Netflix Issue on Smart TV Sharp: Playback Error & Troubleshooting Tips (Network, Updates)
Piciorex 15408 9
Why does Netflix on a Sharp smart TV show a playback error for every title even though Netflix works on other devices and the TV’s other apps work normally?
If Netflix fails only on the Sharp TV while the same title plays on a computer or smartphone on the same network, and other TV apps like YouTube and the browser work, the issue points to the TV/Netflix app rather than the home network [#17054467] [#17054478] [#17054552] [#17054607] The main troubleshooting advice in the thread is to first isolate the fault by testing Netflix on another device on the same network, then verify the TV’s internet access and app functionality [#17054467] [#17054552] The TV details provided were Sharp Aquos LC-40FI5342E with IP 192.168.0.10 [#17372334] No definite fix is shown in the thread; the later replies are follow-up reports from other users with the same symptom [#17852338] [#19391765]
  • #1 17054435
    Piciorex
    I have a problem with the Netflix application on smart TV Sharp.
    I have had TV for half a year and everything worked without a problem. One day, the application started normally, but when you enable any movie, a message appears: "We currently have a problem reproducing this title. Please try again later or choose another title."
    I have contacted Netflix on this matter, but this is not their problem. They point to a problem with the TV or network. I have implemented all of their tips: I have reset the network, I have permanently removed the TV from the power, I have even set the factory settings in it. Nothing, however.
    I even wanted to make some updates on tv, but I can not do it from the settings.
    Has anyone had a similar problem and managed to solve it?
  • #2 17054467
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    First you need to diagnose whether the problem is definitely on the TV or maybe somewhere along the way (network). Do the first test - being on the same network as the TV (i.e., assume that it is home), try to fire the title on another device, e.g. on a computer.
  • #3 17054478
    Piciorex
    Thanks for the quick response.
    I just forgot to add that on other devices (computer, smartphone) running in the same network, the Netflix application works without a problem. Therefore, it indicates that the problem lies in the sharp TV.
  • #4 17054552
    alster1
    CCTV and Stationary Alarms specialist
    Help: 352
    Rate: 540
    Did you check if this TV has internet access? Something else works on it, browser, YouTube etc?
  • #5 17054607
    Piciorex
    All other applications like YT or browser work without a problem. Only the Netflix application reports an error.
  • #6 17054695
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    1. What exactly TV model?
    2. What is the current IP address of the TV?
  • #7 17372334
    Piciorex
    The IP address is 192.168.0.10
    The TV model is Sharp Aquos LC-40FI5342E
  • #8 17742037
    RadekM
    Level 19  
    Rate: 61
    I will connect to the topic. I need Netflix on Sharp TV. Is there any way to add it to the application? I searched all available applications but I can not find one.
  • #9 17852338
    Karo1311
    I have the same problem as you, I have something to do, because I do not know whether to file complaints on TV, everywhere on the other devices (the same network) internet and other applications also, netflix after the inclusion of the movie - shows the message - temporarily we have a problem with the reproduction of this title, I tried other films and the same and only on this tv
  • #10 19391765
    megamind
    Has someone managed to solve this problem? I have an identical one after a year and a half of use.
The discussion revolves around a playback error encountered on a Sharp smart TV while using the Netflix application. The user reports that after six months of normal operation, an error message appears when attempting to play any title, indicating a problem with playback. Despite following Netflix's troubleshooting advice, including resetting the network and restoring factory settings, the issue persists. Other applications on the TV, such as YouTube and the browser, function correctly, suggesting the problem is isolated to Netflix. Participants in the discussion suggest checking the TV's internet connectivity and provide insights into the model specifics, with one user confirming the model as Sharp Aquos LC-40FI5342E. Others express similar experiences, indicating a potential widespread issue with Netflix on Sharp TVs.
