How to Fix Microphone Audio Delay When Monitoring on Windows 10/11 PC
dex590 43056 10
How can I eliminate the noticeable delay when monitoring my microphone through PC speakers or headphones on Windows?
Turn off microphone listening/monitoring and raise the microphone volume in the microphone settings instead; that solved the delay. [#10736604]
  • #1 8862435
    dex590
    After connecting the microphone to the computer and turning on the listening device, you can hear everything with a minimal delay, which is nevertheless bothersome. What to do to remove them?
  • #2 8862516
    fascynat
    Help: 64
    Rate: 107
    You should specify what hardware you have (computer, sound card) and what operating system you are using, yes ...
    Read e.g. here .
  • #3 8863963
    dex590
    Windows 7 64 bit Ultimate, ASRock 890GX EXTREME3 integrated sound card, latest HdVDeck drivers installed, microphone 100% functional.
    I have already searched on googles ..., I have read this article before, but it has nothing to do with my problem because it only works with the audio software listed there.
    Apparently, you can set it so that you have turned off monitoring, which is said to be the cause of the delay, and at the same time that you can hear the microphone on the speakers.
  • #4 8864118
    fascynat
    Help: 64
    Rate: 107
    dex590 wrote:
    ... I have read this article before, but it has nothing to do with my problem ...
    That's why I wrote that you should give ... clairvoyants, unfortunately we have a shortage of them.
    Is this delay noticeable when using any particular program under Win7?
  • #5 8864199
    dex590
    the point is that you can hear what I say with gain but without delay without using any program, but using e.g. Audacity there is also a delay
  • #6 8864209
    fascynat
    Help: 64
    Rate: 107
    The microphone has a USB plug or a jack?
  • #7 8864253
    dex590
    the minijack, plugged into every possible socket, has the same delay, can you set it somehow so that without using the listening function I could hear myself through the speakers / headphones?
  • #8 8864262
    fascynat
    Help: 64
    Rate: 107
    Maybe an installation these drivers will help you.
  • #9 8864861
    dex590
    I pre-installed them, now I'm trying to set it up, but I don't know what to do to make it work - after launching the foobar with the plug, when I start a song, Aiso works (a green tray icon with a playback icon is displayed) but I can't hear anything ... I tried to change the settings but I have achieved nothing
  • #10 8867401
    gonzo24
    Maybe it's a matter of setting in the program.
    I used to record desktop actions using CamStudio (the free one). And there the sound diverged from the recorded image. It turned out there was no synchronization.
    The film was recorded with set by frames marked in the options and set by milisecons in the sound.
    Hence the destruction.
  • #11 10736604
    dex590
    The solution was simple, it was enough to give up listening and increase the volume level in the microphone settings.
The discussion revolves around the issue of microphone delay experienced when using a computer with an ASRock 890GX EXTREME3 integrated sound card and Windows 7 64-bit Ultimate. The user reports a bothersome delay when monitoring audio through speakers or headphones, even when using software like Audacity. Suggestions include checking hardware connections (USB vs. minijack), adjusting microphone settings to disable monitoring, and ensuring proper driver installation. A solution was ultimately found by increasing the microphone volume level and ceasing the listening function, which eliminated the delay.
