the very convenience of emptying it: it is easier to detach and discard a bag with contents than empty an open container with gypsum dust.
  • #3 17019401
    bartek158
    Rate: 26
    Thank you for the answer if this vacuum cleaner for DeWalt stops working? Because from what I read, cleaning the filter turns on every 15 seconds only nothing was written whether the vacuum cleaner can work in continuous mode or on time the filter cleaning stops
  • #4 17168282
    RafZielak
    Rate: 24
    I have and regularly use the Starmix ARDL 1435 vacuum cleaner and I have not found so far even the smallest problems with the work either when lapping gypsums (dust / gypsum dust) or with a chisel (cutting grooves in any walls) or wood oscillation grinders (dust / wooden dust).
    The mechanism of shaking the filters is loud, very loud but also very effective. Filter cleaning / shaking is activated depending on the suction power drop, sometimes every 5 seconds, sometimes every 5 minutes.
    I used the bag only once, the first one, delivered with the kit and I find that it does not make sense, it is not needed.
    RafTec
    Prezydenta Ryszarda Kaczorowskiego 12, Sochaczew, 96-500
  • #5 17532846
    Potyczko
    I recommend Bosch GAS 35, it costs a bit, but you will be satisfied, you will forget about bags, filters or replacing the vacuum cleaner for years.
    I've had it for five years and use it for everything in construction, plaster, sawdust, rubble, etc.
    I have never mounted any bag to it, the vacuum cleaner just shakes off the dust by itself, when it is full, when it gets really heavy, you empty the vacuum cleaner. Sometimes I clean the filter when emptying the vacuum cleaner.
    The self-cleaning system does not interrupt the suction, so you work without interruption.
    Decent ends, long suction hose, excellent equipment for heavy tasks, does not regret a single zloty for this tank!
  • #6 17555175
    bartek158
    Rate: 26
    I bought a Starmix and it is enough to work with a furrow and gypsum. So far it works without problems.
  • #7 19019819
    nygys019
    Rate: 19
    bartek158 wrote:
    I bought a Starmix and it is enough to work with the wall chaser and plaster. So far it works without problems.
    And how does it work after this period? I am also faced with this choice and I wonder whether to pay extra for 1635 iPulse or 1625 is enough for plaster6
  • Clarifying budget vacuum for giraffe and wall chaser
    #8 20563550
    sylwekAIR90
    I would like to warm up the topic a bit because since then some products from the PRC have hit our market. I am looking for a vacuum cleaner that can work with a giraffe and a wall chaser. I’m going to be renovating the whole house and just for this occasion I need some cheap solution that won’t clog every 1-2 minutes. I will add that I have a cyclone separator prepared for the vacuum cleaner to relieve it a bit.
    Can you recommend a vacuum cleaner for PLN 400-500?
    Regards
    New Year’s Eve
  • #9 20564609
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    sylwekAIR90 wrote:
    I'm going to be renovating the whole house and just for this occasion I need some cheap solution that won't clog every 1-2 minutes
    In this case, I recommend a power tool rental.
The discussion revolves around selecting the best vacuum cleaner for handling gypsum dust, particularly in conjunction with tools like the Giraffe grinder. Users express concerns about filter clogging, especially with the Starmix models 1425 and 1435. The Starmix 1435 is noted for its effective filter shaking mechanism, which can activate based on suction power drop, while the 1425 model requires the vacuum to be turned off for filter cleaning. Recommendations include the Bosch GAS 35, praised for its self-cleaning feature and durability, allowing continuous operation without interruptions. Users also mention the importance of using bags for easier disposal of gypsum dust and suggest considering rental options for budget-friendly solutions.
