2004 VW Sharan Mk1: ABS, ESP & MANUAL Indicators On - 00003-Control Module/Defective Diagnosis
kamiloooxxx 7461 4
  • #1 16259849
    kamiloooxxx
    Rate: 48
    Hello. The patient is Sharan from 2004. While driving, when parked, the ABS, ESP and MANUAL indicators light up without difference. After connecting to vcds an error appeared
    00003-Control Module / Defective.
    After turning the ignition off and on, everything returns to normal and after some time the same happens again. While the error is constant, I checked the power supply and the mass of the module are all ok. The plug at the controller is not tarnished. Due to the fact that the module is not cheap, I would like to make sure and advise what else to check?
  • #2 16260084
    szymitsu21
    Help: 343
    Rate: 1302
    Probably the driver is damaged.
    There are no non-original devices in the car?
  • #3 16260566
    kamiloooxxx
    Rate: 48
    There are no non-original devices in the car.
  • #4 16260677
    bsv2001
    Help: 26
    Rate: 183
    This is often a problem
  • #5 16433815
    kamiloooxxx
    Rate: 48
    Hello again, the fault has not been removed, it seems to have intensified. When there is an error related to ABS when braking, the fuel gauge goes down and the reserve lights up, it looks as if it depends on the ABS error, when there is no error in the ABS system, the floats work normally. What does a pressure modulator have to do with a float?
