[Solved] Bosch SPV43M10EU/20 Dishwasher - Persistent Error E19, Dispenser Error despite Replacements
mailwash 31164 3
  • #1 17044109
    mailwash
    Rate: 13
    I have a Bosch SPV43M10EU / 20 dishwasher. For some time the dishwasher stops after 15 minutes, displaying the error E19 - acc. bosch website pages - dispenser error. My guess is that it is a detergent dispenser I mentioned: the actuator in the dispenser, and the transistors and diodes on the control board, and the error has not disappeared. Did any of you have a similar problem?
    Bosch SPV43M10EU/20 Dishwasher - Persistent Error E19, Dispenser Error despite Replacements Bosch SPV43M10EU/20 Dishwasher - Persistent Error E19, Dispenser Error despite Replacements
  • #2 17045517
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3827
    mailwash wrote:
    I replaced: the actuator in the dispenser, and the transistors and diodes on the control board
    So you exchanged those marked with a red frame, and what did you give in exchange? I usually saw a broken transistor below the frame ...
  • #3 17047817
    mailwash
    Rate: 13
    I exchanged those marked with the same frame (from the 2nd album I managed to get). Unfortunately this one below the frame broke during the extraction from the donor so I left what it was. But are you able to say if E19 is associated with a detergent dispenser coil? Because in the meantime I measured the solenoid coil and has 7? instead of about 2.5?.
  • #4 17082969
    mailwash
    Rate: 13
    Replacing the solenoid valve marked in the picture in the last post has helped and everything is blinking.
