CS GO Jams: Game Freezing Issues on Proper Computer, 150fps, Latest Drivers, Cleaned PC
Yellow19 21297 9
Why does CS:GO freeze on a computer that otherwise runs the game at around 150 FPS, with the latest drivers and a cleaned system, and how can I fix it?
CS:GO is probably not freezing because of overheating or throttling here; the logged data showed the CPU staying under 64°C, the GPU about 10°C hotter, no clock drops, and RAM/disk usage looking normal [#16819624] [#16819727] Check Steam’s file integrity, reinstall the game if needed, and make sure your startup commands and multicore rendering are set correctly [#16820843] The graphics card is also a likely bottleneck, because the GTX 260 is already loaded almost to 100% during play [#16819727] [#16821008] Since the card is old and the issue persists after reinstalling and checking files, upgrading the GPU is the most likely remaining fix [#16821655]
  • #1 16819600
    Yellow19
    So yes, let's start with the fact that when I play CS GO, the game cuts out from time to time. The computer is good and calmly copes with the game, on average I have 150fps. It was formatted, has the latest drivers installed, and was all cleaned (dust). After these treatments it is exactly the same, I don't have any unnecessary applications and no other processes are connected during the game. I don't know what to do anymore, I read a lot of posts but still nothing works. Please help
  • #2 16819624
    dt1
    Admin of Computers group
    Help: 7320
    Rate: 8306
    Welcome. Enter the computer configuration (key components) and temperature under load Download and run hwinfo: https://www.hwinfo.com/download.php in sensors only mode, start logging in (icon on the bottom right), having the program in the background play 10-15 minutes, exit the game, wait 2-3 more minutes, finish logging in, upload the log file here).
  • #3 16819686
    Yellow19
    When I want to add, an illegal extension pops up.
  • #4 16819695
    dt1
    Help: 7320
    Rate: 8306
    Pack it into a zip or rar and then join.
  • #5 16819699
    Yellow19
    Graphics Card: GTX 260
    Motherboard: ASUS P8H61-M PRO
    Ram: 8GB
    Processor: Inetel Core i5 4x3.1ghz
    • cs.rar (43.84 KB) You must be logged in to download this attachment.
  • #6 16819727
    dt1
    Help: 7320
    Rate: 8306
    There is nothing disturbing in the logs. The processor did not exceed 64 degrees, graphics 10 degrees more (but for GTX 260 it is not a tragedy). Neither the processor nor the graphics lowered clock speed during the game. The RAM and disk occupancy did not indicate that the problem was on their side. The only thing you can see is the fact that the graphics are loaded almost to the maximum during the game (the processor still has a spare power).
  • #7 16819748
    Yellow19
    Approx. What would I do to fix it? Or use all the processor power and unload the graphics card?
  • #8 16820843
    kukiz87
    Rate: 26
    And you did not think maybe to try to check the consistency of the game files by steam, possibly install the game again? and as a last resort you can do the format and try. Believe me, cs go is a strange game and it also works differently for me, sometimes better and worse fps are jumping like crazy at times.
    And also remember about startup commands, because you haven't written anything or you have multicore rendering on it
  • #9 16821008
    enhanced
    Help: 964
    Rate: 884
    And what are you up to - the gtx 260 is already a monument - what to require from the card since it already flies 100% and it inhibits performance?
  • #10 16821655
    Yellow19
    I have enabled this option in the startup parameters. I do not require that on this graphics card it was 300fps, only 80 is enough for me, the point is not to get into the game because it bothers a lot, and I play at a high level. I checked the consistency of the files, reinstalled and nothing. At most, I am left with nothing more than buying a new card.
The discussion revolves around a user experiencing game freezing issues while playing CS:GO, despite having a capable computer that averages 150fps. The system has been formatted, equipped with the latest drivers, and cleaned of dust. The user provided their hardware specifications, including a GTX 260 graphics card, ASUS P8H61-M PRO motherboard, 8GB RAM, and Intel Core i5 processor. Responses suggest checking the game's file integrity via Steam, reinstalling the game, and considering the limitations of the aging GTX 260, which may be maxing out under load. The user has already enabled multicore rendering and checked file consistency, indicating that a hardware upgrade might be necessary.
