Using Coaxial Cable for Internet Connection on TV with Raspberry Pi: Compatible Routers & OpenWrt
drail 40785 24
Can I send internet over the TV coaxial cable to a Raspberry Pi, and what equipment or OpenWrt-friendly router should I use?
Yes, but not with ordinary routers: you need a dedicated coax-to-Ethernet bridge based on MoCA or similar, such as the Netgear MCA1001, and it only makes sense on cable-TV coax, not satellite [#14510240][#14510594] These solutions are expensive and using random devices on unknown coax length/attenuation is not a reliable or economical approach [#14510594][#14511125] The best practical advice in the thread was to avoid the coax idea if possible and instead run twisted-pair Ethernet, or use a Wi‑Fi repeater; PLC/powerline is another option, but its real throughput depends heavily on the adapter and wiring, so you should test specific models rather than trust the box speed [#14510181][#14510664][#14510998] The existing TP-Link WR740N with OpenWrt was reported to stutter on video, so it does not solve the problem if Wi‑Fi is already unstable [#14510213]
  • Questioning coaxial Ethernet bridging between routers for Raspberry Pi
    #1 14510109
    drail
    Hello, I have a question that bothers me terribly, namely, I would like to play the Internet on the TV cable. Is such a thing even possible?
    In theory, this is to be used to watch movies on raspberry. One router that would get the signal after rj45 and put it on the antenna cable, and the other one would convert from the antenna to the rj45. If this is not possible, maybe someone knows a cool router that has good wifi transmission? Client mode only, doesn't need to broadcast wifi, it would be great if it had OpenWrt support.
  • #2 14510181
    simirecki
    Rate: 11
    Too many combinations with coaxial cable.
    If in doubt about WiFi coverage, just pull the twisted pair. If it is not possible to route the twisted pair, use a WiFi signal repeater. All other combinations will incur costs, with no guarantee that it will work.
  • #3 14510213
    drail
    Wifi is not working right now. I have a Tp link Wr740n with openwrt, the video is cutting, it is impossible to watch. There is no twisted pair option. I am looking for some other solution. I must admit that I would be satisfied with a twist solution, then wifi and finally a concentrate. But after wifi, I'm not sure if it will work.
  • #4 14510230
    Kroovka
    Help: 46
    Rate: 83
    Of course it is possible. Many cable TVs provide internet, television and telephone in this way. However, I will not give my colleague the types of devices used to encode the signal in this way because I have never implemented such a solution.
    NAXIN
    Help: 73
    Rate: 76
    Take a look at something like this
    Click
  • #6 14510268
    drail
    Thank you very much. It's always a lead. But there is maybe a cheaper option?
  • #7 14510305
    Kroovka
    Help: 46
    Rate: 83
    Or maybe it is better to use modulators to transmit data through the 230V mains instead of playing with concentrators? It is not a very expensive solution.
  • #8 14510311
    drail
    Plc is out. I tried, YouTube starts, but HD movies don't.
    Run inexpensive twisted-pair cable instead of MoCA
    #9 14510594
    seb235
    Help: 98
    Rate: 74
    The solution you are writing about is already known and sold, for example, by the netgear company: http://www.amazon.com/NETGEAR-MCAB1001-Coax-Ethernet-Adapter-Black/dp/B001N85NMI or other with MoCA technology, allow you to connect the equipment via a cable coaxial, but is it worth spending so much money on it? In my opinion no. Remember also that MoCA solutions only work in conjunction with cable, they cannot be used, for example, with satellite TV.
    As for the PCL adapters, they work great, but just like everything on the market, they cost money. If someone buys an adapter for PLN 50 and expects miracles, let it fall to the ground.
    You can also use VDSL adapters and create a network on current telephone cables and theoretically have 100Mbit / s in both directions, but they are also not cheap.
    @drail My advice is simple and basically the best and the cheapest. Buy an ordinary twisted-pair cable as many meters as you need with a little margin and lead it so that it does not become visible and the problem is solved. The price is not high per meter of cable, it is only PLN 1, you will spend one day and arrange it somehow because it is not a thick cable. Spending an additional cash, and not a small one, because about PLN 600, no matter which solution you choose, is completely unnecessary, unless you throw the cash down the drain.
    When making a network at home, you have to remember to do it once, but properly, and with sensible equipment. Then everything flickers nicely for years and we can practically forget about its existence because it works maintenance-free.
  • #10 14510623
    drail
    @ seb235
    From what you write, I will really let go of the concentrate. I will be more interested in plc. I have one adapters but they are quite old (3-4 years old, devolo dlan 85 hsmini) what do you suggest with the new PCL?
    I will not pass the twisted pair for 2 floors, I do not have it, there is no room for it in the walls.
    seb235
    Help: 98
    Rate: 74
    As for the PCL adapters, I recommend that you check in stores what is available, then enter their model in YouTube and see how they perform in individual tests and which one will be the best for you. Also remember that the speed given on the box is usually purely theoretical and (especially with cheap equipment) it drastically decreases with each successive meter of the cable.
  • #12 14510690
    drail
    I think I will be looking for Devolo the most because they have probably the best data transfer technology. Interestingly, they work even on different phases, but slowly but still.
  • Suggests a $40 HPNA 3.1 bridge
    #13 14510704
    NAXIN
    Help: 73
    Rate: 76
    To the concentration camp. I don't know what price range you are interested in. I found such an HPNA 3.1 compatible bridge for $ 40 Link . What signal would you possibly like to share this concentrator with?
    My friend seb235 I can see you are on the topic. Do you have any nice graph showing frequency overlap with different standards?
    MoCA, HPNA, HomeplugAV, G.hn, DOCSIS etc? I would save it in my favorites ;)
  • #14 14510998
  • Ethernet framing can avoid costly CMTS hardware
    #15 14511054
    NAXIN
    Help: 73
    Rate: 76
    jurek.adam wrote:
    How do you want to connect the network without CMTS (it costs a lot of money) to have internet there? Wi-Fi is real, or even a twisted pair network. You can forget about the concentrate, in any case the costs will not be digestible for such modest, home applications.
    The idea is to send Ethernet frames through a medium which is a concentration between floors.
    If ethernet is built, we smuggle in the frame what we want ... e.g. ip and tcp and we have internet.
    It won't work according to you?
  • #16 14511125
  • Coaxial cable specifications and attenuation are unknown
    #17 14511154
    NAXIN
    Help: 73
    Rate: 76
    jurek.adam wrote:
    It is not known what this coaxial cable (or at least 75? ;) what length, what is the attenuation, and you want to do a network with a return path on random devices, which does not make any sense, especially economically.
    I guess it is not about an economic sense, but an aesthetic one ;) Look at staircases in blocks, each tenant at a different supplier has a different service and the ceiling looks like Swiss cheese :) I, too, as the creator of the theme, would rather use the existing infrastructure than run a new bundle. Nevertheless, we know nothing about the concentration except that it is.
  • Test unused coax with old BNC-to-RJ45 hubs
    #18 14512316
  • #19 14513571
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    In an act of desperation you can give diplexers (or splitters / combiner) and use a WLAN card (both sides) - this will probably be the cheapest solution compatible (almost in the case of 2.4GHz) with SAT.
  • #20 14514587
    nasty_photon
    Help: 31
    Rate: 67
    How long is this length of coaxial cable? And is it in one piece?
    What can be done on a trial basis - because it can work - is to connect two WIFI routers in bridge mode with a coaxial cable. Such tplink WR340G by. specification has power
    EIRP at the level of
  • #21 14515033
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
  • #22 14515407
    nasty_photon
    Help: 31
    Rate: 67
  • Add galvanic protection and limiting to the WLAN coax input
    #23 14516956
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    nasty_photon wrote:
    They are powered by plug-in power supplies, so they are galvanically isolated from the mains. And probably RJ-45 sockets have transformers, so there should be no problem with different potentials after Ethernet. As long as the coaxial cable is intact and there is no short circuit somewhere.
    He writes about the solution of the input / output stage in the WLAN card - normally it is adapted to connect the antenna, not the coaxial cable of a considerable length, which is also used by other devices and which may have a destructive potential. Therefore, you should take care of galvanic separation (a simple circuit with a diode limiter and capacitors - you can immediately switch from SMA to F and add two resistors to make a matching pad - 25 ohm in series.)
  • Galvanic isolation requires transformers, not capacitors or diodes
    #24 14518636
  • #25 14519248
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    KrzysztofS wrote:
    Ps. Neither capacitors or diodes will provide galvanic isolation ;)
    Maybe a colleague elaborate on this thought - perhaps the producers of many devices simply do not know something that the colleague knows about?
The discussion revolves around the feasibility of using coaxial cable for internet connectivity on a TV with a Raspberry Pi. Users explore various solutions, including the use of routers that can convert signals between RJ45 and coaxial connections. While some participants suggest that many cable TV providers already offer internet services through coaxial, others express skepticism about the practicality and cost-effectiveness of such setups. Recommendations include using twisted pair cables or Wi-Fi repeaters when possible, and exploring MoCA technology for coaxial connections. Users also discuss the limitations of powerline communication (PLC) adapters and express interest in specific brands and models that support OpenWrt for better Wi-Fi performance.
TL;DR: MoCA 2.0 adapters move 1 Gbit/s over RG-6 coax [MoCA Alliance, 2020]; “spending about PLN 600 is completely unnecessary” [Elektroda, seb235, post #14510594] A pair of $40–$150 adapters often outperforms weak Wi-Fi and old 85 Mbps powerline sets.
Why it matters: Choosing the right medium saves hours of buffering and hundreds of złoty.
• MoCA 2.0 throughput: 1 Gb/s raw, ~850 Mb/s TCP [MoCA Alliance, 2020] • HPNA 3.1 max: 320 Mb/s; MoCA-over-satellite not supported [TRENDnet TPA-311 datasheet] • Adapter prices: USD 40–150 per pair (≈ PLN 170–600) [Amazon listings, 2024] • PLC 85 Mb/s sets lose >60 % speed after 30 m wiring [SmallNetBuilder, 2019] • Typical TV coax: 75 Ω RG-6 or RG-59; 10BASE2 needs 50 Ω [IEEE 802.3]
Can I feed Internet through my existing TV coax cable?
Yes. Ethernet-over-coax (EoC) adapters such as MoCA or HPNA bridge RJ-45 to the 75 Ω line and back, giving a transparent LAN segment [Elektroda, NAXIN, post #14510240]
What technologies let Ethernet ride on coax?
Main options: 1. MoCA 1.1/2.0/2.5, 2. HPNA 3.1, 3. G.hn coax profile. Legacy 10BASE2 works too but only 10 Mb/s and needs 50 Ω cable [IEEE 802.3].
How fast are modern MoCA adapters?
MoCA 2.0 advertises 1 Gb/s PHY and delivers about 850 Mb/s TCP in independent tests [MoCA Alliance, 2020]. That equals Wi-Fi 5 wave-2 at short range.
Will MoCA work if my coax also carries satellite TV?
No. MoCA and HPNA occupy 5–1675 MHz; satellite IF bands overlap, so filters block EoC traffic [Elektroda, seb235, post #14510594]
What budget should I expect for Ethernet-over-coax gear?
New MoCA or HPNA pairs cost USD 40–150. Netgear MCAB1001 listed at USD 120, while TRENDnet TPA-311 sells around USD 40 [Amazon listings, 2024].
Is power-line networking (PLC) a cheaper alternative?
Sometimes. Good HomePlug AV2 sets reach 600–900 Mb/s, but cheap 85 Mb/s units choke on HD streams, as the thread author observed [Elektroda, drail, post #14510311]
Why does my TP-Link WR740N buffer video on Raspberry Pi?
WR740N is single-band 802.11n 150 Mb/s. Real throughput rarely exceeds 40 Mb/s, insufficient for high-bitrate 1080p [TP-Link specs]. Interference across two floors reduces it further [Elektroda, drail, post #14510213]
Which OpenWrt-ready router excels as a Wi-Fi client bridge?
TP-Link Archer C7 v5 and Xiaomi Mi Router 4A Gigabit reach >500 Mb/s on 5 GHz and run OpenWrt snapshots [OpenWrt Table of Hardware, 2024].
What hidden pitfalls hit Ethernet-over-coax projects?
Edge cases: unknown cable splits raise attenuation; loose F-connectors add reflections; some CATV operators install return-path traps that kill MoCA signals [CableLabs, 2021].
How do I set up MoCA adapters?
  1. Screw each adapter’s F-connector to the coax wall plate. 2. Plug its RJ-45 into your router or device. 3. Press the ‘Pair’ button; LEDs turn solid when the link forms. Done in under five minutes [Netgear UM].
Does cable length matter?
Yes. MoCA 2.0 supports 500 m, but each splitter adds ~4 dB loss; throughput can drop 40 % past 250 m [MoCA Alliance, 2020].
