SAGEMCOM DSI87 Decoder Issue: Can't Start, Stuck on Boot & Init, Red LED Blinking
szydxx 7590 4
  • #1 17028470
    szydxx
    Rate: 9
    Hello all!
    I need help with the SAGEMCOM DSI87 decoder mentioned in the topic. The decoder has been working properly to this day. Unexpectedly, it turned off by itself, the word "boot" appeared, then "init". The red LED lights up next to "init", then goes out, "init" blinks over and over again.
    I started the decoder with the P + and P- buttons pressed - the decoder response saved on the attached movie.
    DSCF0204.AVI
    Can I fix the problem in any way?
  • #2 17028477
  • #3 17028506
    szydxx
    Rate: 9
    The decoder is already my property. Nobody will exchange it for me.
    Maybe someone else has other advice?
  • #5 17029540
    szydxx
    Rate: 9
    Thank you. The matter is clear.
    Subject to close.
