[Solved] VW Sharan 2003: Communication Error with Computer, OBD, CDIFA, K Line & ECU Troubleshooting
zuberek7 23835 15
Why does diagnostic software fail to communicate with my 2003 VW Sharan even though the OBD K-line wiring checks out, and what can block the connection?
The communication error was caused by the auxiliary heater controller blocking the K-line, not by the instrument cluster itself [#17324448] Check the K-line voltage and inspect the splice point under the dashboard behind the fuse/relay box, where the K-line wires join; unplug the connectors one by one until the blocking device is found [#17047605] In this case, the K-line path for the engine controller goes through the immobilizer box, so if there is no communication with the engine ECU, the immobilizer side should also be checked [#17045602] The owner later found cut/opened insulation and multiple spliced K-line wires in that harness, which confirmed the fault was in the wiring/connected module rather than the OBD socket itself [#17322630]
  • #1 17044840
    zuberek7
    Rate: 15
    I warmly welcome,
    I recently tried to connect my sharan to a computer using CDIFA and unfortunately I get a communication error. I started to check the cable - the K line and it turns out that everything is fine from the ODB socket to the meter and from the immobilizer plug to the ECU. Is there anything on the meter clocks that can block the connection?
  • #2 17044855
    sagem173
    Rate: 8
    with the meter, you check in the socket whether the 12V is?
  • #3 17044950
    zuberek7
    Rate: 15
    I checked, it's 12v. I also tried to connect "for a short time" - I connected pin16 with ecu directly with pin 7 of the OBD socket and then connects but only to the engine itself.
  • #4 17044953
    ociz
    Help: 1379
    Rate: 3488
    zuberek7 wrote:
    is there anything that can block the connection?
    Eg additional heat and its rotten beam.
  • #5 17045494
    sagem173
    Rate: 8
    or ecu freaks out :D
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5054
    You only have no communication with the engine controller?
    The K line for the engine controller goes through the immo box.
    If there is a problem there should be communication with the immo box.
    Short-circuit K and W to immo forest and diagnosis should return. They are probably gray-white or white-gray wires.
  • #7 17047468
    zuberek7
    Rate: 15
    maybe something is happening with the cables because when I bought it, there were no 2 pieces in the fuse socket (there were empty spaces) and when I refilled them, the battery discharged after the night ...
    I have a total lack of communication. Only when connecting "for a short time", as I mentioned before, I connected to the engine controller, I could not cope with others.
    ociz
    Help: 1379
    Rate: 3488
    Check the voltage on the K line.
    Under the cockpit, somewhere in the upper left corner there were connectors where all the K line wires come together. Unpin all in turn until you find what is blocking.
  • #9 17049566
    zuberek7
    Rate: 15
    Thank you very much for the hints. As soon as I find a little more time I will start checking everything you write about and I will keep you updated on the results.
  • #10 17312249
    zuberek7
    Rate: 15
    I finally found time to review the installation. It turned out that someone was already looking for something and the beam insulation was cut open. 4 yellow-black welded cables protruded from the cut insulation - visible in the photo. In addition, the gray cable with a white K line strip from the OBD socket is also welded to 4 others - also visible in the picture. These welds are factory or are they someone's makeover?
    • VW Sharan 2003: Communication Error with Computer, OBD, CDIFA, K Line & ECU Troubleshooting 20180704_180105.jpg (4.08 MB) You must be logged in to download this attachment.
    • VW Sharan 2003: Communication Error with Computer, OBD, CDIFA, K Line & ECU Troubleshooting 20180704_172042.jpg (1.72 MB) You must be logged in to download this attachment.
  • #11 17322630
    zuberek7
    Rate: 15
    These heated wires from the first photo are connected K lines. I unraveled them all and it turned out that the connection was blocked by one of them - most likely from reheating (most likely because I have not checked yet and the computer can not connect now only with reheating).
  • #12 17323700
    dabrowski marek
    Rate: 68
    Buddy, and where is the bundle and if I follow the cable from the obd lines k lines will I find the cable connections k lines
  • #13 17323786
    zuberek7
    Rate: 15
    it is in a thick hanging behind the fuse box and relay box which is on the left side of the steering wheel. tracking the k line from obd you will reach it.
  • #14 17324059
    dabrowski marek
    Rate: 68
    Thanks a lot or maybe you know what color cable goes to the additional heater and where its controller is located
  • #15 17324102
    zuberek7
    Rate: 15
    all K lines are gray with a white stripe. only from the immobilizer is white. It is impossible to determine which is what without checking.
  • #16 17324448
    zuberek7
    Rate: 15
    Added after 8 [hours] 34 [minutes]:
    Finally, it turned out that the connection blocks the reheating controller. Thank you all for the advice.
The discussion revolves around a communication error encountered when connecting a 2003 VW Sharan to a computer using CDIFA. The user confirmed that the K line and OBD socket connections are intact, but communication with the engine controller is absent. Suggestions included checking the voltage on the K line, inspecting the immobilizer box, and verifying connections under the dashboard. The user later discovered damaged wiring in the harness, which was blocking the K line connection. Ultimately, it was determined that the reheating controller was the source of the communication blockage.
TL;DR: In a 2003 Sharan, after 8h34m of tracing, "all K lines are gray with a white stripe," and the additional‑heater controller was the K‑line blocker. Isolate the K‑line and test with that controller unplugged. [Elektroda, zuberek7, post #17324448] Why it matters: This FAQ helps VW Sharan 7M owners and techs fix no‑communication OBD issues by tracing K‑line faults fast.
Why won’t my 2003 Sharan connect to CDiFA/VCDS?
A module is likely pulling the shared K-line down. In this documented case, the additional heater controller blocked communication across modules. Unplug the heater controller and retest diagnostics. If communication returns, repair or replace that controller or its harness. [Elektroda, zuberek7, post #17324448]
Where is the K-line junction I should check first?
Follow the gray/white K-line from the OBD socket to a splice cluster. It is inside a thick loom behind the fuse and relay box on the left of the steering wheel. Access the loom, open the wrap carefully, and expose the splice connectors for testing. [Elektroda, zuberek7, post #17323786]
How do I isolate a shorted K-line quickly?
Use this 3-step method:
  1. Measure K-line voltage at OBD pin 7 with ignition on.
  2. Unplug K-line splice connectors under the dash one by one.
  3. After each unplug, retry the scan until communication returns; the last removed branch is faulty. [Elektroda, ociz, post #17047605]
Does the engine ECU’s K-line route through the immobilizer?
Yes. The engine ECU K-line passes through the immobilizer box. If that path fails, you may still talk to the immobilizer itself. As one expert put it: "Short-circuit K and W to immo forest and diagnosis should return." Verify the gray/white and white wires at the immo plug. [Elektroda, grala1, post #17045602]
What color are the Sharan’s K-line wires, including immobilizer?
All K-lines are gray with a white stripe. The immobilizer K-line is white. Trace and confirm before cutting, because multiple gray/white lines join in the loom, and identification requires testing continuity. "All K lines are gray with a white stripe. only from the immobilizer is white." [Elektroda, zuberek7, post #17324448]
Why did a direct jump to OBD pin 7 only talk to the engine ECU?
A direct wire connected your scan tool only to the engine ECU’s K-line, bypassing the shared splice. That isolated the engine module from the rest, so only the engine answered while other controllers remained unreachable on the faulty K-line branch. This behavior matches the reported test outcome. [Elektroda, zuberek7, post #17044950]
Can the additional heater (Webasto) block diagnostics on the K-line?
Yes. The additional heater controller can hold the K-line bus down and kill communication to all modules. Disconnect that controller and check if scanning resumes. If it does, repair the heater controller or its corroded harness before reconnecting it to the K-line. [Elektroda, zuberek7, post #17324448]
How many joined K-line wires might I find in the under-dash loom?
Expect multiple splices. In the documented teardown, the gray/white K-line from the OBD socket was welded to four other K-line wires in the loom. One of those branches blocked diagnostics until isolated from the bus. This shows how a single bad branch can affect all modules. [Elektroda, zuberek7, post #17312249]
How do I verify OBD-II power before chasing K-line faults?
Check for battery voltage at OBD pin 16 and good grounds on pins 4 and 5. Without stable +12 V and ground, no scan tool will connect, regardless of K-line integrity. Confirm power first to avoid misdiagnosing a communications fault. [“OBD-II Connector Pinout”]
Could a failed ECU cause total no-communication on the K-line?
It can. A malfunctioning ECU may disrupt bus communication and appear as a global no-comm condition. Rule it out by isolating ECU’s K-line branch at the splice and testing tool communication with other modules. Replace or repair the ECU only after confirming isolation results. [Elektroda, sagem173, post #17045494]
After adding missing fuses, my battery died overnight. Related to no-comm?
It can be related. Reinstalling missing fuses can re-energize a faulty retrofit or corroded circuit, such as the auxiliary heater harness. That can both drain the battery and load the K-line. Pull the suspect fuse, unplug the heater controller, and recheck current draw and diagnostics. [Elektroda, zuberek7, post #17047468]
If the immobilizer path is faulty, can I still run diagnostics?
Often, yes. You may retain communication with the immobilizer even if the engine ECU path via immo is broken. Bypassing or shorting the K and W lines at the immobilizer plug for testing can restore scan access, confirming a path fault. Proceed carefully and document wiring. [Elektroda, grala1, post #17045602]
