Is it possible to distribute the LAN from the router through the hub in the home
PawelKce 10965 13
Can I distribute Ethernet/LAN from a router through the existing coaxial cabling in my house?
Yes, but you need Ethernet-over-coax/MoCA adapters rather than a normal router-to-coax connection, and the solution is usually expensive [#17047369][#17048656] The old BNC/coax networking approach is described as outdated, hard to find, and limited in speed; one reply notes that 75-ohm TV coax can be used, while classic 50-ohm BNC networking is a different, older technology [#17047369][#17048041] A tested example is the Radiosonic ICY BOX IB-CX110-110-Kit, which reportedly works on 100 Mb/s over 75-ohm cable and needs no tees or terminators, with a stated maximum distance of 200 m [#17048706] Another tester says a 10 Mb/s RJ45-to-TV-cable converter worked, but the 100 Mb/s version was unreliable, so performance depends on the hardware [#17048041] If you can still change the installation, several replies recommend pulling twisted pair instead because it is simpler, cheaper, and more reliable; Powerline is mentioned as an alternative but with possible performance loss when multiple users are connected [#17049077][#17049491][#17050682]
  • #1 17047271
    PawelKce
    in a single-family house I have an installation on a coaxial cable which is distributed to the rooms from the attic.
    I would like to put a router in the attic and give up WiFi connectivity in favor of Lan via a cable.
    I do not really want to put a twisted pair, because the house is almost new and after painting, but this, apart from drilling, would involve a bit more interference in the plaster.
    I would like to use the existing network on a coaxial cable.
    The router I have is Asus to the operator's card. Are there any adapters, or would it require the purchase of a new router?
    I will be grateful for your help.
  • #2 17047369
    tata1
    Help: 43
    Rate: 260
    First, you would have to lay the 50om coaxial cable, not the one for the TV-75.
    Secondly, in today's technology, it cannot be done cheaply.
    There are even devices (switches), e.g. NF-1804M, which work in BNC technology and can work in a star (like a twisted pair), up to 92Mbs. They are used for downstream wired transmissions where it is too far over the twisted pair.
    For the purposes of the Internet, it would also work, but is it worth it? You would connect this to your router and it would send the signal through the BNC plugs.
    However, this switch does not cost little, and on the other hand, you also need converters to RJ-45 twisted pair (because BNC network cards are probably only for ISA, PCI and PCIMCIA for older computers).
    Here are the links to an example device:
    http://www.nufiber-systems.com/sale-7730762-4...t-over-coaxial-converter-2km-master-type.html
    http://www.nufiber-systems.com/supplier-112566-ethernet-over-coaxial-converter
  • #3 17047377
    icosie
    Help: 298
    Rate: 239
    The technology "died out" more than 20 years ago, it is not used often, so unfortunately it is expensive. There is a fairly efficient alternative to this type of connection. Look on Google under the name "Outlet Internet". These are LAN adapters running on the electric network, without forging and mounting wires to the network.
  • #4 17047381
    mieszaczwcz
    Help: 185
    Rate: 258
    What the devil is tempting you, give up time, once upon a time in the early days of network connections it was common and generally did not work with a few exceptions. Now, you will not buy this equipment on BNC, even in a bazaar antique shop, unless some strange converters and if it even worked, max transmission up to 10Mbit
  • #5 17048041
    mbo
    Help: 2333
    Rate: 845
    I used to test some RJ45 converters - TV cable.
    The 10 Mb / s version even worked, the 100 Mb / s version did not really want to work.
    But I don't remember what it was called or who made it.
    Currently something like this:
    http://televesdystrybutor.pl/nadkuje-odbiorni...1gbps-hdvt-1zlacza-ethernet-i-2-zlacza-f.html
    What I tested was passive (without power).
    You can search for "ethernet coaxi adapter".
    Unfortunately, it's not cheap ...
  • #6 17048656
    KOCUREK1970
    Help: 3862
    Rate: 5490
    These are called MOca converters.
    https://www.youtube.com/watch?v=gIKIMk6s5Yw
  • #7 17048706
    sanfran
    Help: 963
    Rate: 3004
    Radiosonic ICY BOX IB-CX110-110-Kit, tested, works on 100 MB, uses a 75 Ohm cable (this is the specification and I used it) and does not require tees and terminators that were needed for the BNC connection. In the specification, the maximum distance is 200 meters, in my case it was about 25 meters.
  • #8 17049077
    makosuu
    Help: 369
    Rate: 370
    I will leave without a comment ... During construction / major renovation, it is even a duty to lay the twisted pair ... Now you can save yourself with PLC adapters but the costs are much higher than the twisted pair, especially if the transfers are to be made of twisted pair.
  • #9 17049261
    tata1
    Help: 43
    Rate: 260
    Gentlemen
    Each of us presented different views on the concentration, the author of the thread already has a view as such, but somehow he does not express himself.
    It seems to me that, after all, BNC made in a modern and professional manner is a very high cost if there are a lot of rooms (points). It will be easier to apply the solution proposed above, i.e. LAN via network sockets - there are adapters on the market after all.
    Or maybe it can be done quite simply with minor modifications - that is, use the skirting boards and pass under the skirting boards under the door. Maybe the ceiling is suspended, or the walls are made of gypsum boards - it sounds a bit unprofessional, but it gives a lot of room for maneuver and reduces the breaking of fresh walls.
    A few posts have accumulated, let the author comment.
    Maybe wi-fi after all?
  • Considering twisted pair or PowerLine instead of hub distribution
    #10 17049491
    PawelKce
    Thank you for all your comments.
    Now I am sure that it will be best to abandon this solution with a concentrate.
    However, I will go with a twisted pair, a wooden ceiling with plasterboard, so it will go somehow.
    A 2-year-old house and I agree that such wiring is laid immediately during construction, so why not put it?
    Only recently did I realize what is happening now, everywhere Wifi, bluetooh etc. In a word, we served ourselves a global microwave. Probably not everyone will agree with me or say that I am exaggerating, but I have two small children and I prefer to play with the cable by the laptop.
    Added after 12 [minutes]:
    I will also consider PowerLine. Also not a stupid solution.
  • #11 17050682
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Only this can not be covered with one set (2 pieces in the set), and with more users using one point at the router, the network performance will be headlong.
  • #12 17050714
    m.jastrzebski
    Help: 679
    Rate: 865
    | As you say "microwave" is global. Your WiFi on or off, unfortunately, will not make a big difference. A neighbor will turn on a Chinese USB card bought on the Allegro that exceeds the power standards 10 or 20 times and all your actions are about the edge of your butt :-( You would have to build a faraday cage instead of a house. Search for the list of radio links in PL and open in google earth. You'll turn gray. In addition, you have GPS, TV, satellite TV, cell phones (often by your ear !!), all wireless cameras, remote controls, weather radars. and what is not there yet.
    In short. As long as you do not sleep with your head on the WiFi router with overclocked power, you should not worry about it. That's my opinion.
    And switching to a cable has one major advantage. No WiFi will give you the speed and stability of a cable. You connect everything you can with cables. WiFi is how the device must move.
  • #13 17051322
    PawelKce
    I agree with you, WiFi, masts, transmitters are everywhere and it cannot be avoided anymore and digitization is progressing more and more. On the other hand, if you can cut something off within your reach, it's always something. If I lived in a block of flats, I would have several Wifi networks available from my neighbors. At home, after turning off Wifi, the neighbors have no influence anymore.
  • #14 17051491
    makosuu
    Help: 369
    Rate: 370
    That's an understatement? Rather a few dozen minimum.
The discussion revolves around the feasibility of distributing a LAN connection from a router through existing coaxial cable infrastructure in a home. The original poster seeks to avoid installing new twisted pair cabling due to the recent renovation of their house. Responses suggest that while coaxial cable can be used, it is often outdated and expensive. Alternatives such as Ethernet over coaxial adapters (e.g., MOCA converters) and PowerLine adapters are recommended. Some users share experiences with specific devices that can facilitate this setup, while others emphasize the advantages of wired connections over WiFi for stability and speed. Ultimately, the original poster decides to proceed with installing twisted pair cabling despite initial hesitations.
TL;DR: Yes—Ethernet-over-coax can work. 10 Mb/s passive baluns worked, 100 Mb/s struggled; "Unfortunately, it's not cheap..." Use modern coax adapters or pull Cat5e/6. [Elektroda, mbo, post #17048041]
Why it matters: For homeowners with TV coax in walls, this helps you get wired LAN without tearing up fresh plaster.
Can I distribute LAN over my existing TV coax?
Yes, using Ethernet-over-coax adapters that bridge Ethernet onto TV-grade coax. Passive 10 Mb/s baluns worked, while 100 Mb/s struggled. Modern powered kits exist and target higher rates. "Unfortunately, it's not cheap..." [Elektroda, mbo, post #17048041]
Do I need 50Ω or 75Ω cable for this?
Legacy BNC Ethernet requires 50Ω coax, not the 75Ω TV coax common in homes. That mismatch rules out classic BNC networking on TV cabling. Consider modern Ethernet-over-coax solutions instead. [Elektroda, tata1, post #17047369]
Will 100 Mb/s work over 75Ω TV coax?
Yes, with the right kit. The Radiosonic ICY BOX IB-CX110-110-Kit was tested at 100 Mb/s on 75Ω cable. The specification lists a maximum run of 200 meters, and no BNC-style tees or terminators are needed. [Elektroda, sanfran, post #17048706]
What speeds can I expect from Ethernet-over-coax today?
Some systems referenced in the thread advertise up to 1 Gbps on 75Ω coax. Passive adapters deliver far less. "Unfortunately, it's not cheap..." Budget accordingly for active gear. [Elektroda, mbo, post #17048041]
Are passive RJ45-to-coax adapters worth trying?
Only for very low bandwidth needs. 10 Mb/s passive units worked in tests, but 100 Mb/s did not. For modern broadband and stability, use powered Ethernet-over-coax or pull Cat5e/6. [Elektroda, mbo, post #17048041]
What are MoCA converters?
MoCA converters are Ethernet-over-coax adapters that carry LAN traffic over existing TV coax. They let you avoid opening walls. “These are called MOca converters.” [Elektroda, KOCUREK1970, post #17048656]
How does Powerline (PLC) compare to coax adapters?
PLC uses your electrical wiring and can be easy to deploy. However, one kit covers only two endpoints, and adding more users at one router point slashes performance. Plan for the throughput trade-off. [Elektroda, KOCUREK1970, post #17050682]
Is it better to pull new Ethernet cable instead?
Yes, when you can. “During construction / major renovation, it is even a duty to lay the twisted pair.” PLC adapters also cost more than cabling for comparable performance. [Elektroda, makosuu, post #17049077]
How can I retrofit Ethernet without damaging fresh walls?
Use low-impact paths and finishes. "It gives a lot of room for maneuver" while reducing wall breaking.
  1. Route behind skirting boards and pass under door thresholds.
  2. Pull cable above any suspended ceilings to cross rooms.
  3. Leverage gypsum board construction where present to simplify routing. [Elektroda, tata1, post #17049261]
Will turning off Wi‑Fi at home reduce exposure?
It won’t change the broader radio environment around you. “As long as you do not sleep with your head on the WiFi router, you should not worry.” Prefer cables for performance: “No WiFi will give you the speed and stability of a cable.” [Elektroda, m.jastrzebski, post #17050714]
Can I plug coax adapters into my existing router?
Yes. You connect the adapter or BNC switch to a router LAN port, and it sends the signal over coax to endpoints. [Elektroda, tata1, post #17047369]
How many rooms can I serve over coax?
You’ll need star-capable hardware and per-room converters to RJ45. Such devices exist, but they’re not cheap, so costs rise with more rooms. [Elektroda, tata1, post #17047369]
Any pitfalls with old BNC networking?
Yes. Gear is hard to find and slow. “You will not buy this equipment on BNC … max transmission up to 10 Mbit.” Choose modern Ethernet-over-coax or new twisted pair. [Elektroda, mieszaczwcz, post #17047381]
