[Solved] Bosch WAS 28743 PL / 01 washing machine - error F57 engine does not work
artursosinski 19263 13
Why does a Bosch WAS 28743 washing machine show F57, stop the drum, and only open the door in emergency mode?
F57 points to a fault in the motor inverter/module, not a normal brushed-motor problem [#17023389][#17869529] The motor in this model is brushless and has 3 connectors, so it is driven by a 3-phase inverter and should not be powered directly [#17023250][#17027442] Check the inverter module for failed or cold solder joints on the large components, and if the module is damaged, replace it [#17024717][#17869529]
  • F57 points to motor circuit fault
    #1 17022328
    artursosinski
    Rate: 10
    I have a problem with the washing machine as in the topic. During washing, probably right at the very end, because the laundry was rinsed, the F57 code was displayed and the sound signal was displayed, the drum stopped and the door could not be opened in a normal way, but it was possible in an emergency. Now the washing machine behaves identically on each program after closing the door, the lock works properly, it locks and then the water pump starts and the alarm signal with the F57 code is activated. Opening the door works only in emergency.
    I read that this code could mean damage to the motor circuit. Can the engine be checked somehow? I removed the engine module and after careful inspection, no damage is visible, the connections of the connectors are also ok. Attached are photos of the module with the removed heat sink. I am asking for any suggestions. Thank you in advance
    Bosch WAS 28743 PL / 01 washing machine - error F57 engine does not work Bosch WAS 28743 PL / 01 washing machine - error F57 engine does not work
  • #2 17023048
    magir
    Help: 128
    Rate: 379
    Remove and check the engine.
  • #3 17023090
    artursosinski
    Rate: 10
    Ok. How to do it yourself?
  • #4 17023104
    magir
    Help: 128
    Rate: 379
    Remove the motor from the washing machine and check:
    - whether the brushes are too short and whether the lice are no longer going on the commutator
    - if the bearings do not have any noticeable play (rather there should not be any
    - whether the winding of the speed and direction of rotation sensor is open
    Aj! He's actually cracking me off! This is not a commutator motor, I should notice it after the outputs from the driver.
  • #5 17023179
    wiesiekmisiek
    Help: 259
    Rate: 524
    Oh, I think this motor has no brushes, but maybe I'm wrong.
  • #6 17023250
    artursosinski
    Rate: 10
    Exactly the motor is brushless and has 3 connectors.
  • #7 17023308
    wiesiekmisiek
    Help: 259
    Rate: 524
    then the water pump starts up and the alarm signal with the F57 code
    Maybe here is the answer, check the dirty water drain pump not only for blockage but also for the continuity of the winding, or you can give it a direct power supply from the outside. By the way, also check with a multimeter what it shows on these three motor connectors in different configurations, you may have to try to give it power directly. With the module on the table, check also if the relay contacts are not shorted.
    Moderated By mrhari:
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #8 17023355
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    wiesiekmisiek - man you don't know, don't advise stupid things. This motor is controlled by the inverter and there is probably a problem in it
  • #9 17023389
    magir
    Help: 128
    Rate: 379
    Well, I was able to find - unfortunately the F57 error is a failure of the inverter.
    h jaworski
    Help: 466
    Rate: 717
    After all, on these legs of a large system, like a bull, you can see a cold February soldering system and it may work.
  • #11 17024968
    magir
    Help: 128
    Rate: 379
    I have a request for the owner of the washing machine - can you please post some photos of the washing machine's motor here?
  • #13 17027442
    cezet
    Help: 719
    Rate: 1407
    Buddy - don't mislead people! You don't even know what you're writing about. This motor is powered by 3 phases from the inverter module and each "giving it power" will only end badly for the author of the topic!
    There is a specific answer here and the author should do so.
  • #14 17869529
    artursosinski
    Rate: 10
    Washing machine motor module damaged, replace with a new one.
The Bosch WAS 28743 PL / 01 washing machine is experiencing an F57 error code, indicating a potential issue with the motor or inverter. The user reports that the drum stops during the wash cycle, and the door can only be opened in an emergency. Responses suggest checking the motor for brush wear, bearing play, and winding continuity, although it is confirmed that the motor is brushless. The water pump should also be inspected for blockages and continuity. Ultimately, the consensus is that the F57 error likely points to a failure in the inverter module, which may need replacement.
TL;DR: If your Bosch WAS28743PL/01 shows F57, focus on the 3‑phase drive — "This motor is powered by 3 phases from the inverter module." Avoid direct mains tests; inspect or service the inverter board. [Elektroda, cezet, post #17027442]
Why it matters: For Bosch WAS28743PL/01 owners/DIYers with F57, this steers diagnosis to the right module and prevents damage.
What does error F57 mean on a Bosch WAS28743PL/01?
F57 flags an inverter failure. The control inverter that drives the motor is the primary suspect. As one expert put it, "F57 error is a failure of the inverter." Plan diagnostics or replacement around that board, not the pump or mechanics. [Elektroda, magir, post #17023389]
What symptoms will I see when F57 triggers?
After you close the door, the lock engages, the drain pump starts, then the alarm sounds and F57 appears. The door won’t open normally; use the emergency release to retrieve laundry. This behavior repeats on every program until the fault is resolved. [Elektroda, artursosinski, post #17022328]
Does this model use a brushless motor?
Yes. It’s a brushless motor with 3 connectors. That means there are 0 brushes to wear or replace, and diagnostics center on the inverter drive and wiring. "Exactly the motor is brushless and has 3 connectors." [Elektroda, artursosinski, post #17023250]
Can I power the motor directly to test it?
No. "This motor is powered by 3 phases from the inverter module" and is not designed for direct mains. Applying line voltage to the three pins risks damaging the inverter, the motor, or both, and creates a shock hazard. Use board-level diagnostics instead. [Elektroda, cezet, post #17027442]
How do I inspect the inverter for cold solder joints?
Three-step check: 1) Unplug washer and remove the motor/inverter module. 2) Under good light, inspect the main IC legs for dull or cracked joints. 3) Reflow suspicious legs carefully and retest. Cold joints on that IC are visible and a rework "may work." [Elektroda, h jaworski, post #17024717]
What ultimately fixed the F57 in this thread?
The motor module (inverter) was defective. Replacing the motor module resolved the F57 and restored operation. This was the confirmed outcome reported by the original poster after troubleshooting and inspection. [Elektroda, artursosinski, post #17869529]
Should I check the drain pump when I get F57?
Focus on the inverter. F57 specifically denotes an inverter failure, so clearing a pump blockage will not resolve this code. Direct your time to inspecting, reworking, or replacing the inverter/motor module instead of the drain circuit. [Elektroda, magir, post #17023389]
Do I need to inspect motor brushes or a commutator?
No. This washer uses a brushless drive, so there are no brushes or commutator to inspect. Diagnostic effort belongs on the inverter electronics and connections to the 3‑pin motor. That removes a common wear item from the checklist. [Elektroda, artursosinski, post #17023250]
What happens if I try to run the motor straight from the wall?
It is an edge-case failure path: "each giving it power will only end badly." The inverter and motor can be destroyed by inappropriate mains tests. Use the inverter to drive the motor or bench-test the board with proper equipment only. [Elektroda, cezet, post #17027442]
Is the motor sold as a complete unit for this washer?
Yes, the drive motor is available as a dedicated part for the Bosch WAS28743PL/01. That listing confirms model compatibility if you choose to replace the motor or verify its specifications before inverter work. [Elektroda, wiesiekmisiek, post #17027411]
How can I open the door after F57 to get my clothes?
Use the emergency door release. With F57 present, the door lock does not release normally after the alarm. The emergency method allows you to retrieve laundry while you plan inverter diagnostics or replacement. [Elektroda, artursosinski, post #17022328]
Where should I focus if I already checked brushes, bearings, or a tacho?
Concentrate on the inverter. The motor in this model is inverter‑controlled, so legacy checks for brushes or commutator faults do not apply. The fault source lies in the inverter electronics or its connections. [Elektroda, zibi1971, post #17023355]
