Windows 10 Automatic Repair Loop After Disk Partition: Data Recovery Concerns
ortinek625 24573 9
How can I recover my files after Windows 10 gets stuck in an automatic repair loop following a partition resize?
Boot the computer from a Live system and copy your data first; the Windows installation itself is not needed to access the disks [#16911094][#16911192] A good option mentioned in the thread is Parted Magic live CD/USB, which can be used to check whether the partitions are visible and to browse the disk with DMDE under Linux after selecting the physical device [#16911192] If you cannot prepare the media on the broken PC, use a second computer to download and burn the Live system [#16911234] Only after the important files are saved should you try to repair or reinstall Windows [#16911094]
  • Partition change triggered automatic repair loop
    #1 16911051
    ortinek625
    I'll go straight to the problem and then he came out.
    After running the disk partition, to move some memory to disk C the computer has made some strange installation related to the capacity of these disks and from then on, automatic repair is started, resulting in the following message on the screen, most advanced options does not help I care about the data that I had.
    Please help
    Windows 10 Automatic Repair Loop After Disk Partition: Data Recovery Concerns1514120008...975511.jpg (4.23 MB)You must be logged in to download this attachment.
  • #2 16911060
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. What did you transfer and from which partition D to C or vice versa? Use advanced options.
  • #3 16911066
    ortinek625
    From drive D to C, I just wanted to let drive C have more capacity
    Added after 4 [minutes]:
    I used this program:
    partition wizard
  • #4 16911094
    Matuzalem
    Help: 1653
    Rate: 1100
    You can access the data through any Live system. It is only after they have been ripped that I suggest taking steps to rescue the system.
    PS
    Changing the size of the partition in which program was being made?
    GPT or MBR?
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #5 16911147
    ortinek625
    How does the live system work?
    As for GPT or MBR, it's hard for me to answer because I have no idea about it. Only I can say that I used the partiton wizard
  • Suggesting Parted Magic and DMDE to inspect partitions
    #6 16911192
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    This is now show the screen / picture again from this program, because I understand that everything was done in the live CD mode (program launched from CD / pendrive). Also download, for example, Parted Magic live CD, run and see if it reads these partitions of the program. Under Parted Magic, you can drop it on a DMDE pen drive under linux and also show screen / photo from the window partitions, after selecting a disk from physical devices.
  • #7 16911218
    ortinek625
    The problem is that the system does not want to start only to repair and nothing more
    I do not have how to download this etc: /
  • #8 16911230
    Pedros050
    Help: 2471
    Rate: 3926
    And the recovery partition is all or have you deleted the files?
  • #9 16911234
    mati211p
    Help: 2585
    Rate: 1133
    The system is not required to run the above-mentioned programs.
    A friend does not have a computer to download and record?
  • Reinstalling Windows preserved the needed files
    #10 16911312
    ortinek625
    I have not removed anything so it should be everything
    I have a second computer, I can download and record it there
    Massacre, I could leave it as it was because I do not know it and all these programs abbreviate I do not know what and how ...
    Added after 1 [hour] 22 [minutes]:
    I reinstalled the windows and the files that interested me were so subject to close.
The discussion revolves around a user experiencing an automatic repair loop in Windows 10 after attempting to resize disk partitions using Partition Wizard. The user is concerned about data recovery, as the system fails to boot and only displays repair options. Various suggestions are made, including using a Live system to access data, checking partition types (GPT or MBR), and utilizing tools like Parted Magic and DMDE for recovery. The user expresses difficulty in executing these solutions due to system limitations but mentions having access to another computer for downloading necessary tools. Ultimately, the user reinstalled Windows, resulting in the loss of some important files.
