Stuck Decoder Dsi87 CPL: Remote Control Unresponsive, Diode Blinks, Program Search Jammed
dzikusek97 8142 2
  • Remote blinks but decoder stays unresponsive
    #1 16822864
    dzikusek97
    Hello . today I wanted to search for programs again when I entered the menu and wanted to select the options search for programs the decoder was jammed I unplugged the decoder and the menu is displayed again the remote control does not respond at all but when pressing the buttons the diode blinks I made updates holding two buttons next to the decoder + / - updated but the problem has not disappeared I do not know how I can deal with it, I would take the decoder for guarantees but I am on a trip abroad and I will be back only in a month
    Decoder model: dsi87 cpl
    Picture Stuck Decoder Dsi87 CPL: Remote Control Unresponsive, Diode Blinks, Program Search Jammed
  • #2 16823545
    netTv
    Level 32  
    Help: 193
    Rate: 579
    This is not a Cyfrowy Polsat set-top box, but NC +. Correct the title of the topic.
  • #3 16823553
    _kli_
    Help: 760
    Rate: 1038
    dzikusek97 wrote:
    stuck decoder of digital polsat
    This is a decoder nc + .
    Try again:
    1 - remove the card and disconnect the decoder from the power supply for about 10 seconds, then connect to the power supply
    2 - wait for the decoder to start working (it takes 15-30 seconds, wait during this time)
    3 - if this attempt does not help - perform another reset, but additionally, no antenna and still no card
    4 - wait for the decoder to start working (it takes 15-30 s, wait during this time)
    5 - if the attempt fails again - disconnect the decoder from the power supply, press P + and P- (left and middle buttons) on the housing, and then, while holding the buttons, connect the power supply. Keep the buttons pressed until the display shows "8888". The decoder starts downloading the update, which is signaled by the blinking digits on the display. The update takes about 20 minutes. Do not disconnect the decoder during this time, but wait patiently for the process to end.
    If the situation still does not improve - make another attempt according to the above instructions in some time.
    If it does not help - replacement.
