[Solved] Best SSD Under PLN 200: Crucial BX300, Goodram IRDM, Intenso, Patriot Burst or Other MLC Models?
stalowarura 3774 8
  • #1 17079155
    stalowarura
    Hello. As in the subject, I'm thinking of buying an SSD up to PLN 200. The problem is that there are a lot of these tests and I got lost in it all. With help I came to the forum with the following question, which drive is the most profitable / will be the fastest? You can choose from this Crucial BX300, Goodram IRDM, Intenso, Patriot Burst. Unless you recommend something different on MLC bones up to PLN 200. I want it to be as fast as possible at this price. Greetings!
  • #2 17080083
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Hi. BX300 seems to be more efficient than GoodRAM IRDM. The warranty is both 3 years old, the BX300 has a TBW limit of 55 TB (120GB version), for GOODRAM I did not find the TBW limit, so either it is missing or I have not looked for it well). Under normal use, the TBW limit should not be an obstacle, although I'm wondering about such a low TBW limit for a disk with MLC memories. I didn't have Intenso disk or Patriot Burst in my hand, so it's hard for me to compare. Of the cheap MLC disks, you can also take into account the A-data SP920 128GB, a disk on a Marvell controller and MLC memories.
  • #3 17080135
    qs300
    Help: 242
    Rate: 362
    GoodRam CX300 has slightly better parameters than Crucial BX300, has a higher write speed.
  • #4 17080203
    dt1
    Help: 7319
    Rate: 8299
    CX300 has better parameters only on the packaging. This is the same controller as in GoodRAM IRDM, except paired with quite poor performance TLC memories. It's worth checking out some real CX300 benchmarks - it usually closes performance rankings at the bottom.
  • #5 17080474
    stalowarura
    So it turns out that the best choice in this amount will be this Crucial BX300 or an additional payment to A-data SP920? Thanks for the answers.
  • #6 17080536
    dt1
    Help: 7319
    Rate: 8299
    SP920 is a fairly safe choice, although you will not achieve such write speeds on it as on the BX300.
  • #7 17081221
    stalowarura
    I still have doubts about the value of IOPS. Does it matter? Because in Adata the reading is 90,000 and Crucial reading 45,000. Theoretically, it seems to me that reading is more important but I can be wrong. I am waiting for a response.
  • #9 17081595
    stalowarura
    Thank you for the answers, You can close the topic. Regards!
    Added after 50 [seconds]:
    I chose Crucial bx300.
The discussion centers around selecting the best SSD under PLN 200, with a focus on models such as Crucial BX300, Goodram IRDM, Intenso, and Patriot Burst. Users compare the performance and specifications of these drives, noting that the Crucial BX300 is generally regarded as more efficient than the Goodram IRDM, despite both having a 3-year warranty. The A-data SP920 is also mentioned as a viable alternative, although it may not match the write speeds of the BX300. The importance of IOPS (Input/Output Operations Per Second) is debated, with users encouraged to research its significance. Ultimately, the author decides to purchase the Crucial BX300 based on the feedback received.
