Choosing the Right Cable for Home Use: VCDS vs Aledrogo for PLN 200
hugo987 6090 2
  • #1 17056864
    hugo987
    Rate: 23
    Which cable to buy VCDS or one with aledrogo for PLN 200 will give advice for home use? If so, maybe you recommend something?
  • #2 17056914
    gracjan55
    Level 36  
    Help: 315
    Rate: 244
    If you have a car from before 2005, a simple cost for 20-30 PLN is enough, and after 2005 you need to look for vcds.
  • #3 17058912
    hugo987
    Rate: 23
    Car is Golf 6, does it mean that I have to buy the original interface? How much you have to give
