[Solved] Corolla e11, 4EFE Engine Oil: Synthetic or Semi-Synthetic? Castrol SLX vs Original TOYOTA 5w30
12225 6
  • #1 17065352
  • #2 17065402
    decybel91
    Help: 1024
    Rate: 4231
    A bit rare for this oil, best buy Valvoline 5w40. Good and quite cheap. Generally, if the oil is more expensive than 16-18pln / l then you can ride it.
  • #3 17066675
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Castrol recommends magnatec 5w30. Toyota does not produce but sells oil under its name.
  • Toyota 4EFE oil choice: 5w30 synthetic or 10w40 semi-synthetic
    #4 17070810
  • Castrol and Toyota oils are likely rebranded blends
    #5 17071966
  • #6 17072012
  • Factory recommends 5w30 synthetic over 10w40 semi-synthetic
    #7 17072071
The discussion revolves around the appropriate engine oil for a 1998 Toyota Corolla E11 with a 4EFE engine. Users express confusion over the recommended oil type, with suggestions ranging from synthetic 5W30 to semi-synthetic 10W40. Castrol SLX is mentioned as the current oil, but there are concerns about its authenticity and whether Toyota produces its own oil. Recommendations include Castrol Magnatec 5W30 and Valvoline 5W40 as alternatives. The consensus leans towards using synthetic oil for optimal performance, supported by links to Toyota's official recommendations and oil selection guides.
