CS GO Problem: Unable to Connect to Server, Stuck Searching for Match, Can Only Play with Bots
michal24241313 9477 6
  • #1 17052509
    michal24241313
    Welcome.
    I have a problem with CS go. I can't join the game. Still searching for a match. I can only play with bots. Reinstallation checked the consistency of the game did not help. What to do?
  • #2 17052532
    procsa
    Help: 173
    Rate: 364
    Check in the game settings the maximum acceptable PING, maybe you accidentally set it too low.
  • #3 17052536
    michal24241313
    Although I set the highest, it did nothing. I played normally yesterday.
  • #4 17052547
    procsa
    Help: 173
    Rate: 364
    Well, you have to wait, sometimes it is just that and it is independent of you ... provided that the internet works properly for you :)
    Alternatively, download the MM picker server and check the pings from each other to the steam servers.
  • #5 17052551
    michal24241313
    Could it be because I have a low rank?
  • #6 17052636
    procsa
    Help: 173
    Rate: 364
    No, or if you're looking for a match on a small map.
  • #7 17052728
    michal24241313
    I take any map. Same.
The user is experiencing connectivity issues in CS:GO, being unable to join matches and only able to play against bots. They have already reinstalled the game and checked its integrity without success. Suggestions from other users include checking the maximum acceptable PING settings, waiting for server availability, and using the MM picker server to test pings to Steam servers. The user inquired if their low rank could be a factor, but responses indicated that rank should not affect match availability, especially when selecting any map.
