Connect Box UPC in bridge mode - no internet access every day
Pawel_PS 35142 13
Why does my Connect Box in bridge mode lose internet every morning, and how can I fix it?
If the connection drops every morning even in bridge mode, the thread points to a line/signal problem on the UPC side, and the working fix was for a technician to check and adjust the signal outside the apartment; replacing the modem alone did not solve it [#18882158] [#18882185] [#18882284] [#18909975] Before calling UPC, test with only a computer connected directly to the Connect Box to rule out the Huawei router [#18881937] In bridge mode the modem is reachable at 192.168.100.1, not 192.168.0.1 [#18882098] If you reconnect devices, power off both the modem and the client/router for about 30 seconds so the modem can obtain a new IP [#18882132] The reported downstream levels were about 9–10 dBmV and were described as being near the upper edge, while upstream looked normal [#18882158] [#18882185]
  • #1 18881833
    Pawel_PS
    Good morning,
    I am a UPC 300/20 internet user, I have ConnectBox set to bridge mode and a Huawei AX3 router. Everything flashes beautifully and I am really happy with WiFi and lan on the cable on connected devices, but there is one BUT:
    every morning when i get up, the Connect Box bridge can't see the internet. My devices are connected to the AX3 router via WiFi or cable, but there is no external internet access. This is not the fault of the Huawei router, because re-focusing it does not help. The only way out is to turn off the Connect Box and turn it on. After waiting 5-6 minutes, while the CB syncs with the network, all devices can see the world and I can surf the Internet all day until late in the evening. Until the next morning when I don't have internet again ....
    I called UPC help, but all they do is reset the Connect Box.
    Has anyone experienced such a situation? How to cope? I am thinking of connecting the Connect Box's power supply to the programmable power switch so that, for example, at 5 or 6 am it turns off the power for a few minutes and then turns it on (instead of me), but this is a half-measure, not a solution to the problem.
    Best regards,
    Paul
  • #2 18881937
    KOCUREK1970
    Help: 3860
    Rate: 5488
    It does not mean anything.
    To be sure it's not his fault, disconnect it at all and test that you are wired only to the CB.
    Additionally, insert here the DS / US signal levels from the CB here.
    What version of the software for CB?
  • #3 18882068
    Pawel_PS
    Thank you for your response.
    I'll disconnect the router from the Connect Box in the evening and see if there's a signal in the morning.
    And how do I connect to the Connect Box, if it is in "bridge" mode? I am trying to log in via the cable to 192.168.0.1, but it is not responding. I also entered the WAN address 31.xxx.xx.xxx or xx.01 or xx.1 (WAN IP address with different ends), but I also do not go to the CB.
  • #4 18882098
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Just remember that wifi doesn't work in bridge mode, and additionally only one device on the cable will work.
    192.168.100.1 - This is the CB's IP address in bridge mode.
  • #5 18882112
    Pawel_PS
    Yes, I know, but thank you for reminding me. Instead of a router, I will plug in my laptop and check in the morning if there is a connection.
    Thanks a lot. I did not know this address and I was in the dark.
    Which table will it be from the CB Advanced Settings?
    hardware version: 5.01
    software version: CH7465LG-NCIP-6.12.18.26-3p6-GA-NOSH
  • #6 18882132
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Well, it doesn't quite work as well.
    After such connection, you need to disconnect the computer and modem from the power for 30 seconds, wait these 30 seconds and connect the electricity to the modem and computer again - the modem must download a different / new IP.
    The same maneuver must be used when you reconnect the modem router.
    There are 3 addresses in total:
    192.168.0.1 - modemorouter
    192.168.0.100 - modemorouter
    192.168.100.1 - modem
    You probably also have the WiFree service turned on (not to be confused with wifi) - even in modem mode it is active, turn it off via the operator's hotline / chat
    I don't remember exactly, but something like network settings and there should be downstream and upstream tabs.
    Latest official version.
  • #7 18882137
    Pawel_PS
    I will do as you write. In the evening I will turn off the modem, connect the computer, turn on both devices and check in the morning how things are going,
    It has already been disabled at my request by the hotline.
  • #8 18882156
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @Pawel_PS
    Well, we are waiting for the test.
    If there is no improvement (i.e. there is still a problem), call the operator's hotline and report the problem - a technician will come and replace the Compal for another unit.
    Also replace the RJ45 cable that connects to the CB.
    If all is ok, then advertise the Huawei router at the seller, or look for another official and newer software.
    And is this Huawei by chance, there is no intelligent power / current management option turned on somewhere (if nobody uses, Huawei falls asleep?).
  • #9 18882158
    Pawel_PS
    For forward channels 1-24 downstream, the signal level is 9 dBmV (except for channel 21, where the level is 10 dBmV), and for the return channels it looks like this:
    Channel Frequency (Hz) Signal Level (dBmV) Symbol Rate (ksps) Modulation Channel ID
    1 38,000,000 44 5.120 64qam 2
    2 51 600 000 44 5.120 64qam 4
    3 44,800,000 43 5,120 64qam 3
    4 311 200 000 43 5.120 64qam 1
    Added after 4 [minutes]:
    So I will.
    Soft is the newest, check for updates. Haven't found the power management option, thought about it too.
    Thanks again for your help and hints. I'll call you in 3-4 days when I have a few rehearsals with the morning rehearsals
    Best regards.
  • #10 18882185
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Pawel_PS wrote:
    For downstream channels 1-24, the signal level is 9 dBmV (except for channel 21, where the level is 10 dBmV)
    No downstream signal on the edge of the upper brackets - this can also cause problems.
    Upstream signal normal.
  • #11 18882244
    Pawel_PS
    Is it my Connect Box's fault? Or maybe UPC should change its settings to make the downstream signal better? Does it make sense to call technical support on this matter?
  • #12 18882284
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Hard to say.
    Without replacing the device, nothing will be known.
    Remotely, no one will improve the signal because there are several components that are not affected by UPC.
    The optical NOD in front of the block has the auto-adaptation option - that is, it regulates itself, optimally for the signal transmitted with light. The problem may be the signal that goes from the optical NOD to the bus splitter and then to the coaxial cable, another splitter to the customer's premises. And it is this last element of the UPC network that it has no remote influence.
    This must be reported to the operator - a technician must come and adjust the signal and, by the way, he can also replace the modem if necessary. But signal adjustment is essential.
  • #13 18882317
    Pawel_PS
    So I will call UPC tomorrow and report the need to adjust the signal and possibly replace the modem.
    Thanks again for your help and have a good weekend :)
    Best regards,
    Paul
  • #14 18909975
    Pawel_PS
    The topic seems to be finally settled by UPC. After reporting the problems to the technical support, the fitter came, replaced the Compal with another one and it was ... even worse. After the next call, a technician was scheduled to check the signals. He came, checked the signal levels somewhere outside the apartment, adjusted it and for 6 days I have had no problems with disconnecting.
    So finally it is comfortable. I hope it will be like that all the time.
    Best regards,
    Paul
A UPC internet user experiences daily internet connectivity issues with their Connect Box set to bridge mode, connected to a Huawei AX3 router. Despite having a stable connection throughout the day, the Connect Box fails to access the internet each morning, requiring a power cycle to restore connectivity. Users suggest troubleshooting steps, including testing the Connect Box without the router, checking signal levels, and ensuring proper settings. The user is advised to contact UPC for signal adjustments and potential modem replacement. After reporting the issue, a technician adjusted the signal, resulting in improved connectivity.
TL;DR: Daily bridge‑mode dropouts on the UPC Connect Box often trace to line signal issues; "adjusted it and for 6 days I have had no problems." Call UPC for a technician to tune levels and use 192.168.100.1 for checks. [Elektroda, Pawel_PS, post #18909975]
Why it matters: It helps you stop endless reboots and fix the real cause—signal and IP handoff—for stable internet on bridge‑mode setups.
Why does my Connect Box in bridge mode drop internet every morning?
A marginal or misadjusted line signal can cause daily loss. Reboots resync temporarily but do not cure it. Ask UPC to send a technician to measure and tune the signal, and replace the modem if needed. "Signal adjustment is essential." [Elektroda, KOCUREK1970, post #18882284]
How do I access the Connect Box when it’s in bridge mode?
Connect a single device by Ethernet and open 192.168.100.1 in a browser. 192.168.0.1 will not respond in bridge mode. This lets you check signal and status pages while routing is disabled. [Elektroda, KOCUREK1970, post #18882098]
In bridge mode, how many devices can I connect directly?
Only one wired device will work at a time. The Connect Box’s Wi‑Fi is disabled in bridge mode. Use your own router to support multiple clients and wireless. [Elektroda, KOCUREK1970, post #18882098]
How can I test if my Huawei AX3 is the problem?
Use this 3‑step isolation test:
  1. Unplug the router and connect a laptop directly to the Connect Box.
  2. Power off both for 30 seconds, then power the modem, then the laptop.
  3. Test internet. Repeat the power‑cycle when reconnecting your router. [Elektroda, KOCUREK1970, post #18882132]
I swapped devices behind the modem and lost internet. What should I do?
Power‑cycle the Connect Box and the connected device for 30 seconds. The modem must obtain a different or new WAN IP before the new device works. Do the same when switching back to your router. [Elektroda, KOCUREK1970, post #18882132]
Does UPC WiFree stay active in bridge (modem) mode?
Yes. WiFree can remain active when the unit is in modem mode. Ask UPC via hotline or chat to disable WiFree on your account if you do not want it. [Elektroda, KOCUREK1970, post #18882132]
What downstream/upstream levels were reported in this case?
Downstream channels were about 9–10 dBmV. Upstream channels were 43–44 dBmV. These values came from the Connect Box’s advanced signal pages during troubleshooting. [Elektroda, Pawel_PS, post #18882158]
Are high downstream levels a problem?
Yes. Downstream near the upper acceptable bracket can cause instability. In this thread, upstream looked normal while downstream sat at the edge, which can explain morning no‑internet symptoms. [Elektroda, KOCUREK1970, post #18882185]
Who should I call at UPC, and what should I request?
Open a technical ticket and ask for a field technician to measure and adjust signal levels. They can also replace the modem if necessary. "Signal adjustment is essential." [Elektroda, KOCUREK1970, post #18882284]
What ultimately fixed the daily morning dropouts here?
A technician first replaced the Compal, which made it worse. Another visit measured signal outside the apartment and adjusted levels. After that adjustment, the connection stayed stable for 6 days. [Elektroda, Pawel_PS, post #18909975]
Should I replace the Ethernet cable between the Connect Box and my router?
Yes. Swap the RJ45 cable to rule out a flaky or oxidized lead. A bad patch cable can mimic WAN drops and complicate diagnosis. [Elektroda, KOCUREK1970, post #18882156]
Does firmware version matter for this issue?
The unit here ran CH7465LG‑NCIP‑6.12.18.26‑3p6‑GA‑NOSH, noted as the latest official release. The root cause proved to be signal, not firmware. [Elektroda, KOCUREK1970, post #18882132]
What management IPs does the Connect Box use in router vs modem mode?
Use 192.168.100.1 in modem/bridge mode. In router mode, management is 192.168.0.1 or 192.168.0.100. "There are 3 addresses in total." [Elektroda, KOCUREK1970, post #18882132]
Can remote resets from the hotline solve this?
Hotline agents can trigger remote resets, but that did not resolve the OP’s recurring morning outage. Persistent issues need deeper investigation. [Elektroda, Pawel_PS, post #18881833]
What hardware and plan did the OP use?
UPC 300/20 Mb/s service, Connect Box in bridge mode, and a Huawei AX3 router. Daytime worked fine, but mornings showed no external access until troubleshooting. [Elektroda, Pawel_PS, post #18881833]
