Torrent client - what's the best without errors when downloading and configu
9879 18
Which torrent client is simple, reliable, and least troublesome to configure and use for downloading?
Qbittorrent is the most recommended choice here for a simple, reliable torrent client that did not cause problems for the responder, and a portable version is available if you want to avoid installing it into the system [#17025139][#17025222][#17026511][#17043185] Download the portable build, extract it to its own folder, and delete that folder if you no longer want the program; the built-in search may ask you to install Python [#17026511] Transmission is also presented as a good alternative with a web GUI, mobile apps, and remote control support, but one user noted Windows issues with very large torrents above 100GB [#17055462][#17072454][#17073449] Vuze was mentioned as working properly and being light, but another user preferred qBittorrent over it because of ads [#17043062][#17043185]
  • #1 17025022
  • #2 17025139
    tad_reula
    Help: 18
    Rate: 43
    Qbittorrent - a ptosty interface and a transparent search engine.
  • #3 17025184
  • #4 17025222
    tad_reula
    Help: 18
    Rate: 43
    I will not help here. Install and test-never caused problems. You can use the portable version.
  • #5 17026441
  • #6 17026511
    tad_reula
    Help: 18
    Rate: 43
    In order not to litter in the system, download the portable version, create a folder and extract to the created folder. In this folder you will have everything about this program - if it will not fit, you delete the folder and the program is not there. For a search engine to work, the program will ask you to install Python. Try it - you do not risk anything.
  • #7 17043062
  • #8 17043185
    tad_reula
    Help: 18
    Rate: 43
    I tested various programs and decided that Qbittorrent suited me best. Now, for comparison, I installed Vuze, but this is not for me - e.g. advertising. I am writing not to force my "program" and force anyone to use this program. I write as a tester of various such programs.
  • #9 17043191
  • #10 17043225
    tad_reula
    Help: 18
    Rate: 43
    I used to download files of various sizes - 20, 30, and even above 50GB, (a pack of films) - it lasted a dozen or so days and there was no situation that I would not download and the computer did not have to work non-stop, after re-enabling it continued downloading . I often used two different programs that supported each other.
  • #11 17043247
  • #12 17043285
    tad_reula
    Help: 18
    Rate: 43
    Maybe it is possible, but I have never succeeded. Sometimes I accidentally deleted from the list of downloaded torents (the unfinished file was downloaded), but after reloading the torent did not want to integrate with the downloaded part, so I gave it a rest and downloaded it again. Maybe there is a way, but I did not fight it anymore. I never downloaded games because I do not create. Maybe those who intentionally damage files or use tricks, because a man is sometimes more malicious than a monkey. Do you have any problems with these kinds of files?
    Added after 16 [minutes]:
    Or maybe some antivirus blocks you or a defender or other firewall.
  • #13 17055379
    kil4
    I have been using ?Torrent for years and I am very happy. Very simple.
  • #14 17055462
    pawelr98
    Help: 413
    Rate: 1156
    Transmission is interesting.
    However, on linux it looks much better than on windows.
    On Linux, it can easily download torrents over 1.6TB, the transmission remote GUI can hang when resuming such large torrents, but executes commands.
    On the windows there are problems above 100GB (I had a situation where I checked over 1TB and spilled out at 99%) and the speed of checking data is lower.
    Nevertheless, an interesting program because it even has a phone app to control the client's operation.
    In the case of unfinished files, we have the choice between extension .part and not adding any tip. There is also path mapping in RemoteGUI if the file is on another computer (eg / mnt / drive / torrents = \\ NAS / disk). It allows you to open files straight from a remote client.
  • #15 17072454
    specpc
    Transmission is accepted on most "industry" portals ;) It has a cool web gui, applikacja on android, ios and a cool download server for various NASs.
  • #16 17073302
  • #17 17073449
    pawelr98
    Help: 413
    Rate: 1156
    The easiest way to use Transmission Remote GUI.
    There was probably an option to limit speed at selected hours, which can be used to force downloading at certain hours.
  • #18 17074075
  • #19 17075518
    pawelr98
    Help: 413
    Rate: 1156
    And how does a colleague remove these folders?
    When removing from the operating system, it may be that the torrent client will restore the folder and will try to download it.
    As for the data above 1.6TB, it will look at the TLMC colleague. The whole is currently above 1.7TB.
The discussion revolves around finding a reliable torrent client that minimizes errors during downloads. Users suggest several options, including Qbittorrent, Vuze, and Transmission, highlighting their features and performance. Qbittorrent is praised for its user-friendly interface and lack of ads, while Vuze is noted for its lightness and appealing interface despite some users experiencing NAT issues. Transmission is recognized for its compatibility with Linux and its remote GUI capabilities. Users also discuss common issues such as I/O errors, NAT configuration, and the challenges of transferring unfinished downloads between computers. The importance of using portable versions to avoid system clutter is emphasized, along with potential interference from antivirus software.
TL;DR: Transmission has handled 1.6 TB torrents on Linux; "Transmission is interesting." This guide fixes I/O errors, NAT issues, and resuming partial downloads for users asking what's the best low-error client. [Elektroda, pawelr98, post #17055462]
Why it matters: It prevents stalled downloads and saves hours on big transfers.
What’s the best torrent client if I want minimal errors and a simple UI?
Many users favor qBittorrent for its simplicity and built-in search. “A simple interface and a transparent search engine.” It offers an easy setup for casual use and avoids heavy extras. If you want to test without changes, use a portable build. Try it and see if it matches your workflow. [Elektroda, tad_reula, post #17025139]
How do I fix “I/O error” or “refusal to write” while downloading?
These usually stem from disk permissions, antivirus locks, or lack of space. Fixes: choose a writable folder, ensure free space, shorten paths, and whitelist the download folder in security software. Restart the client after changes. If the target drive is flaky, test another disk. “Disk I/O errors” are commonly resolved by correcting permissions or space limits. [Vuze Wiki: Disk I/O Errors]
How do I get rid of Vuze’s yellow NAT icon and slow speeds?
Open a listening port on your router. Steps: pick a port in Vuze, disable randomize, and forward that port via your router (or enable UPnP/NAT-PMP). Confirm status turns green. This removes firewalled status and improves peer connectivity. Vuze’s guide explains NAT/Firewall status and port forwarding details. [Vuze Wiki: NAT problem]
How can I move an unfinished torrent to another computer and continue?
Transmission supports this with .part files and path mapping. How-To: 1) Copy the data and the .torrent to the new machine. 2) In Transmission Remote GUI, map old to new paths. 3) Force a recheck, then resume. This lets you continue without redownloading completed pieces. It also enables opening files directly from the remote client after mapping. [Elektroda, pawelr98, post #17055462]
Why do deleted folders keep reappearing on my NAS/router when Transmission is running?
The torrent is still active. The client recreates needed folders and resumes downloading. Stop the torrent in the client first, then remove it and its data. Delete folders only after the client stops monitoring that path. Removing folders from the OS alone causes them to return as the client manages content. [Elektroda, pawelr98, post #17075518]
Can I resume large downloads after a reboot or power cut?
Yes. Clients recheck and continue where they left off. Users report resuming 20–50 GB packs after days of downloading. You do not need the PC running nonstop to finish. After restart, open the client and let it verify pieces, then it continues transfer. This behavior is standard in mainstream clients. [Elektroda, tad_reula, post #17043225]
Is Vuze lightweight and reliable for casual use?
Some users find Vuze works properly and feels light with a nice interface. If it runs well on your setup, it can be a solid choice. Test it on a few torrents and watch resource usage. If you dislike extras or ads, consider alternatives. [Elektroda, Anonymous, post #17043062]
Does Vuze show ads? Can I avoid them?
Yes, Vuze includes advertising in the interface. That bothers some users. If ads are a deal-breaker, try qBittorrent or Transmission, which aim for cleaner interfaces. Evaluate your preference by testing on the same tasks. [Elektroda, tad_reula, post #17043185]
Is µTorrent still a good, simple option?
Many people still use µTorrent and remain happy with it. It offers a very simple workflow for common tasks. If you value familiarity and minimal setup, it can work well. Always download from the official source and avoid bundled offers during installation. [Elektroda, kil4, post #17055379]
Why does qBittorrent ask me to install Python for search?
qBittorrent’s built-in search uses Python-based plugins. When you enable search, it prompts to install Python. Accept the prompt or install Python first, then enable search in the client. This keeps the core client lean while offering powerful searches. [Elektroda, tad_reula, post #17026511]
Should I use a portable torrent client to avoid cluttering Windows?
Yes. A portable client keeps all files in one folder. Create a folder, extract the portable build, and run it there. To remove it, just delete the folder. This avoids registry changes and makes testing easy. Use it on a separate drive if needed. [Elektroda, tad_reula, post #17025222]
How do I schedule night-only downloads in Transmission?
Use the built-in scheduler. In Transmission Remote GUI, set speed limits or a time window for active transfers. Configure peak/off-peak hours as needed. This lets you force downloading only at selected times. It’s ideal for bandwidth caps or quiet hours. [Elektroda, pawelr98, post #17073449]
Which client handles huge torrents best? Any caveats?
Transmission on Linux has handled torrents over 1.6 TB. On Windows, users saw problems above 100 GB and slower data checks. Edge case: Transmission Remote GUI may hang during resume of very large torrents, yet commands still execute. For massive sets, prefer Linux hosts. [Elektroda, pawelr98, post #17055462]
Why do I get “file too large” or failures when saving to a USB drive?
Many USB drives use FAT32, which has a 4 GB single-file limit. Large files will fail or trigger errors. Reformat the drive to exFAT or NTFS to store files over 4 GB. Back up data before reformatting. After switching file systems, recheck the torrent and resume. [Microsoft Support: FAT32 file size limit]
Can antivirus or firewall software break my torrents?
Yes. Security tools can block ports or lock files mid-write. Whitelist your torrent client and download folder. Allow the listening port in your firewall. If issues persist, test with the security tool temporarily disabled, then add proper exceptions. Re-enable protections after testing. [Elektroda, tad_reula, post #17043285]
