[Solved] Autocad 2016: Menu Disappeared after Removing Start Tab, Restore to Default (RibbonBgClose)
moher40 12753 5
  • RIBBONBGCLOSE removed the AutoCAD menu bar
    #1 17050611
    moher40
    Rate: 27
    I fight for the second day and nothing.
    In Autocad, I wanted to remove the tab called START, which always appears after startup, and make sure that Autocad from the automatic machine turns on by default always in NEW DOCUMENT mode.
    I found a quick mini description on the net and cut something.
    They ordered to enter in the console: RIBBONBGCLOSE
    The tab has disappeared but the MENU has also disappeared and now CAD looks like this:
    I have no idea how to restore it and I would like it to look like after installation:
    kozi966
    Help: 599
    Rate: 1288
    Enter the command: Ribbon
  • #3 17052267
    moher40
    Rate: 27
    It does not respond, that is, it does not recognize RIBBON and automatically switches to RIBBONLOAD and asks for a new value. Current value 1. Value 0 does not change anything.
    And there are no RIBBONON, RIBBONBGOPEN etc. commands :cry:
    kozi966
    Help: 599
    Rate: 1288
    In that case, all that remains is the option to reset the autocad to the initial settings.
    Start -> Autodesk -> Reset settings to default.
    PS
    moher40 wrote:
    RIBBONLOAD
    And not RIBBONBGLOAD? but it doesn't matter.
  • #5 17052419
    moher40
    Rate: 27
    Ribbonload = unknown command
    It helped. I never looked in the bar and didn't even know the reset was there. I was looking for it in the program menu.
  • #6 17052540
    moher40
    Rate: 27
    Added after 1 [hours] 9 [minutes]:
    Restore settings.
