VW T5 multivan 2.5 tdi 174 - turning off the turbo while driving
pawel_lubin 26061 19
Why does the turbo on a VW T5 2.5 TDI 174 intermittently cut out around 105–110 km/h and put the engine into limp mode until the engine is restarted?
The most likely cause is a boost-control fault that triggers limp mode, so the turbo itself is not necessarily the only problem; first check the vacuum hoses, the solenoid valve/N75, the actuator (“pear”), the airflow meter, and read the fault codes with the original VCDS, because generic diagnostics may miss the issue [#17064323][#17065385][#17429390] If the vacuum pressure is correct and the actuator works, the variable-geometry turbine may still be sticking and need cleaning or repair [#17064821][#14373] One user eventually found that the regenerated turbo was actually the problem even though the workshop claimed it was fine, and replacing it with a new turbo fixed the limp mode [#17809983]
  • #1 17064280
    pawel_lubin
    Rate: 15
    Hello ... I have been struggling with the turbine problem for some time .... vw 2.5 tdi 174 engine ...
    While driving, exactly around 105-110 km / h, the turbine switches off and goes into emergency mode. Of course, when we turn off the engine and restart it, the problem disappears and we can go on. The problem does not always appear and you can travel 50 or 300 km. and you can drive 100 and 140 but the speed limit is 105-110 km / h.
    It should be noted that last year the turbine was regenerated and earlier the water pump was replaced, which gave the effect of disappearing fluid in the cooling system.
    At the mechanic - it was found that the turbine is mechanically OK. so the reason lies elsewhere but where ....? Are these regenerations sometimes pic photo montage ???? although it must be noted that the engine has power and there is nothing to complain about, everything is ok up to the speed limits and it is not known how many kilometers .....
    it happens that the turbo turns off after 50 km. after driving or maybe after 250 -300 or 100. but it is so annoying that you never know what and how it will happen and especially when overtaking ...
    did anyone have such a case?
    when replacing the water pump, these were the adventures: https://www.elektroda.pl/rtvforum/topic2395987.html
  • #2 17064323
    migmig85
    Help: 85
    Rate: 337
    To start with, check all the negative pressure that controls the turbine, most likely a rubber hose has worn or broke and left air gets in. But take the diagnostics should be an error from the boost pressure.
    Moderated By T5:
    3.1.11. Do not send messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #3 17064821
    komandospolen
    There is no legend that indicates that left air gets under vacuum, like ??? please do not write such nonsense and do not mislead people.
    As for this fault, it is a fault probably known to everyone, the turbine in this case has nothing to do, the mechanic who replaced the turbine and regenerated it forgot that cleaning and bringing the turbine as new would not give the following results.
    Go, buddy, to the right mechanical plant and let you check your vacuum pressure during the vacations, if the pressure is adequate and there will be no decrease in time to deal with the geometry of the turbine, it turns off depends on the load and intake of exhaust gases. nothing can bury everything and clean.
  • #4 17065385
    kanar2306
    Help: 23
    Rate: 283
    As it goes into safe mode there can be many reasons. Solenoid valve, pear, vacuum leak, flow meter, etc. ... Reading errors first and then you can think again
  • #5 17066427
    pawel_lubin
    Rate: 15
    And today I made one more small test .... like a 2.5 174 engine .... and at 50 km / h I drive 6 and a pedal into the floor ..... The car should reach 2 thousand revolutions and here :( almost faint response ... there was a reduction for 5 and pedal and we also do not embrace any revelations .....
  • #6 17066777
    migmig85
    Help: 85
    Rate: 337
    Do not carry out tests, lift the mask and see the vacuum hoses.
  • #7 17419069
    Nowyblady
    Hello, I have the same problem
    You may have solved your cause
  • #8 17419468
    pawel_lubin
    Rate: 15
    Still the same .... they suggested that the turbo should be replaced with a new one from the site .... at what speeds it turns off? At your place Did you exchange a turbo? Regenerowaleś?
  • #9 17421213
    Nowyblady
    Turbo twice checked on the dynamometer like everything is ok and for me at about 110 km it loses power and just turn off the engine and after firing again ok. Mechanic claims that the injectors to be replaced
  • #10 17421951
    dizba
    Help: 239
    Rate: 808
    This fake car is not read properly by any fake.
  • #11 17429333
    Nowyblady
    Dizba if you could develop a little hint. Thank you in advance
  • #12 17429390
    dizba
    Help: 239
    Rate: 808
    I have such a car and several computers. When the trouble started, mine read nothing. I visited several friends, the same. It wasn't until I bought the original VCDS that the problem ended. And that was a few years ago.
  • #13 17613773
    comin
    Rate: 115
    I have the same problem, Highway 140 and suddenly no power. Exit to the car park off / on and everything returns to normal. Share how did you solve this problem?
  • #14 17613809
    dizba
    Help: 239
    Rate: 808
    You have the answer above.
  • #15 17613814
    comin
    Rate: 115
    Should I buy VCDS?
  • #16 17613837
    dizba
    Help: 239
    Rate: 808
    After all, you can drive to a decent diagnostic workshop. But again, it must be the original.
  • #17 17614373
    Mazur_1234
    Level 4  
    I also had such a problem that the lack of power and the engine fell into emergency mode and drove like sdi. At the beginning I replaced the pear because it cuts. Later it turned out that the geometry also intersects. Was expelled like new. And finally I had to visit a guy who regenerates the turbo and set a pear for me because someone in front of me turned the bumper on the turbine and was overloading the engine.
  • #18 17809983
    pawel_lubin
    Rate: 15
    Topic solved .... So, after checking the regeneration of the turbine that was installed in the engine, it turned out that regeneration is OK. So says the company that carried out the regeneration. I say NO ... Because after buying a new turbine .. cost 2100 PLN + replacement engine works much better does not fall into the so-called emergency mode, i.e. when the turbine does not rain ...... CONCLUSION FOR ALL OF THOSE .... WE UNUSH BUY A NEW TURBINE AND FORGET ABOUT THE SUBJECT .... all those companies with whom I had to deal with regeneration you can know where to put ... .. REGARDS ...
    LINK TO NEW TURBINE ..
    https://allegro.pl/oferta/turbina-vw-multivan-t5-transporter-2-5-tdi-nowa-7859385471
  • #19 17810032
    comin
    Rate: 115
    I will not agree with a friend that you need to exchange the turbo. Nothing happens with me after my last adventure in November. I did nothing and the car drives without a problem.
  • #20 20198154
    banbud1511
    Hello, I have such a problem. Only in the summer there are no symptoms at all, as it is outside. It drops to about 10 degrees and less, it happens to me that it disconnects the turbo and goes into emergency mode and after restart it is good once more often, less often and in the summer in general. The error that only the 2.0 140km 2013 Caravella engine did not reach some pressure
The discussion revolves around a recurring issue with a VW T5 Multivan equipped with a 2.5 TDI 174 engine, where the turbocharger switches off while driving at speeds between 105-110 km/h, leading to emergency mode activation. Users suggest various potential causes, including vacuum leaks, solenoid valve issues, and flow meter problems. Some recommend checking vacuum hoses and performing diagnostics to identify error codes. Others share experiences of similar problems, with some attributing the issue to faulty turbo regeneration or geometry problems. A user ultimately resolved the issue by replacing the turbo with a new unit, stating that regeneration services were inadequate. The conversation highlights the importance of proper diagnostics and the potential need for new components over regeneration.
TL;DR: VW T5 2.5 TDI limp‑mode turbo cutout? One verified fix cost 2100 PLN; "buy a new turbine and forget about the subject." [Elektroda, pawel_lubin, post #17809983]
Why it matters: For VW T5 Multivan/Transporter owners, this FAQ shows how to diagnose and fix unpredictable turbo shut‑offs without guesswork.
What are the typical symptoms when a VW T5 2.5 TDI 174 loses turbo while driving?
Sudden power loss appears around 105–110 km/h. The ECU enters limp mode and disables boost. Cycling the ignition restores full power until it happens again. The interval is irregular, from 50 km to a few hundred. It complicates overtakes and long trips. [Elektroda, pawel_lubin, post #17064280]
How do I diagnose this quickly without guessing?
Start with targeted checks.
  1. Inspect all vacuum hoses and connectors for splits and loose fits.
  2. Measure vacuum supply and the actuator’s ability to hold vacuum with a hand pump.
  3. If vacuum is steady, service the VNT geometry for sticking under load. These steps isolate control versus mechanical causes. [Elektroda, komandospolen, post #17064821]
Do I need the original VCDS to read faults on a T5?
Yes. Owners report multiple scanners showing nothing until the genuine VCDS is used. “It wasn’t until I bought the original VCDS that the problem ended.” Clone tools can miss key data and codes. Use a shop with the real interface or buy one. [Elektroda, dizba, post #17429390]
Which components should I check first for limp mode?
Scan for boost control errors, then test the N75 solenoid, vacuum lines, actuator “pear,” and the MAF. Address stored faults before replacing parts. “Reading errors first and then you can think again.” This sequence avoids unnecessary swaps and reveals control issues. [Elektroda, kanar2306, post #17065385]
Could the turbo be bad even if it was regenerated recently?
Yes. One owner had a regenerated turbo deemed OK, yet limp persisted. Replacing it with a new unit resolved the issue. Reported cost was 2100 PLN plus installation. If control checks pass and geometry binds, a new turbo can be decisive. [Elektroda, pawel_lubin, post #17809983]
Should I keep road‑testing, or inspect under the hood first?
Inspect under the hood first. “Do not carry out tests, lift the mask and see the vacuum hoses.” Road tests without basic checks waste time. Find leaks or loose lines before chasing sensors or electronics. It is quick and often revealing. [Elektroda, migmig85, post #17066777]
Can VNT geometry or actuator adjustment cause overboost or limp mode?
Yes. Sticky geometry can bind and trigger limp under load. Misadjusted actuators can also overboost. One owner replaced the actuator, cleaned geometry, and finally had a turbo specialist set the actuator correctly to stop overload. Verify movement and calibration. [Elektroda, Mazur_1234, post #17614373]
My van loses power at 140 km/h, then is fine after restart. Same issue?
Yes. That matches classic limp mode behavior. At highway speed, boost control deviates and the ECU limits power. Cycling the ignition clears limp until the next deviation. Diagnose vacuum, N75, actuator, and VNT sticking as first steps. [Elektroda, comin, post #17613773]
A mechanic says injectors are the problem—should I replace them?
Treat injectors as a later step. One case had the turbo checked twice on a dynamometer, limp near 110 km/h, and a mechanic suggested injectors. However, verify boost control, vacuum, N75, and geometry first. Replace injectors only after those pass. [Elektroda, Nowyblady, post #17421213]
Does cold weather make limp mode more likely?
It can. One owner reported no symptoms in summer, but repeated limp when ambient dropped to about 10°C or lower. The ECU stored an underboost type error on a 2.0 TDI 140. Temperature can expose marginal control or leaks. [Elektroda, banbud1511, post #20198154]
Will clone diagnostic tools miss the fault on this platform?
Often, yes. Owners note these vehicles may not read properly with non‑original tools. You risk missing codes and key live data. Use a workshop with genuine equipment or buy original VCDS to ensure reliable diagnostics and logs. [Elektroda, dizba, post #17421951]
Can a bad MAF (flow meter) cause turbo cut‑out and limp mode?
Yes. A faulty MAF can skew load and boost calculations, triggering limp. Check measured versus expected airflow in live data after verifying vacuum and N75 control. Replace the MAF only after confirming it deviates from expected values in logs. [Elektroda, kanar2306, post #17065385]
