Hikvision & HQvision Hybrid Recorders: Remote Configuration Issues with 3G Modem & PLAY Card
Damian060709 7056 19
How can I get remote configuration access to a Hikvision/HQvision hybrid recorder when live view and playback work through the cloud, but iVMS4500/Hik-Connect disables Customize and iVMS4200 says the device is offline?
Remote configuration is most likely failing because PLAY is blocking the needed ports or the recorder is not properly port-forwarded; the thread says that in a correctly redirected recorder these settings are normally available [#16922042] [#16922123] [#16923294] One reply also suggests the 3G modem itself may be the blocker, even if Hik-Connect P2P preview works [#16927532] In iVMS-4200, one workaround mentioned is to add the device as a new P2P encoder and log in through Hik-Connect there to get full management access [#17112686] If you want to verify the cause, try the SIM in another operator’s network or ask PLAY technical support which ports are blocked [#16922123] [#16922042]
  • #1 16921586
    Damian060709
    Help: 5
    I have two hybrid recorders. The first hikvision, the second is HQvision.
    They are in different places. Each of them is connected to the internet. Camera view is through the cloud.
    Next to each recorder is a router to which a 3G modem with a PLAY card is connected.
    I have access to cameras, preview and playback. I can't get to the registrars.
    In ivms4500 or hik-connekt there is no customize option, the icon is dimmed. However, in the ivms4200 program, when I want to enter the remote configuration of the recorder, it shows me a message that the device is offline or a network problem, error .... dll (7)
    Do you also have that? Is this the fault of the ports blocked by PLAY?
    I have a different hika set. internet orange, external IP. Zero problems with remote configuration.
    I will be grateful for any suggestion.
    best regards
  • #2 16922042
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 642
    I would bet on blocked ports. I recently had a similar problem that was related to port forwarding. Call Playa and get along with them.
  • #3 16922123
    marek216
    Help: 1077
    Rate: 932
    As a colleague mentioned above. Play blocks ports. Contact the technical department helps - do not count on help in BOK You have to find someone smarter, I succeeded in 4 at a time.
  • #4 16922270
    jpl
    Help: 240
    Rate: 223
    What windows do you have If 10 -may try to uninstall ivms and then install it in "run as administrator" mode and set the installation file to "windows 7 compatibility settings" (if you have a lower os, then you skip this step).
    After installation, you also start the program by running as an administrator and trying to enter.
    For me it's not a ports matter because you have a picture etc.
    And what file are you missing? Down?
    Maybe install early visual c ++ 2012 32bityy and 64bity packages.
    And finally both packages at visual c ++ 2015.
  • #5 16923192
    Damian060709
    Help: 5
    I checked IVMS4200 in various ways. older, newer versions. Running as admin. I also tried VC ++ and the same thing continues. It works on windows 8. So it will be the fault, however, Play because the application also does not have all the options exposed.
    In the application we have modes: clear, smooth or we can customize our own settings. and this Customize option is not available.
  • #6 16923294
    dawidedziu
    Help: 500
    Rate: 642
    Well, as you can see, the fault is 99% on the side of blocked ports. In a correctly redirected recorder these parameters can be freely configured.
  • #7 16923360
    Damian060709
    Help: 5
    I know that, unfortunately this option is disabled: /
    I checked on another VTVision recorder. Oprerator PLUS, connection via the cloud. No problems in VMeye, Xmeye applications. Everything is available on the CMS computer.
    It is best now to insert the card from Plus into the modem and check if it will be blocked on Hiku,
    Thanks for the answers,
  • #8 16927532
    Konrad Kl.
    Rate: 10
    At the beginning of December I installed the Hikvision recorder with remote management through HikConnect. Of course, internet from Play. There were no problems connecting via P2P. UPnP enabled. The router is from TP-LINK, but the difference in my case is that the router has a built-in modem for a sim card. Maybe the 3G modem itself is blocking.
  • Cloud access and port forwarding for Hikvision cameras
    #9 17111689
    dobo_28
    Gentlemen, I have a similar problem with my cameras.
    I have 3 cameras DS-2CD2385FWD-I and one DS-2DE3304W-DE display image and PTZ control works I can change the image quality from HD to standard but I can not enter any settings e.g. Remote configuration in IVMS-4200 or Remote configuration in Hik -Connect (Port mapping mode - automatically or manually on 8080)
    The cameras are connected to the TENDA POE SWITCH TEF1105P, and it is connected to the Huawei LTE LTE modem (T-Mobile without limit - cameras send about 400GB of data per month). In the net flat I have a CISCO EPC3008 modem with cable, which is connected to the Router TL-WR1043ND, and in the phone (Xiaomi Redmi Note 4) LTE Orange internet.
    Do I need to configure ports when connecting through the cloud?
    I mean ports:
    8000 server
    HTTP 80 or 8080
    RTSP 554 or 5554
    HTTPS 443
    if everything goes through the cloud and leave for the car.
    I will only add that the house is under construction and I do not stay there every day. The ability to change image parameters remotely would be very useful.
    Ultimately, I do not plan to insert a typical recorder into cameras, only a QNAP server, e.g. model TS-251A with support for 4 cameras.
    One more question is whether it is easier to download photos from motion detection that are available in Hik-Connect Message tab than to browse through hundreds of photos from 3 days and download them by clicking one by one and saving them additionally in incomplete resolution because instead of 4K I have FHD.
    I want to help a neighbor whom I broke into although he is far away from me, most likely my camera registered them as they headed towards his property. Viewing photos from a few days ahead is a tragedy in this application I would like to download them to disk and view them from a computer, not an application that can go to the latest photos and again the fun begins to browse through hundreds of registered events.
    Thank you in advance for the information.
  • #10 17112686
    Marcin8626
    in ivms 4200 you need to add a new encoder as p2p and log in to your cloud there, then you have the full ability to manage the recorder.
  • #11 17112734
    makosuu
    Help: 369
    Rate: 370
    dobo_28 wrote:
    In the home net I have a CISCO EPC3008 modem with cable connected to the TL-WR1043ND Router, and in the phone (Xiaomi Redmi Note 4) LTE Orange internet.
    You don't have to, but since you have a public IP then assign this device (recorder, NAS, something) a static IP and redirect these ports, you will have 100% access to it, and it's probably always on +.
  • #12 17113008
    dobo_28
    I do not have a recorder here I will specify more precisely IVMS 4200 I have installed on a laptop in the apartment where I have a preview of what is happening at the construction of the house.
    I corrected the sentence "In the home net I have a CISCO EPC3008 modem with cable connected to the TL-WR1043ND Router, and LTE Orange internet in my phone (Xiaomi Redmi Note 4)." for an apartment because it can be misleading in terms of location.
    Apparently mobile operators (in my case T-Mobile) do not really give static IP.
  • #13 17113022
    makosuu
    Help: 369
    Rate: 370
    Internet with T-Mobile, if it's for a regular user, you will not get a public IP, for a company you will get a static public IP. If you have a cloud, you do not need to redirect anything, and in this case redirection will not do anything because there is no public IP. And whether IP is static or dynamic does not matter, because we have DDNS.
  • #14 17113032
    dobo_28
    Net with T-Mobile is for the ordinary blacksmith his plus is the actual no limit.
    In this case, does I use the Hikvision cloud to deprive me of remote camera configuration?
  • #15 17113040
    makosuu
    Help: 369
    Rate: 370
    I don't know, because I'm not a specialist, but I think that the cloud is just a preview of the image from the camera. But port forwarding is not the only way, you can connect via VPN, you need to have some server through which you connect from both sides to be with the camera in one network, just like the cloud (proxy server) but according to for me, these combinations are a form over content and I would be content with the cloud.
  • #16 17113055
    dobo_28
    All I miss is the possibility of remote configuration so that I do not have to go with the flip to build 40 km to make corrections, e.g. in image compression or the number of frames sent.
    Recently, I also made a look when I was at the construction site without a laptop and restored the factory settings via a smartphone (because the PTZ camera did not take snapshots after motion detection - I changed something when I was playing with the microphone) I could not connect it to the cloud again. I suspect that the camera must be reactivated by SADP.
    And does anyone know how to download dumps of frames that are available in the Hik-Connect application in bulk?
  • #17 17115034
    dobo_28
    The DS-2DE3304W-DE camera is restarted after a factory reset.
    But it is but because I still don't have a frame drop when detecting motion. The whole camera area is set, the detection sensitivity is 60, exactly the same way the DS-2CD2385FWD-I cameras are set. Where can the problem be that I don't have detection from this one camera?
    I have also unnecessarily updated the app on the phone now it constantly changes my image settings from HD to BASIC as I switch from preview 1 where I have HD to preview 4 cameras switches to preview on BASIC.
    So a screwed up preview and you still can't change the settings. In addition, I noticed that it automatically changed the image parameters from 2048 to 512.
  • #18 17122896
    Marcin8626
    no, you have full configuration options through cloud.
  • Motion capture requires iVMS and A1 linkage methods
    #19 17123383
    dobo_28
    In iVMS-4200, when I click in Remote Configuration, a black window pops up in the bottom right corner with the information "Logins failed. Error CodeHCNetSDK.dll [10]. (Receiving data from device timed out.)" While in Hik-Connect by clicking Remote configuration with the port mapping mode set to manual (Service port 8000 and HTTP 80), "Failed to connect" pops up, while the automatic mapping mode parameters disappear (service and HTTP port) and when trying to connect, "Port cannot be empty" pops up, which in automatic mode cannot be inserted manually.
    Added after 16 [hours] 28 [minutes]:
    In DS-2DE3304W-DE, I managed to launch a frame capture for motion detection, I had to additionally select the option from iVMS and A1 in the Linkage Method tab.
  • #20 17141603
    dobo_28
    Gentlemen, you will help solve the problem of lack of configuration when connecting through the hikvision cloud, which does not work on your smartphone or PC.
    Should I set a different Service Port for each camera, e.g. 8001 8002, 8003 etc.? Because if there is one for everyone this is a conflict?
The discussion revolves around remote configuration issues with Hikvision and HQvision hybrid recorders connected via 3G modems with PLAY cards. Users report difficulties accessing the recorders through iVMS-4200 and Hik-Connect, often receiving error messages indicating offline status or network problems. Many participants suggest that the root cause is likely blocked ports by the PLAY service, as successful remote management was noted with other ISPs. Various troubleshooting steps are discussed, including checking port forwarding settings, using different versions of iVMS software, and ensuring proper installation settings. Some users also mention the importance of having a public IP for effective remote access and suggest using VPNs as an alternative solution. The conversation highlights the need for proper configuration to enable full access to recorder settings remotely.
TL;DR: Many "remote config not available" cases trace to carrier port policies; one user fixed 4 lines after escalation—“Play blocks ports.” [Elektroda, marek216, post #16922123]
Why it matters: If preview works but configuration fails, you need the right path—P2P login, port changes, or carrier support—to regain full remote control.
Quick-Facts
Why can I see cameras via cloud but can’t open Remote Configuration?
Your carrier is likely blocking required ports or you’re not added via P2P correctly. Users on Play report preview OK but config blocked and HCNetSDK.dll errors. Escalating to Play’s technical department restored access. Quote: “Play blocks ports.” [Elektroda, marek216, post #16922123]
Does Play (PL) really block ports for DVR/NVR access? What do I tell them?
Yes—users confirm port blocking on consumer Play. Call and ask for technical support to open/allow required ports for your recorder’s service and HTTP access. Front-line BOK rarely helps; escalation did. “Contact the technical department helps.” [Elektroda, marek216, post #16922123]
How do I get full configuration through Hik‑Connect/iVMS‑4200?
Add the device to iVMS‑4200 as P2P, then sign in with your Hik‑Connect account. That enables full remote management through the cloud without manual port forwarding. “You have full configuration options through cloud.” [Elektroda, Marcin8626, post #17122896]
How do I add a Hik device in iVMS‑4200 via P2P (quick steps)?
  1. In iVMS‑4200, Add Device > choose P2P.
  2. Sign in with your Hik‑Connect account and select the device.
  3. Save, then open Remote Configuration from the device menu. [Elektroda, Marcin8626, post #17112686]
I get HCNetSDK.dll errors like (7) or timeouts. Is this Windows or network?
Both appear in reports. Some tried admin install and Visual C++ runtimes with no change. When preview works but config fails, network/carrier policy is the primary cause. Fix often requires P2P login or carrier support. [Elektroda, jpl, post #16922270]
Do I need to forward ports if I use Hik‑Connect cloud?
No. With cloud/P2P you don’t need manual port forwarding. If you have a public IP, forwarding is optional for direct access. Without a public IP (typical mobile plans), forwarding won’t work anyway. [Elektroda, makosuu, post #17113022]
Is a USB 3G/LTE stick the issue? Would a router with SIM help?
One success case used a TP‑Link router with built‑in SIM modem, UPnP enabled, and Hik‑Connect P2P—no issues on Play. External USB modems can add NAT quirks. Try a router with integrated LTE. [Elektroda, Konrad Kl., post #16927532]
The Customize stream option is greyed out in Hik‑Connect/iVMS. Why?
That often accompanies remote‑config blocking. Users on Play saw preview modes but Customize disabled until network constraints were resolved. After switching environments, options returned. [Elektroda, Damian060709, post #16923192]
Manual port mapping in Hik‑Connect shows “Port cannot be empty.” What does it mean?
Automatic mapping may clear fields, causing connection failure. One user saw “Failed to connect,” then empty ports and timeouts. This is an edge case with manual mapping over mobile CGNAT. Use P2P mode instead. [Elektroda, dobo_28, post #17123383]
Do multiple cameras need unique Service/HTTP ports when mapping manually?
When you manually map through a router, overlapping ports can cause failures. Reports of timeouts and cleared fields suggest conflicts; assign distinct ports per device or use P2P to avoid this. [Elektroda, dobo_28, post #17123383]
Will changing mobile operator help?
It can. A user on Plus with a different brand recorder and cloud access reported full options in apps and CMS, unlike on Play. Carrier policies differ. [Elektroda, Damian060709, post #16923360]
How much data do LTE cameras consume in practice?
Expect heavy usage. One setup with three 8 MP cameras plus a PTZ moved about 400 GB per month over LTE. Plan data and costs accordingly to avoid throttling. [Elektroda, dobo_28, post #17111689]
Motion snapshots aren’t saving on my PTZ. Any fix from iVMS‑4200?
Yes. Enable the snapshot linkage. In iVMS‑4200, open Remote Configuration > Event > Linkage Method, and tick Snapshot (A1). That restored motion captures for a DS‑2DE3304W‑DE. [Elektroda, dobo_28, post #17123383]
After factory reset, my PTZ won’t rejoin the cloud. What next?
Post‑reset, devices may need reactivation and re‑adding. One user suspected reactivation via SADP before cloud binding. Re‑activate locally, then add back to Hik‑Connect. [Elektroda, dobo_28, post #17113055]
iVMS‑4200 on Windows still fails after reinstalls. Any tip?
Try installing/running as Administrator and apply Windows 7 compatibility, plus VC++ 2012/2015 x86/x64. If errors persist, focus on carrier/network policy or switch to P2P login. [Elektroda, jpl, post #16922270]
