AMD graphics card does not work - AMD Radeon 8570M graphics card does not work
lokipok 8259 3
  • #1 17053305
    lokipok
    Hey, I have a problem, namely the AMD Radeon 8570M graphics card has stopped working for some time in my laptop Lenovo g500 (win 10 64bit). I thought it was the fault of the drivers so I removed the old ones, installed the latest from the AMD website and still the same. I get such errors. AMD graphics card does not work - AMD Radeon 8570M graphics card does not work AMD graphics card does not work - AMD Radeon 8570M graphics card does not work AMD graphics card does not work - AMD Radeon 8570M graphics card does not work AMD graphics card does not work - AMD Radeon 8570M graphics card does not work
    roxio
    Help: 108
    Rate: 213
    In a nutshell, the 8570M card in combination with your processor is no longer supported by AMD has gone into the so-called "Legacy" mode, so what? A driver with a higher number than the one that officially released AMD is downloaded from the Windows update site for Windows 10 and replaced by "basic screen driver", i.e. as if the driver was almost gone :) In addition, there are other drivers that interact with it that have been muttering since the Windows 10 autumn update.
    What can you do?
    First of all, disable automatic driver updates on your system from the WU website.
    https://www.download.net.pl/jak-wylaczyc-automatyczna-instalacje-lub-aktualizacje-sterownikow-przez-windows-update/n/7020/
    https://www.dobreprogramy.pl/Wylaczamy-automatyczna-instalacje-sterownikow-z-Windows-Update,News,64945.html
    Then download the driver cleaner from AMD and start cleaning
    https://www2.ati.com/drivers/amdcleanuputility.exe
    Download drivers compatible with the card, i.e.
    - 13.152.1.3000 win10
    - 15.7.1 catalyst-win10-64bit
    - 16.2.1-Win10-win7 Crismmon
    and install in the order I gave it, i.e. first 13 then 15 and finally 16. If an application does not need newer drivers, stay even on 13.152 because these worked extremely well, if you need, install the next one. Download exactly the versions I have given, others will not overlap and will crash again.
    Do not install newer drivers than 16.2.1 Crismmon, or a newer AMD panel because it will crash and restore the system driver.
    Watch out for messages from the AMD panel about automatic upgrade to a newer version, after the upgrade it will stop working again.
    If you will be installing more drivers, after installation 13 go to installation 15 without rebooting the system, but before installation 16 restart.
  • #3 17054947
    lokipok
    Thanks so much for your help :D do you know how I could download these older drivers?
    roxio
    Help: 108
    Rate: 213
    13152
    http://download.msi.com/nb_drivers/vga/ati_r9_131.52_0x7a41faed_w878100.zip
    1571
    https://files01.tchspt.com/tempd/amd-catalyst-15.7.1-win10-64bit.exe
    1621
    https://www2.ati.com/drivers/beta/non-whql-64bit-nieg-radeon-crimson-16.2.1-win10-win8.1-win7-feb27.exe
