[Solved] An Operating System Wasn't Found Error: Resolving Partition Deactivation & CMD Steps
Jarzi12 7734 10
How can I recover my data and fix a PC that boots only to CMD after I may have deactivated the system partition, with Windows saying no operating system was found?
Yes — first boot from a Linux live USB/DVD and copy your important files to another disk or the cloud before trying any repair of the system partition [#17073735][#17082611] If you have a Lenovo G570 and the recovery partition is still intact, you can try restoring the factory settings after saving your data [#17073899] If Windows repair tools do not start and CMD attempts fail, a clean Windows 10 install may be the practical next step [#17082611] In this thread, the successful recovery path was: start Ubuntu from a bootable USB, find the files, back them up, then reinstall Windows [#17082611]
  • #1 17073657
    Jarzi12
    I warmly welcome.
    Unfortunately, I don't know exactly what happened when I tried to create the partition. I think I accidentally deactivated the system partition. (I was botting a pendrive and tried to activate partitions from CMD but on average it came out and either did not give results or I am doing it wrong) When switching on the computer I was shown the text that E was not found Mbr I played a little in CMD and I think I could play it unless the inscription changed on any operating system wasn't found, I can't use any repair option, only CMD starts, can something be done with it so that I don't lose data? All data was on D and the Partition with the system is C,
    michald
    Help: 210
    Rate: 437
    I suggest booting from a dvd or USB stick with a linux live system and copy the data to another disk before a colleague attempts to repair the system partition.
  • #3 17073739
    Jarzi12
    So is it enough to download free Ubuntu eg and copy everything on a pendrive, and then install the system just?
    michald
    Help: 210
    Rate: 437
    Is it a desktop or laptop?
  • #5 17073797
    Jarzi12
    Lenovo g570 laptop exactly
    michald
    Help: 210
    Rate: 437
    If the "Recovery" partition has not suffered then you can try to restore the factory settings after copying valuable data.
  • #7 17075186
    Jarzi12
    I started Ubuntu with a pendrive, I do not know how to recover these files because all folders are empty, what to do or maybe everything is lost?
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    Show the screen from DMDE from the partitions window view, after selecting the disk from physical devices.
  • #9 17082144
    Jarzi12
    I have regained everything thank you for your help !!
  • #10 17082434
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    That's if you can write at a glance what you did and close the topic as completed.
  • #11 17082611
    Jarzi12
    I booted the pendrive so that I could boot win 10 from it, as I could not use repair tools at startup or restore the backup, so I started Ubuntu from another booted pendrive, found my files and dumped to the cloud then after unsuccessful attempts to repair the system partition with CMD I put Windows 10 clean. That's all, I will add that if you do not have data that is important on your computer, it is not worth having fun repairing with CMD, it is time consuming and requires patience.
The discussion revolves around resolving an "Operating System Wasn't Found" error after a user accidentally deactivated the system partition while attempting to create a new partition via CMD. The user, with a Lenovo G570 laptop, sought help to recover data from the D partition while the C partition was affected. Suggestions included booting from a Linux live system (like Ubuntu) to recover files before attempting system repairs. After successfully booting Ubuntu from a USB drive, the user managed to recover their files and ultimately decided to install a clean version of Windows 10 after unsuccessful CMD repair attempts. The conversation highlights the importance of data backup and the challenges of using CMD for system repairs.
