Kubota D1105 Engine Bolt Tightening Torques: E-TVCS D221, 3-cyl 24HP, 1123cm^3 - Specs & Details
Megawe 20829 2
  • Kubota D1105 torque specs and valve clearances
    #1 17049593
    Megawe
    Help: 246
    Rate: 1438
    Engine KUBOTA D1105 - D221, E-TVCS, 3 - cyl. 24.0 HP, 1123 cm ^ 3, Cyl. 78 mm, stroke 78.40 mm.
    Head cover nut - M7 × 1.0 - 7 -8 Nm
    Injection tube fixing nut - M12 × 1.5 - 25 - 34 Nm
    Nozzle holder assembly - M20 × 1.5 - 49 - 68 Nm
    Nozzle holder - 35 - 39 Nm
    Overflow pipe fixing nut - M12 × 1.5 ......... 20 - 24 Nm
    Glow plug M8 × 1.0 - 7.9 - 14 Nm
    * Rocker arm bracket nut - M7 × 1.0 .................. 22 - 26 Nm
    * Head bolts - M10 × 1.25 ........ 64 - 68 Nm
    screw securing the fan drive pulley - M14 × 1.5 .......... 236 - 245 Nm
    * Connecting rod bolt - M8 × 1.0 ....... 42- 46 Nm
    * Flywheel bolt - M12 × 1.25 ........... 54- 58 Nm
    * Main bearing case screw 1 - M8 × 1.25 ......... 30 - 34 Nm
    * Main bearing case screw 2 - M9 × 1.25 ................. 49 - 53 Nm
    Bearing case cover mounting screw - M6 × 1.0 ..... 9.81 - 11.2 Nm
    Compression - 3.73 - 4.11 MPa, min. 2.26 MPa
    Valve clearance - 0.145 - 0.185 mm
    Injection angle 16 * - 18 * before TDC
    Injection pressure - 13.73 - 14.70 MPa
  • #2 17051823
    Megawe
    Help: 246
    Rate: 1438
    KUBOT D1105 engine manual in English.
    • 2KUBOT-ENGINE.7z (3.64 MB) You must be logged in to download this attachment.
    • 1KUBOT_ENGINE.7z (1.33 MB) You must be logged in to download this attachment.
  • #3 17054405
    Megawe
    Help: 246
    Rate: 1438
    D1105 engine parts catalog
    • Katalog_czesci_D1105.7z (2.37 MB) You must be logged in to download this attachment.
