BMW E46 2003: Dashboard Airbag Symbol, Cruise Control, Brake Lights Issues & Solutions
grzes19911 4161 2
  • #1 17080518
    grzes19911
    Rate: 21
    Hello, I have the following problem when I was returning home in a BMW E46 2003 I noticed an airbag symbol on the dashboard that did not light up, but got involved. after another start of the engine, there were lights from the rear lights and the cruise control that I have started. All three brake lights were on continuously. after removing fuse 9, the lights did not go out. The lights were still on with the brake pedal sensor removed. After another start of the engine, the lights and cruise control lights went out and the pillow will start again. The traction control switch does not work, the seat heating does not work, the horn does not work and turns on the stop lamps. Fuses ok, the brake pedal sensor is also probably good because what has to do with the horn or heating the seats. I changed the light module, but with the bmw e46 2000r with xenon and the effect was the same. only that this module was from a terrible bmka that had xenon lights and the number started with 61 my module on 69. The computer is not wet because the car is garaged. anyone have any ideas for solving the problem?
  • #2 17081197
    Cobrat
    Help: 35
    Rate: 501
    Have you checked / removed fuse No. 11 (passenger compartment)?
  • #3 17082360
    grzes19911
    Rate: 21
    11 is from the airbag, I checked this option at the beginning. They are all ok. even one burned out, one light would burn and a lot of things do not work in the car. seat heating, traction control switch, sound signal, stop lights turn on when they like it, cruise control, radio control from the steering wheel, the traffic light indicator does not light, only it will
