Title: Home Security Cameras: SIM Card-Compatible Recorders for Online Preview & Remote Monitoring
macono 5448 10
How can I connect my wired security cameras to remote monitoring over SIM/LTE if I have no cable internet or Wi‑Fi at home, and do I need a recorder with a SIM slot or a separate router?
You usually do not buy a recorder with a SIM card; the common solution is a separate LTE router with a SIM slot and LAN outputs, and the recorder connects to that router [#17030628][#17030863] If you want the image stored outside the house so theft of the recorder does not matter, use a cloud/VSaaS service, where the recording goes to a remote server and the recorder is not needed [#17031562][#17033079] For cloud monitoring you need LTE coverage and unlimited transfer, and you should remember that LTE can also fail or be cut off [#17031562][#17032024] One reply also notes that if you had normal internet, you would connect a LAN recorder to the router and use an external IP for remote viewing [#17030459]
  • SIM router needed for remote camera access
    #1 17030356
    macono
    Good morning. I have questions to professionals who are more involved in this field than I am - I have 4 wires for 4 cameras outside the house on the roof lining. all go to one place - now I would like to buy a camera recorder. I have a question? are there any recorders to install a sim card from an operator in them so as to have an online preview? It seems to me that it makes no sense to install the recorder without online preview or saving on the server because if they sneak in, they will steal the restrator and there will be no use of the cameras. I emphasize that I do not have any wifi etc. at home and I will not, and it would be most convenient for me to buy a sim card for monitoring from the operator. Do I just have to buy a separate recorder and router with the possibility of a sim card and connect them? please give me a hint on how best to rip it I don't want to spend a fortune on it, so ask for the best solution. best regards, Maciek
    and can the router be connected to the recorder at all? if so, everyone with everyone or do they have to be dedicated to each other ?? I look at the recorder camera sets on the Allegro, such as PLN 800, but I wonder if they are worth anything and can I use sim cards in them? please help. Hi
  • #2 17030459
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    It's best if you have internet at home from some local operator. Then you connect the LAN recorder from the router. You ask for an external IP address and you can view your property from anywhere in the world. You mention the PLN 800 set and that you don't want to spend a fortune. Ask yourself how much do you value your property?
  • SIM router and cloud preview for remote monitoring
    #3 17030628
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 643
    Such ready-made sets for PLN 800, I would give up. Branded equipment is almost such an expense again. Counting the recorder PLN 300-400, cameras 150-250 each, hard drive 250, plugs + power supply + cans (original or "electric") 200-300. If you search well, you will find good prices. As for the Internet, it's a mobile one, but with a router that has a SIM slot and LAN outputs. Preview, e.g. via the cloud.
  • Clarifying GSM router and camera recommendations
    #4 17030834
    macono
    I mean, I have to buy a router that has a GSM module or somehow, so that it can work almost like a phone and connect via wifi with one of the operators? Then the router connects to the registrar? If, for example, I am in the play network, can I buy an additional sim card for this purpose? As for cameras and recorder, what do you recommend? E.g. dahau? And maybe you will recommend a router to me because there are thousands of them? And I can't have internet via cable, so I can only have a mobile one, thank you for the answers
  • #5 17030863
    dawidedziu
    Help: 500
    Rate: 643
    Cameras, do you want domes or bullets? Do you have any lighting at night? More data, etc. As for the router, you could get it from the operator. The router itself, which supports the SIM card or router + "USB flash drive", costs several hundred zlotys. I think it will be cheaper to take everything from your network.
  • #6 17031562
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    @macono get interested in VSaaS (Video Surveillance as a Service) service. In Polish: cloud-based monitoring.
    In short: you don't need a recorder as the image is saved on a remote server. There is no risk of the recorder being stolen.
    There are also Polish companies that provide such services. For example, adcloud.pl, but I don't know how it works, because I haven't tested it.
    You must have LTE coverage and unlimited transfer.
  • #7 17032024
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    But there is a risk of LTE disruption or otherwise cutting off the internet. Also, everything has its pros and cons.
  • #9 17032756
    Level 37  
    Help: 211
    Rate: 1014
    @yszne correct. But who will take the "hedgehog" when breaking into a single-family house? Marginal cases.
    @dawidedziu full consent. Therefore, if you plan well where to hide the recorder at the stage of cable laying, it can pay off. :-)
  • #10 17033001
    macono
    it's dark around the house at night. I looked at the Allegro such a set: http://allegro.pl/zecja-do-monitoringu-dahua-4-kamery-2mpx-full-hd-i6316385900.html what do you think about it? Unfortunately, I did not think about hiding the recorder somewhere hidden, therefore I would prefer the image to be saved somewhere on the net. as I wrote, I do not have a cable, only connecting to the Internet wirelessly is in the game. the recorder is not needed to record in this so-called chumurce? cramp, can anyone explain what it is and what is the best solution for me in this situation ??
    and I want to buy domes, they look so aesthetically at home in my home, they stick out less, etc.
  • #11 17033079
    Level 37  
    Help: 211
    Rate: 1014
    He is not needed.
The discussion revolves around the installation of home security cameras with a focus on recorders that support SIM cards for online preview and remote monitoring. The user seeks advice on suitable recorders and routers, given the absence of a wired internet connection. Recommendations include using a router with a GSM module to connect to mobile networks, and considering Video Surveillance as a Service (VSaaS) for cloud-based monitoring to mitigate the risk of theft of physical recorders. The user expresses interest in dome cameras for aesthetic reasons and seeks cost-effective solutions for their security setup.
