[Solved] Yato YT-82780 vs Meec 18V Battery Screwdrivers: Which is a Better Option for Amateur Use?
sebakos 10047 2
  • #1 17059295
    sebakos
    Rate: 37
    Hello, I am looking to buy a new screwdriver. It will be used amateurically and occasionally. I need something for the battery. Budget up to PLN 300. I am thinking of buying one of the two that caught my eye, namely:
    https://www.jula.pl/catalog/narzedzia-i-maszy.../?f.category.code=A-031200&sort.by=price&sort .order = asc & skip = 10 & take = 10 & page = 2 & _ = 1519429397440
    https://www.budujesz.pl/yato-wiertarko-wkreta...akumulatorowa-18v-2ah-li-ion-yt-82780-416882/
    I am asking for an opinion which of these two will be better and suggestions for something else.
    Thank you in advance for the hint.
    Greetings.
  • #2 17059311
    mladenick
    Help: 14
    Rate: 90
    I would choose Yato, the price is actually the same, probably the most important here is only the battery capacity in Yato 2AH in the first 1.5AH, and Yato a little stronger, there is Parkside on the Allegro similar parameters to Yato, for home use it can be, with you don't go crazy with this budget, you may have a stroke but unfortunately it's much higher.
  • #3 17060936
    sebakos
    Rate: 37
    I bought a meeca just because I saw two pieces of yato (more the seller did not want to open because the boxes are foil) and in both of them the gear was loud and even very loud, and when the switch was released a strong rattling was heard. The seller acknowledged that this should not be the case. That's why I gave up and bought a meeca. I regret a little that it is not yato, because at first glance it is better made, in my opinion somehow better materials and generally somehow pleasing to the eye and hand because it was more securely held and lighter but that is only my subjective feeling.
    Greetings.
