CS: GO Not Starting: Intel Pentium G3258, ASRock H81M VG4, 8GB DDR3, Integrated GPU, Win10 Pro
kompsev21 31071 10
How can I make CS:GO start on Windows 10 when Steam briefly shows it as running and then closes immediately?
Check the integrity of CS:GO’s game files in Steam, then open csgo.exe properties and set it to run in Windows 7 compatibility mode and as an administrator [#17026373] If needed, also run GPU-Z and share a screenshot of the GPU details [#17026373] The original poster reported that after doing these steps, the game worked [#17030326]
  • #1 17025215
    kompsev21
    Hello, I have a problem with CS: GO, when I click play on the steam it shows up a small window, then disappears and for a moment next to the name Counter Strike Global Offensive writes running.
    My specification is:
    CPU: intel pentium g3258 4.2 GHz
    MOBO: ASrock H81M vg4
    RAM: 8GB 1333MHz DDR3
    GPU: integrated, because there are several videos on YT that you can play on a decent FPS on an integrated CPU
    POWER SUPPLY: 550W Thermaltake modular
    SYSTEM: Windows 10 pro 64
    Please help :)
  • #2 17026373
    atomic99
    Help: 171
    Rate: 338
    In the STEAM list, click PM on CS: GO and select Properties, then the tab "Local files" and "Check consistency of game files"
    How to check and it will be all right, then click on "Browse local files", click PM on the file "csgo.exe" tab "Compliance", select "Run this program in compatibility mode with:" select Windows 7 and select "Run" at the bottom this program as an administrator "
    Download the program "GPU-Z" , run, make a screen and insert.
  • #3 17030326
    kompsev21
    Thanks, I did everything and work a lot thanks for your help
  • #4 19034320
    galanonim77
    Rate: 8
    and what to do in case of the same problem on mac?
  • #5 19034326
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    Same as the author of the thread?
  • #6 19041453
    galanonim77
    Rate: 8
    yes, the same
  • #7 19041459
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    @ galanonim77 if you also have steam, you have to do the same, and not respond.
  • #8 19041463
    galanonim77
    Rate: 8
    I have steam, but the problem is on the mac. on it I can not perform all the recommended actions. I can only check the compatibility of files which is not helping me anyway.
  • #9 19041468
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    What's your system? Tried to remove Steam and CS: GO and reinstall?
  • #10 19048159
    reg80
    What is the difference between CS 1.6 and this Global Offensive?
  • #11 19050809
    atomic99
    Help: 171
    Rate: 338
    @ reg80 Mainly in graphics, requirements, physics, maps, weapon skins + a few other crap to make money, it's all in CS: GO
The user experienced issues with CS: GO not starting on their system, which includes an Intel Pentium G3258 CPU, ASRock H81M VG4 motherboard, 8GB DDR3 RAM, integrated GPU, and Windows 10 Pro. A suggested solution involved verifying the integrity of game files through Steam, setting compatibility mode for the CS: GO executable to Windows 7, and running it as an administrator. The user confirmed that these steps resolved the issue. Additional inquiries about similar problems on Mac systems were raised, but the solutions provided were specific to Windows.
