Bmw e39 - Malfunctioning Central Locking and Window Controls: Driver and Passenger Doors
kempes221 11664 4
  • #1 16727904
    kempes221
    Hey. I have a problem in my e39. Central locking in the front door (driver and passenger) does not work. The control of the windows from the driver's panel does not work except the driver's window (it works normally from the panel). The rest of the glass works but with the buttons on the door. I can't control the right mirror. I checked the panel from another car and it is the same. I have also replaced the comfort module and nothing. I am asking for help because I am heartbroken.
  • #2 16727915
    andrzej20001
    Help: 1574
    Rate: 6647
    Review the fuses carefully one after another.
  • #3 16728007
    carrier
    Car alarms specialist
    Help: 511
    Rate: 1053
    see the cables in the door grommet, probably broken
  • #4 16728272
    kempes221
    Everything's checked out. None of these things, unfortunately :(
  • #5 16733825
    kempes221
    The problem was solved and the solution was banal. Well, I checked everything that was possible in the car. And it turned out that everything went through as I SEWED THE ARMCHAIR FROM P-BUS. I have no idea why it happened that the seat driver fucked something in GM ... I have no idea what it could be about because I used the same seat module before (because my previous seat broke) and when connecting new seats it happens. After reconnecting the P-BUS to the seat it is the same, the central one in the front door does not work, the cushion is lit (passenger mat error, although it is blinded with a resistor). If the chair is disconnected, everything suddenly starts working. And this is not GM's fault because I bought a second one and it is the same so there is something with a chair on the bank. The chair, of course, walks normally (moves, pumps, etc.). However, THANK YOU for your help. I still have to look at the pins in the chair because maybe something did not play there.
    best regards :)
