Renault Megane III Ph1 1.5 dCi 2010 - No Stop Lamps, Sensor & Fuses OK, Seeking Schematic
rwuhp 22197 4
  • #1 17027552
    rwuhp
    Rate: 128
    Hello, as in the topic of megane III ph1 1.5 dci from 2010 there is no stop. The sensor is ok fuses all good, but which stop I do not know. maybe someone will send a stop scheme from which the pin comes out of the ear and the fuse scheme I would be very grateful thank you in advance for any help.
  • #2 17028526
    kamiloskop
    Help: 42
    Rate: 278
    Have you checked the stop sensor with the meter?
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5049
    Diagram of stop lamps attached.
    120 - engine control unit
    172 - right rear light
    173 - left rear light
    260 - fuse box
    639 - third brake light
    645 - UCH
    1337 - UPC
    Apparently the UCH cannot see the signal from the sensor - no plus on the sensor or the signal from the sensor does not reach the UCH.
    Connect CLIP and check if the signal is coming.
    • M3 czujnik stop.pdf (13.65 KB) You must be logged in to download this attachment.
  • #4 17030036
    rwuhp
    Rate: 128
    Thanks for the diagram, the pros on the sensor are there and when you press the brake it outputs a signal.
  • #5 17039594
    rwuhp
    Rate: 128
    Hello, the reason for the lack of alloy was cold solder on 6 pins ears
