BMW E61 Seat belt and airbag error - Seat belt and cushion error, airbag 93f9
kamilo1409 20670 6
  • #1 16982695
    kamilo1409
    Rate: 30
    Hello, as in the subject I have a pillow and belt error. One photo with an error read from Carly, the other from Inpy (once I managed to delete it for maybe a minute and came back) and a photo from idrive. I will add that I have an IBS bug, but if it has something to do, I don't know. I ask for advice.
    • BMW E61 Seat belt and airbag error - Seat belt and cushion error, airbag 93f9 27265408_1007903702682050_818945828_o.jpg (170.34 KB) You must be logged in to download this attachment.
    • BMW E61 Seat belt and airbag error - Seat belt and cushion error, airbag 93f9 1111.JPG (13.88 KB) You must be logged in to download this attachment.
    • BMW E61 Seat belt and airbag error - Seat belt and cushion error, airbag 93f9 Przechwytywanie.JPG (19.35 KB) You must be logged in to download this attachment.
  • #2 16983390
    melas
    Help: 138
    Rate: 689
    You have a crash saved or badly cleaned.
  • #3 16983579
    kamilo1409
    Rate: 30
    And how to clean it? Ista / inpa, do you need any special equipment?
  • #7 17244994
    mcgusto
    Rate: 24
    Check the tensioner on the battery ....
The discussion revolves around a BMW E61 experiencing seat belt and airbag errors, specifically error code 93F9. The user reports issues with the airbag and seat belt, mentioning attempts to clear the error using Carly and INPA, but the error reappears. Responses suggest that the problem may be due to a crash data issue that needs to be properly cleared. Users inquire about the necessary equipment for cleaning the error, with references to resources and forums for further guidance. Additionally, there is a suggestion to check the tensioner on the battery as a potential cause of the error.
