Connect Box UPC Modem Setup - Router Access, Bridge Service & Open Ports for BitComet
jumis 4842 5
  • #1 17074974
    jumis
    Rate: 8
    Welcome.
    I will step on the topic. I have been the owner of such a modem for several days. As I understood correctly, now I cannot access the router because I do not have the bridge service running?
    Second thing is, I would like to have an open port so that it fits nicely with BitComet client.
    Moderated By jimasek:
    I selected as a new thread only because of the number of replies. Otherwise, your query would go to the bin. Please do not clutter other threads in the forum.
    3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    makosuu
    Help: 369
    Rate: 370
    You will hook it up, but it doesn't make sense. There will be double NAT, and that won't change anything.
  • #3 17075042
    jumis
    Rate: 8
    How to solve it?
  • #4 17075054
    KOCUREK1970
    Help: 3862
    Rate: 5490
    jumis wrote:
    How to solve it?
    Ask UPC to switch Compal to bridge mode (obtain IPv4) and buy your own router (if something is to work on wifi and more than one device is to work on the cable).
  • #5 17075110
    jumis
    Rate: 8
    One computer will be on the cable and the rest on Wi-Fi.
    Will I be able to set the port then?
    KOCUREK1970
    Help: 3862
    Rate: 5490
    You need your router for this.
    You can set whatever you want there.
    What internet speed?
    how much money do you plan to spend on a new router?
