[Solved] MANTA BLAUBERG 32 'LHS3205 - switching between ATV and DTV channels
szynsz87 15177 9
How do I switch between ATV and DTV channels on a Manta Blauberg LHS3205 TV?
Press the DTV button on the remote control to switch the TV between analogue (ATV) and digital (DTV) mode [#17067461] If the set is connected to a cable network, the analogue channels may simply be duplicated in digital form, and the digital package can contain more channels [#17067461]
  • #1 17067242
    szynsz87
    Rate: 16
    My mother bought a 32 "LHS3205 MANTA BLAUBERG TV that has a built-in decoder for digital reception. The problem is that after searching all available channels, both terrestrial and digital, you can only watch dtv channels even though it also detected ATV channels. Unfortunately, the instructions have nothing written on how to switch. Anyway, the instruction is tangled at all
  • #2 17067293
    agraba
    Help: 43
    Rate: 47
    In Poland, only digital programs are broadcast on the ground, so the TV probably does not detect analogue channels.
  • #3 17067299
    szynsz87
    Rate: 16
    It is possible that I have expressed myself badly. It's about normal and cable channels. For sure the TV has detected ATV and DTV channels. At least that was how it looked when tuning. In addition, the TV does not receive all channels, it accurately receives these in the so-called digital package.
    agraba
    Help: 43
    Rate: 47
    I understand that you have a cable decoder connected to the TV and an external antenna?
  • #5 17067390
    szynsz87
    Rate: 16
    Well, just the antenna cable from the cable TV, because the TV was supposed to be able to cope without the decoder
    agraba
    Help: 43
    Rate: 47
    What is this cable?
  • #7 17067426
    szynsz87
    Rate: 16
    Osiedlowa from Lodz, not toya, some small company
    agraba
    Help: 43
    Rate: 47
    It is probably the case that all analogue channels (if this cable is really suitable) are repeated in the digital version. I suspect that you have a larger programming offer digitally. When it comes to switching from analogue to number, you have a DTV button on the remote control. He switches the type of television.
  • #9 17067476
    szynsz87
    Rate: 16
    OK thanks :) I will try today. And as for the repetition of channels, except for a few in the HD version, it is rather unlikely.
  • #10 17189687
    szynsz87
    Rate: 16
    It turned out that the problem is more complicated (instruction and operation of this TV are hard to grasp) and ended up calling for a technician from cable TV.
The discussion revolves around a MANTA BLAUBERG 32" LHS3205 TV, which has a built-in decoder for digital reception. The user is experiencing difficulty switching between ATV (analogue television) and DTV (digital television) channels, as the TV only displays DTV channels despite detecting ATV channels during tuning. Responses suggest that in Poland, only digital channels are broadcast, and the user is likely receiving a digital package that may not include all analogue channels. It is noted that the TV should have a DTV button on the remote to switch between channel types. Ultimately, the user found the operation of the TV complicated and decided to call a technician for assistance.
