Bosch SPV43M10EU/20 Dishwasher: Error E19 Solution, Dealing with E25 & E01 Errors, Solenoid Valve
Phantomxxx 22668 8
  • #1 17103423
    Phantomxxx
    I am new here and I am asking for your understanding. I have a Bosch SPV43M10EU / 20 dishwasher.
    I fight the dishwasher for 2 days (I wanted to be a hero at home). The adventure began with the fact that the dishwasher at work stopped and showed error E25 (pump blocked / clean the pump), I took out the dishwasher, unscrewed, got to the pump. I dismantled and cleaned it, although it was ok - there was some shit in the strainer.
    I put everything together and showed error E01 (electronic circuit fault), so I took apart once again, pushed out the plugs, checked if they were sitting ok, and so it was. I twisted the dishwasher and carried out the test, i.e. washing for 15 minutes, so quickly and it was ok. In the morning I turn it on, and it showed immediately after starting the program and pressing START error E19 (dispenser fault) and the dishwasher does not react.
    I studied the Internet and YouTube and the replacement of the solenoid valve seemed to help, so I went to the store and bought a solenoid valve from the washing machine (it was a bit different, but the coil was the same, so I cleaned the piston, changed the coil, soldered plugs). I make the same again - error E19 at the start.
    And here is my question to you. Do I still have a chance to stay? a hero in your home? Maybe some hints? And I will add that the old coil had 7kA and the new coil had 3.5kA.
    Greetings.
  • #2 17103573
    andrzej1959
    Home appliances specialist
    Help: 223
    Rate: 817
    The module must be replaced for this condition.
  • #3 17103591
    Phantomxxx
    Maybe a silly question, but which module is where it is located?
  • #4 17105648
    andrzej1959
    Help: 223
    Rate: 817
    This module at the bottom of the dishwasher.
  • #5 17108623
    Phantomxxx
    The module burned (probably 3 transistors) and taken to electronics in a week will probably be ready.
  • #6 17865785
    elekdar
    Was the module damaged only?
  • #7 17865845
    Phantomxxx
    Module and electrosaw
  • #8 17866510
    zibi1971
    Help: 262
    Rate: 1120
    You must buy the original solenoid valve. There's a 300V DC coil, you put it on 230V AC. Perhaps only the valve was damaged, and after putting it on from the washing machine you beat the module ...
  • #9 18947642
    mr.meeseeks
    I had the same problem. But there is not transitors, There are triacs Z9M. So it will problably not activate DC solenoid valve. Have you any idea? nothing is burned but E19 show just by turning dishwasher on . Bosch SPV43M10EU/20 Dishwasher: Error E19 Solution, Dealing with E25 & E01 Errors, Solenoid ValveBosch SPV43M10EU/20 Dishwasher: Error E19 Solution, Dealing with E25 & E01 Errors, Solenoid Valve
The discussion revolves around troubleshooting the Bosch SPV43M10EU/20 dishwasher, specifically addressing error codes E19, E25, and E01. The user initially encountered E25, indicating a blocked pump, which was cleaned but subsequently led to E01, an electronic circuit fault. After further attempts, the user faced E19, related to a dispenser fault. Responses suggest that the module at the bottom of the dishwasher may need replacement, with indications that the solenoid valve could also be damaged. There are mentions of specific components like triacs and the importance of using original parts to avoid further damage.
