Autocad 2016 - How to disable start page and other cumbersome features
moher40 10881 4
  • #1 17052543
    moher40
    Rate: 27
    The things that annoy me are:
    Autocad 2016 - How to disable start page and other cumbersome features Autocad 2016 - How to disable start page and other cumbersome features
    I would like CAD to always run without the START page in the NEW DRAWING (empty) mode and I would like to get rid of this window CANNOT LOAD ADDRESS ...
    Where to find these settings?
    Turning off the START PAGE supposedly helped with the RIBBONCLOSE command, but then the entire menu disappeared.
  • #2 17052579
    dedito
    Help: 527
    Rate: 595
    The variable is responsible for the beginning tab " STARTMODE ", set it to 0 and restart.
  • #3 17052701
    moher40
    Rate: 27
    STARTMODE: 0 causes CAD to turn on with blank card, gray desk. You have to manually select NEW DOCUMENT and only then the MENU and the rest appear.
    Is it possible to make the NEW EMPTY document start right away?
    dedito
    Help: 527
    Rate: 595
    Pobaw się zmienną STARTUP .
    Value
    Description
    0
    Starts a drawing without defined settings.
    1
    Displays the Startup or the Create New Drawing dialog box.
    2
    The Start tab is displayed. If available in the application, a custom dialog box is displayed.
    3
    The Start tab is displayed and the ribbon is pre-loaded when you open or create a new drawing.
  • #5 17053147
    moher40
    Rate: 27
    Ok, it worked. I had STARTUP-3, I did 0 and it is as it should be, i.e. like this:
    Cad starts right away with a new drawing and it's ok but you can still see the START tab next to it, you can see this:
