[Solved] UPC ConnectBox - spontaneous restarts, unstable Internet, link parameters, bridge/router mode
Bródka 11541 17
Why does my UPC ConnectBox keep restarting and losing Internet even in both bridge and router mode, and what should be checked on the DOCSIS line?
The spontaneous restarts were caused by an unstable DOCSIS coax link, not by bridge/router mode; when the signal is close to the limit, weather and small losses can make the modem lose contact with the CMTS and reboot to retune the channels [#20587728] The modem should be checked with a meter from the apartment back to the building entry point, because the fault can be in the modem, coax cable, connectors, splitters, or an old in-apartment installation, and simply swapping devices once is not enough [#20587728] [#20588743] [#20588919] The downstream values shown were described as only borderline, with upstream around 45–46 dBmV and downstream around -4 to -5 dBmV, so there was little reserve for further losses [#20587477] [#20588919] Turning off unused CB features like Wi‑Fi, IPv6, and WiFree was suggested as a cleanup step, but it was not the real fix [#20589575] In the end, a technician replaced a connector about 4 meters from the router and replaced the ConnectBox again, after which the disconnects stopped [#20596520]
  • Downstream signal levels and MER look normal
    #1 20586766
    Bródka
    Help: 900
    Rate: 723
    I have been fighting UPC with unstable Internet since the beginning of May.
    The router can restart several times a day - often every hour, but sometimes every few hours but at the same intervals.
    Regardless of whether it works in Bridge or Router mode. There are slightly better logs on MT
    Link parameters:
    Listed downstream channels
    Channel Frequency (Hz) Signal Level (dBmV) SNR (dB) Channel ID Modulation
    1 738000000 -5 36 256qam 17
    2 610000000 -4 36 256qam 1
    3 618000000 -4 36 256qam 2
    4 626000000 -4 36 256qam 3
    5 634000000 -4 36 256qam 4
    6 642000000 -5 36 256qam 5
    7 650000000 -5 36 256qam 6
    8 658000000 -4 36 256qam 7
    9 666000000 -4 36 256qam 8
    10 674000000 -5 35 256qam 9
    11 682000000 -5 36 256qam 10
    12 690000000 -4 36 256qam 11
    13 698000000 -5 35 256qam 12
    14 706000000 -5 36 256qam 13
    15 714000000 -5 35 256qam 14
    16 722000000 -5 36 256qam 15
    17 730000000 -5 35 256qam 16
    18 746000000 -5 36 256qam 18
    19 754000000 -5 35 256qam 19
    20 762000000 -5 35 256qam 20
    21 770000000 -5 35 256qam 21
    22 778000000 -5 35 256qam 22
    23 786000000 -5 35 256qam 23
    24 794000000 -5 35 256qam 24
    Channel RxMER Lock Status (dB) Pre RS Errors Post RS Errors
    1 Blocked 36.387 134367674 12
    2 Blocked 36.610 132100535 3
    3 Blocked 36.610 132101200 6
    4 Blocked 36.610 132109719 15
    5 Blocked 36.610 132103311 9
    6 Blocked 36.387 132101870 5
    7 Blocked 36.610 132071151 4
    8 Blocked 36.387 132072990 6
    9 Blocked 36.610 132096700 4
    10 Blocked 35,780 132102971 7
    11 Blocked 36.387 132103504 8
    12 Blocked 36.387 132099887 6
    13 Blocked 35,780 132096644 10
    14 Blocked 36.387 132103638 5
    15 Blocked 35.595 132071096 22
    16 Blocked 36.387 132103975 10
    17 Blocked 35,780 132104485 20
    18 Blocked 36.387 132096406 7
    19 Blocked 35,780 132104567 16
    20 Blocked 35,780 132071326 14
    21 Blocked 35,780 132069116 25
    22 Blocked 35,780 132071570 27
    23 Blocked 35.595 132104480 34
    24 Blocked 35.595 132104884 109
    Frequencies in the return channel
    Channel Frequency (Hz) Signal Level (dBmV) Symbol Rate (ksps) Channel ID Modulation
    1 54400000 45 5.120 64qam 1
    2 29200000 45 2.560 64qam 6
    3 61100000 46 5.120 64qam 5
    4 47700000 45 5.120 64qam 4
    5 41000000 45 5.120 64qam 3
    6 34300000 45 5.120 64qam 2
    Channel Channel type T1 Timeout T2 Timeout T3 Timeout T4 Timeout
    1 2.0 0 0 0 0
    2 2.0 0 0 0 0
    3 2.0 0 0 0 0
    4 2.0 0 0 0 0
    5 2.0 0 0 0 0
    6 2.0 0 0 0 0
    The reset itself on ConnectBox only shows up like this:
    01-01-1970 01:01:24 notice Cable Modem Reboot - due to power reset;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=00:00:00:00:00: 00;CM-QOS=1.1;CM-VER=3.0;
    However, there are better logs on Mikrotik:
    I have no idea how to talk to them, once they replaced the ConnectBox along with the power supply and the BNC plug for the router.. A few days later (i.e. May 18, 2023) they came and replaced the connectors on the cage and in the box
    The device continues to restart
    I can explain on the hotline how things are going procedurally anyway...
    I don`t know anything about DOCSIS, so I`m writing here for help
  • #2 20586771
    jimasek
    Help: 3783
    Rate: 2681
    @KOCUREK1970 topic for you. Greetings to my friend @Bródka
  • Corrected F-connector type and posted DOCSIS signal ranges
    #4 20587477
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Bródka wrote:
    they replaced the ConnectBox along with the power supply and BNC plug for the router
    BNC plug?
    It should be a compression F plug.
    Could I ask you to insert a window from the modem router (printscreen)?
    Upstream - from 40 to 50 dBmV
    Downstream - from -8 to +10 dBmV
    SNR Upstream - 21 / 27 dB depending on modulation (QAM16 / QAM64)
    SNR Downstream - above 31 dB
    Downstream:
    -7 dBmV to +7 dBmV - optimal signal
    -8 dBmV to -10 dBmV or +8 dBmV to +10 dBmV - good signal
    -11 dBmV to -15 dBmV or +11 dBmV to +15 dBmV - bad signal
    -15 dBmV and below or +15 dBmV and above - very bad signal
    Upstream:
    +35 dBmV to +49 dBmV - optimal signal
    SNR (Signal to Noise Ratio):
    256 QAM > 33 dB - optimal signal
  • Intermittent instability with modem screenshots provided
    #5 20587602
    Bródka
    Help: 900
    Rate: 723
    Yes exactly
    Of course
    Below is a link directly to the file because the electrode probably compresses these files very strongly and they are not readable
    https://sos-pc.pl/screenshot.jpeg
    https://sos-pc.pl/screenshot2.jpeg
    https://sos-pc.pl/screenshot3.jpeg
    I will add that since yesterday evening it has calmed down, but earlier it could be ok for a day and then come back again
    Weather-dependent DOCSIS signal likely causing modem restarts
    #6 20587728
    KOCUREK1970
    Help: 3860
    Rate: 5488
    DOCSIS as a technology has the "advantage" that the signal depends on the weather, air humidity and temperature.
    Your signal is "almost" on the verge of breaking the CB link with CMTS, hence the restarts - it`s not exactly the limit yet, but when the signal breaks down due to weather conditions, the modem has no way to compensate for it.
    Of course, it is not the case that if the signal breaks, the modem will immediately restart - the modem "waits" and from time to time asks CMTS like "hello, how are you" and if there is no connection to CMTS during this period , the modem restarts to search the UD/DS channels again and try to tune in to what is currently available.
    Now the question is what the error is - there are several possibilities:
    - damaged modem,
    - something with the signal itself,
    - something with a coaxial cable from the locbox to your apartment,
    - something in the cable installation in your apartment,
    - damaged splitters that divide the signal into a modem and, for example, a cable decoder...
    And now the "best thing", it is impossible to easily diagnose the problem - because everything that may be at fault should be replaced and monitored to see if there is any improvement.
    Unfortunately, no service technician has time for observation.
    If they are going to replace something, don`t count on them replacing it all at once.
    No one will agree to this, because the culprit may be a piece of crap worth PLN 20, and the cost of replacing everything may be several hundred PLN, so everything will be done in small steps.
    Call UPC and report the problem, because you can`t do anything about it yourself.
    And if this does not help, submit a written complaint (if you decide to do so, I will tell you what such a complaint should contain) and send it by REGISTERED LETTER to the UPC address.
    And my additional questions:
    - describe how your cable installation was done,
    - where and how the coaxial cable goes,
    - are there any splitters and what are their names,
    - is the signal divided somehow?
    - did you modify the installation yourself/add something/extend the cables, etc
    VooVoo
    Help: 215
    Rate: 266
    DS signal to improve (up) and check why there are so many errors that the modem is trying to correct :( Without a technician with a meter who should check it, starting from the premises, ending with the receiver, if necessary.
  • Old apartment cable and loose connector suspected
    #8 20588760
    Bródka
    Help: 900
    Rate: 723
    As I wrote, the technician replaced the modem and the connector on the staircase where the box used to be - now they are every few floors and he is doing something in the box, I don`t know what, I wasn`t with him. The measurements say they are good.
    I haven`t changed anything in the wiring in the apartment, there is no splitter - the TV is broadcast over the Internet
    The cable itself goes from the staircase to the hall and the room, maybe 15 meters of cable in total, the cable runs on the wall, everything is visible and it is old because it was installed about 15 years ago. I will add that I noticed a connector behind the furniture - the terminals themselves are made of clamps and are held in place because the previous ones he replaced just had to be pulled and the cable itself came out.
    I`ll come back in the evening and check if there were any restarts and let you know
    Added cable length can destabilize DOCSIS sync
    #9 20588919
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Bródka wrote:
    I will add that I noticed a connector behind the furniture - the ends themselves are made of clamps and are held in place
    So the modem used to be there?
    Who added this next cable there?
    What software do you have on your modem (firmware)?
    And here is some additional information - the DOCSIS signal is calibrated/set by the technician, depending on what is currently available.
    So it is "normal" that if we add at least 5 m of cable and the signal on the original cable was already bad, then after adding another one it may deteriorate so much that the modem will not synchronize with CMTS at all, or it will work at the limit, balancing, increasing its reception power. /broadcast.
    And this modem operation will continue until the modem is no longer able to "hold" the link with CMTS.
    Exactly.
    VooVoo wrote:
    the why control is full of a hell of a lot of bugs
    The CB software itself is also "somewhat to blame" here - earlier versions did not report any errors at all :D
    The optimal level would be 0 dBmV everywhere, so the modem would have the full balance range in case of any problems and would have "power reserve".
    Because the poorer the signal, the more the modem works with transmit/receive power, but this also causes (the worse signal) the modem reports more errors.
  • Restarts correlate with DFS channel changes and TR-069 activity
    #10 20589496
    Bródka
    Help: 900
    Rate: 723
    Yesterday at 11 p.m. there was a restart, this morning after 9 a.m. and at 4 p.m. The logs from the modem are only from today - I see restarts on the MT side - over the weekend ConnectBox works in router mode to be sure that my router is not breaking the session as the technician claimed. UPC
    Logs from the modem:
    21-05-2023 19:53:10	notice	GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.0.94];CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 19:38:24	notice	Illegal - Dropped INPUT packet: SRC=142.250.203.138 MAC=2C:57:41:E7:78:19;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 19:38:14	notice	GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.0.94];CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 19:38:03	notice	GUI Login Status - Login Fail from LAN interface; client ip=[192.168.0.94];CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 19:23:25	warning	[38:43:7D:9B:3A:28][DFS] Radar signal detected, DFS sequence applied, channel changed from 64 to 36
    21-05-2023 16:27:58	notice	TR069 start;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 16:27:15	notice	Illegal - Dropped INPUT packet: SRC=78.11.196.202 MAC=2C:57:41:E7:78:19;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 16:26:35	notice	REGISTRATION COMPLETE - Waiting for Operational status;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 16:26:25	notice	Illegal - Dropped FORWARD packet: SRC=192.168.0.94 MAC=C4:AD:34:BF:37:4C;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 16:26:10	warning	MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    01-01-1970 01:01:23	notice	Cable Modem Reboot - due to power reset;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 16:15:17	notice	Illegal - Dropped INPUT packet: SRC=216.58.209.14 MAC=2C:57:41:E7:78:19;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:09:17	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:09:10	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:08:10	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:07:51	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:06:51	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:06:31	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:05:31	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:05:11	critical	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    21-05-2023 10:04:11	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=38:43:7d:a2:5d:38;CMTS-MAC=2c:57:41:e7:7a:b3;CM-QOS=1.1;CM-VER=3.0;
    It never was, the modem is always in the same place. I didn`t know about the connector, it was given to me by a technician years ago when installing the cable because no one lived there except me and they pulled the cable in my apartment for me during the first installation in the days of analog cable, and I didn`t bother with it myself because I don`t even have the crimping equipment.
    Compliance with standards: DOCSIS 3.0
    Hardware version: 5.01
    Software version: CH7465LG-NCIP-6.15.31p1-NOSH
  • #11 20589504
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @Bródka
    The logs contain information that WiFi has detected DFS channels and additionally radars.
    What channel is your 5GHz WiFi set on in CB?
  • #12 20589532
    Bródka
    Help: 900
    Rate: 723
    Yes, I see, smart wifi and automatic channels were set, I changed it to 36 but I don`t use wifi on it, I have mine from Mikrotik, now there are these errors because it works in router mode, and since I live in an apartment block, there are a lot of networks here
    So do you think you should call UPC again?
    KOCUREK1970
    Help: 3860
    Rate: 5488
    So turn off wifi on CB altogether.
    It is also worth turning off IPv6 on the CB, as well as WiFree (not to be confused with Wi-Fi).
    Bródka wrote:
    So, do you think you should call UPC again?
    There is no point in calling, because such intervention will do you no good.
    Only written complaint.
  • #14 20589590
    Bródka
    Help: 900
    Rate: 723
    Done
    I turned it off for good morning :)
    I will do the same - as you wrote earlier, please tell me what and how to write to them
  • Complaint template and telecom compensation calculation guidance
    #15 20589695
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Complaint about telecommunications services:
    https://cik.uke.gov.pl/uslugi-teleko/pytania-i-odpowiedzi/reklamacje-i-skargi-faq/
    Complaint in writing, including all evidence of problems.
    In the complaint, describe exactly what we are demanding, how much money should be given as compensation from the date of the complaint until the defect is permanently removed, and how much money should be given for the subscription when the service did not work properly.
    The rate for compensation and reduced wages is 1/30 for each day of the problem, calculated separately.
    The abo relief and compensation are then calculated jointly as 2/30.
    Indicate that the response must also be in writing.
    The response should be provided within 30 days from the date of submission.
    The deadline of 30 days for the operator`s response to a complaint is counted from the day following the date of submission of the complaint.
    If the complaint is not considered within this period, it is presumed that it has been accepted (Article 106(2) of the Telecommunications Law).
    If the response to a complaint is negative or unsatisfactory, the subscriber may apply to the Office of Electronic Communications for intervention or to conduct out-of-court proceedings to resolve consumer disputes (ADR proceedings).
    A Consumer Ombudsman may also be helpful.
  • Firmware 6.15.31p1-NOSH triggers reboot under load
    #16 20593108
    WojtasJD
    Help: 2919
    Rate: 1586
    Specialists - I have this Compal, I run the speedtest.net test and during this time I unplug the F plug for a moment, the speed test is obviously an error and the turtle starts blinking its LEDs and after a few minutes there is access to the network again.
    According to what you write, should it be restarted or not?
    Maybe you should pet it and cover it with foil, because some fly will land on it and it will reboot?
    A few years ago I had such an interesting problem that on another computer, after running Linux and then the browser and starting to browse the Internet, Compal restarted. Under W7 - this never happened.
    After some time the problem disappeared, I had suspicions about r8169 (the kernel module that deals with the Ethernet card).
    And now this thread...
    After some digging, I came up with:
    https://superuser.com/questions/1462424/router-restarts-after-big-git-push-or-big-file-upload
    https://hitco.at/blog/magenta-connect-box-rebootet (here the man did a great analysis, translate the page and repeat the steps)
    It says that the problem was solved by the version:
    CH7465LG-NCIP-6.15.32p2TM-GA-NOSH
    We have:
    CH7465LG-NCIP-6.15.31p1-NOSH (https://forum.mediaswiat.pl/viewtopic.php?t=9310&postdays=0&postorder=asc&start=2055)
    Today I tested a bit - it is possible to disable this modem-router to restart it, supposedly because of:
    Cable Modem Reboot - due to power reset;CM-MAC=ac:22:05:**:**:**;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1; CM-VER=3.0;
    Everything is shown in the video (a bit long but that`s because of the turtle`s restart time) - a computer with openSUSE 15.4 + KDE Plasma 5.24.4 connected via Ethernet to CM, on the left side of the emulator. kitty terminal in which I run the translated script from https://hitco.at/blog/magenta-connect-box-rebootet compal...7z (599 bytes)You must be logged in to download this attachment.
    On the right, a window with emulation. terminal and working: ping 8.8.8.8
    Sometimes it is enough to alternate the script and speedtest, in this case CM crashed after running two scripts in parallel.
    [2023-05-24 15-57-23.mp4 - 15.8 MiB]
  • Firmware version 6.15.32p3-NOSH should fix restarts
    #17 20593122
    KOCUREK1970
    Help: 3860
    Rate: 5488
    There should already be a version:
    CH7465LG-NCIP-6.15.32p3-NOSH
    And don`t rely on information from the Internet.
    Please remember that this is a modem router from 2015, it had and still has its hardware problems - there are no new ones, everything has been refurbished.
    Perhaps, but this does not apply to Poland!
    The version mentioned above should solve this problem.
  • #18 20596520
    Bródka
    Help: 900
    Rate: 723
    Finally, the technician came for the third time, replaced the connector which was about 4 meters from the router, replaced the connect box again and the problem with disconnecting the connection disappeared. Thank you all for your help. Regards
The discussion revolves around persistent issues with the UPC ConnectBox, characterized by frequent spontaneous restarts and unstable internet connectivity. The user reports that the device restarts multiple times daily, regardless of its operation mode (Bridge or Router). Various technical parameters, such as upstream and downstream signal levels, were analyzed, indicating that the signal quality is near the threshold for stable operation. Suggestions included checking the coaxial cable, connectors, and signal levels, as well as disabling Wi-Fi and IPv6 on the ConnectBox. After multiple technician visits and replacements of the modem and connectors, the user finally reported a resolution to the disconnection issues.
TL;DR: “256 QAM > 33 dB — optimal signal” and downstream −7 to +7 dBmV keep UPC Connect Box stable. If your CH7465LG reboots in bridge or router mode, check signal, logs (T3/T4), cabling, and firmware. For UPC/Virgin Media users fixing spontaneous restarts. [Elektroda, KOCUREK1970, post #20587477]
Why it matters: Faster root-cause isolation reduces downtime and avoids endless ticket ping‑pong with your ISP.
Why is my UPC Connect Box rebooting randomly?
Because the RF link to the CMTS is marginal. Weather, humidity, and temperature shift levels. The modem periodically checks the CMTS and reboots to retune when it cannot reach it. Causes include weak signal, damaged modem, bad coax, in‑apartment splitters, or the building feed. “DOCSIS as a technology has the ‘advantage’ that the signal depends on the weather, air humidity and temperature.” Ask for line checks and component replacement. [Elektroda, KOCUREK1970, post #20587728]
What downstream/upstream levels and SNR should I aim for on DOCSIS 3.0?
Targets: Downstream −7 to +7 dBmV is optimal; −8 to −10 or +8 to +10 is good; ±11 to ±15 is bad; below −15 or above +15 is very bad. Upstream +35 to +49 dBmV is optimal. SNR: Downstream 256‑QAM >33 dB is optimal, and above 31 dB is acceptable. Upstream SNR is 21–27 dB depending on modulation (QAM16/QAM64). [Elektroda, KOCUREK1970, post #20587477]
What do T3/T4 timeouts in my Connect Box logs mean?
They indicate the modem cannot complete maintenance ranging or secure a unicast opportunity with the CMTS. Example: “Started Unicast Maintenance Ranging - No Response received - T3 time-out.” In the shared logs, repeated T3/T4 errors preceded re‑registration and a reboot notice. Use these timestamps to correlate with drops. [Elektroda, Bródka, post #20589496]
Does bridge vs router mode affect these restarts?
No. The same reboots occurred in both bridge and router modes in this case. That points to a physical‑layer or firmware issue rather than LAN settings. Test both modes to rule out your own router, and keep logs for correlation. [Elektroda, Bródka, post #20586766]
Could DFS radar channel changes be the reason for drops?
DFS events force 5 GHz to change channels, briefly interrupting Wi‑Fi. The logs show “[DFS] Radar signal detected … channel changed from 64 to 36.” In the same timeframe, T3/T4 DOCSIS timeouts triggered loss of registration, which is separate from Wi‑Fi DFS. [Elektroda, Bródka, post #20589496]
Should I disable Wi‑Fi, IPv6, or WiFree on the Connect Box?
Yes, if you use another access point or want to reduce variables. Expert advice here: turn off Wi‑Fi on the Connect Box, and also disable IPv6 and WiFree. This cuts background services and potential channel changes. “So turn off wifi on CB altogether.” [Elektroda, KOCUREK1970, post #20589575]
How can I document the issue for support?
Capture three screenshots: Downstream channel table (power and SNR), Upstream levels, and the Event Log. Share full‑resolution images so values remain readable, just as the OP provided via direct image links. Include timestamps before and after each outage for correlation. [Elektroda, Bródka, post #20587602]
Is there a known firmware-triggered reboot under heavy upload?
Yes. One user reproduced reboots by stressing the CH7465LG with scripted uploads and speedtests on Linux. The modem crashed and logged “Cable Modem Reboot - due to power reset.” They noted 6.15.31p1‑NOSH and cited reports that 6.15.32p2TM‑GA‑NOSH fixed it. Ask your ISP about firmware. [Elektroda, WojtasJD, post #20593108]
Which firmware should CH7465LG run in Poland?
Forum expertise indicates CH7465LG‑NCIP‑6.15.32p3‑NOSH as the current Poland build. These 2015 units can have hardware quirks. Request the latest firmware push from your ISP if stability issues persist, and consider hardware replacement if problems continue. [Elektroda, KOCUREK1970, post #20593122]
Can old connectors or extra cable length cause instability?
Yes. The DOCSIS signal is calibrated for your run, so extra length or poor splitters can push levels out of range. Replace suspect F‑compression connectors and avoid unnecessary joins. “It is ‘normal’ that if we add at least 5 m of cable … the modem will not synchronize.” [Elektroda, KOCUREK1970, post #20588919]
How was this specific case resolved?
A third technician replaced a faulty connector about 4 meters from the router and swapped the Connect Box. After that, the spontaneous disconnections stopped. This confirms a physical‑layer issue was the culprit in this scenario. [Elektroda, Bródka, post #20596520]
How do I file an effective written complaint if the issue persists?
  1. Draft your complaint with dates, logs, screenshots, and specific demands. Request bill reduction and compensation at 1/30 per day.
  2. Send by registered letter and require a written reply within 30 days. “The response should be provided within 30 days.”
  3. If refused or ignored, seek UKE ADR/intervention and ask your Consumer Ombudsman for help. [Elektroda, KOCUREK1970, post #20589695]
What if the technician says “measurements are good” but errors keep climbing?
Request a visit with a proper meter and end‑to‑end checks, starting at your premises and back to the receiver. Improve downstream levels and investigate why the modem is correcting so many errors. Persistent errors require on‑site diagnostics and adjustments. [Elektroda, VooVoo, post #20588743]
What does the “Cable Modem Reboot - due to power reset” entry mean?
It is the generic restart marker. During restart, the log often shows CMTS‑MAC as 00:00:00:00:00:00 until resync. Example: “Cable Modem Reboot - due to power reset; CMTS-MAC=00:00:00:00:00:00.” Use prior T3/T4 and registration entries to determine root cause. [Elektroda, Bródka, post #20586766]
