[Solved] How to Disconnect Internet in Windows 10: Switch Between Two PLUS LTE & Cable Networks Easily
boltron 7755 9
How can I disconnect and reconnect my Windows 10 cable internet connection from Windows without turning the modem on and off?
You can disconnect the cable internet by disabling the Ethernet/LAN adapter in Windows, then enabling it again when you want to use it [#17092479][#17093286] Press Win+R, type `ncpa.cpl`, and in the Network Connections window right-click the local connection/network card and choose Disable; to reconnect, right-click it again and choose Enable [#17093286][#17092479] After enabling, Windows may need a minute to start the card, get an IP from DHCP, and establish the connection again [#17092479] If you want a one-click method, a batch file or `netsh` shortcut can also be used for the LAN adapter name [#17081073]
  • #1 17081027
    boltron
    The question sounds idiotic it's true, but the situation is:
    - I have two PLUS LTE and cable internet networks
    - When I connect the cable to my laptop, I find the internet and unfortunately I do not see the disconnect option in the settings here, and I do not want to play with the modem all the time (turn it on and off, connect and disconnect).
    - I just want to connect to the Internet from Windows, I have easy with PLUS LTE because there a window pops up in my browser or I want to connect to the Internet
  • #3 17083503
    boltron
    The scary thing is that with such a trivia you have to f *** up so much. There is no other way?
    2018, Windows 10 and there is no internet connect button, disconnect internet :D .
  • #4 17084111
    myszkoscielna
    Help: 62
    Rate: 31
    google windows one-click disable internet
    there you will find ready-to-install programs.
  • Batch file suggested to disconnect internet in Windows 10
    #5 17084139
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    2018 - hardly anyone disconnects from the Internet, so why do such a function in Windows for the masses? If someone cares, he will write a batch file containing not too complicated content in the form of one command line. A real drama. If you had tried to write a file, instead of complaining for two days, it would take you about a minute to two.
  • #6 17090411
    KOCUREK1970
    Help: 3860
    Rate: 5488
    And not easier and simpler to just turn off the LAN network in the device manager?
  • #7 17092443
    boltron
    How to do it? What should I turn off exactly?
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @boltron
    KOCUREK1970 wrote:
    just turn off the LAN in the device manager?
    Right-click on the name of the network card and do "disable" or "disable".
    And when we want to use it, we do "the other way" or "enable" or "enable".
    You need to give the card a minute to start up, ask the DHCP server for IP, lease time and establish a connection.
    haring
    Help: 5
    Press the key combination: window (on the keyboard there is a windows sign between CTRL and ALT) + R -> a run window will appear, type in it: ncpa.cpl and enter in the newly opened window you will see your PPM network cards (right mouse button) for local connection and turn off to turn it on repeat this action only at the end turn it on again. :)
  • #10 17094415
    boltron
    Kocurek solved the problem nicely.
    That's what I did, that I created shortcuts from this Ethernet connection and PPM is there to turn off. It's kind of funny that such a trivial problem has to be combined with some shortcuts. I always thought that in the sidebar there at the connection, the clock has an on-off option, and it wasn't.
    Cheers and thanks!
The discussion revolves around the challenge of disconnecting from an internet connection in Windows 10 when using multiple networks, specifically PLUS LTE and cable internet. Users express frustration over the lack of a straightforward disconnect option in the settings. Various solutions are proposed, including using the Device Manager to disable the LAN network card, creating batch files for quick access, and utilizing keyboard shortcuts to access network settings. One user successfully created shortcuts for easier management of the Ethernet connection. The conversation highlights the need for more intuitive network management features in Windows 10.
